在线时间14 小时
UID3083363
注册时间2015-9-21
NXP金币0
TA的每日心情 | 开心 2017-1-12 19:53 |
- 111
- 2019-2-25
/* main.c: FlexCAN program */
/* Description: Transmit one message from FlexCAN 0 buf. 0 to FlexCAN C buf. 1
(从 FlexCAN 0 buf. 0 传递一个消息到FlexCAN C buf. 1)*/
/* Rev 0.1 Jan 16, 2006 S.Mihalik, Copyright Freescale, 2006. All Rights Reserved */
/* Rev 0.2 Jun 6 2006 SM - changed Flexcan A to C & enabled 64 msg buffers */
/* Rev 0.3 Jun 15 2006 SM - 1. Made globals uninitialized */
/* 2. RecieveMsg function: read CANx_TIMER, removed setting buffer's CODE*/
/* 3. added idle loop code for smoother Nexus trace */
/* 4. modified for newer Freescale header files (r 16) */
/* Rev 0.4 Aug 11 2006 SM - Removed redundant CAN_A.MCR init */
/* Rev 0.5 Jan 31 2007 SM - Removed other redundant CAN_C.MCR init */
/* Rev 0.6 Mar 08 2007 SM - Corrected init of MBs- cleared 64 MBs, instead of 63 */
/* Rev 0.7 Jul 20 2007 SM - Changes for MPC5510 */
/* Rev 0.8 May 15 2008 SM - Changes for new header file symbols */
/* Rev 0.9 May 22 2009 SM - Changes for MPC56xxB/P/S */
/* Rev 1.0 Jul 10 2009 SM - Simplified, cleared CAN Msg Buf flag by writing to reg */
/* not bit, increased Tx pads slew rate(转换率), changed RxCODE, RxLENGTH, dummy data(虚拟数据) types*/
/* & init receiving CAN first to allow CAN bus sync time before receiving 1st msg*/
/* Rev 1.1 Mar 14 2010 SM - modified initModesAndClock, updated header file */
/* NOTE!! structure canbuf_t in header file modified to allow byte addressing*/
/*Chapter 22*/
#include "MPC5604B_M27V.h" /* Use proper include file */
uint32_t RxCODE; /* Received message buffer code */
uint32_t RxID; /* Received message ID */
uint32_t RxLENGTH; /* Recieved message number of data bytes */
uint8_t RxDATA[8]; /* Received message data string*/
uint32_t RxTIMESTAMP; /* Received message time */
void initModesAndClks(void) /*系统初始化*/
ME.MER.R = 0x0000001D; /* Enable DRUN, RUN0, SAFE, RESET modes */
/* Initialize PLL before turning it on: (初始化锁相环)*/
/* Use 1 of the next 2 lines depending on crystal frequency: */
//锁相环时钟没问题
CGM.FMPLL_CR.R = 0x02400100;
//0x02400100 /* 8 MHz xtal: Set PLL0 to 64 MHz */
/*CGM.FMPLL_CR.R = 0x12400100;*/ /* 40 MHz xtal: Set PLL0 to 64 MHz */
ME.RUN[0].R = 0x001F0074; /* RUN0 cfg: 16MHzIRCON,OSC0ON,PLL0ON,syclk=PLL */
// ME.DRUN.R=0x001F0010;
// ME.RUNPC[0].R = 0x000000FE; /* Peri. Cfg. 1 settings: only run in RUN0 mode */
ME.RUNPC[0].R = 0x00000010;
/*要什么功能就在PCTL中配置相应的序号*/
/*选择FlexCAN0和FlexCAN1控制*/
ME.PCTL[16].R = 0x01; /* P143 MPC56xxB/P/S FlexCAN0: select ME.RUNPC[1] */
//要和RUNPC保持一致
ME.PCTL[17].R = 0x01; /* MPC56xxB/S FlexCAN1: select ME.RUNPC[1] */
/*选择SIUL控制*/
ME.PCTL[68].R = 0x01; /* MPC56xxB/S SIUL: select ME.RUNPC[1] */
/*此处未进行端口引脚配置*/
// ME.PCTL[96].R=0x00;
/* Mode Transition to enter RUN0 mode: */
ME.MCTL.R = 0x40005AF0; /* Enter RUN0 Mode & Key */
ME.MCTL.R = 0x4000A50F; /* Enter RUN0 Mode & Inverted Key */
while (ME.GS.B.S_MTRANS) {} /* Wait for mode transition to complete */
/* Note: could wait here using timer and/or I_TC IRQ */
while(ME.GS.B.S_CURRENTMODE != 4) {} /* Verify RUN0 is the current mode */
void initPeriClkGen(void) /*??*/
CGM.SC_DC[1].R = 0x80; /* MPC56xxB/S: Enable peri set 2 sysclk divided by 1 */
CGM.OC_EN.R= 1;
CGM.OCDS_SC.R= 0x22000000;
void disableWatchdog(void)
SWT.SR.R = 0x0000c520; /* Write keys to clear soft lock bit */
SWT.SR.R = 0x0000d928;
SWT.CR.R = 0x8000010A; /* Clear watchdog enable (WEN) */
void initCAN_1 (void) /*初始化CAN_1*/
uint8_t i;
CAN_1.MCR.R = 0x5000003F; /* Put in Freeze Mode & enable all 64 msg bufs *//*Module Configuration Register----MCR 模式配置寄存器*/
CAN_1.CR.R = 0x04DB2006; /* Configure for 8MHz OSC, 100KHz bit time *//*Control Register---CR 控制寄存器*/
//0x04DB0006
for (i=0; i<64; i++)
CAN_1.BUF[i].CS.B.CODE = 0; /* Inactivate all message buffers */ /*Message Buffer--64个信息缓冲寄存器*/
/*P433*/
CAN_1.IMRL.B.BUF04M=1;
CAN_1.BUF[4].CS.B.IDE = 0; /* MB 4 will look for a standard ID */ /*IDE=0表示Frame format(帧格式) is standard*/
CAN_1.BUF[4].ID.B.STD_ID = 555; /* MB 4 will look for ID = 555 */ /*ID(帧标识符)*/
CAN_1.BUF[4].CS.B.CODE = 4; /* MB 4 set to RX EMPTY */ /*CODE=0x0100表示EMPTY: MB is active and empty.*/
// CAN_1.RXGMASK.R = 0x1FFFFF10; /* Global acceptance mask */ /*Rx Global Mask Register---RXGMASK*/
SIU.PCR[42].R = 0x0624; /* MPC56xxB: Config port C10 as CAN1TX, open drain */
SIU.PCR[35].R = 0x0103; /* MPC56xxB: Configure port C3 as CAN1RX */ /*CAN_1的收发送*/
SIU.PSMI[0].R = 0x00; /* MPC56xxB: Select PCR 35 for CAN1RX Input */ /*P346*//*因为可以作为CAN1Rx的引脚有三个(PC3 PC11 PF15)这里选择PC3以后,要注释 SIU.PSMI[0].R = 0x00;表明选择的是PC3*/
CAN_1.MCR.R = 0x0000003F; /* Negate FlexCAN 1 halt state for 64 MB */
void initCAN_0 (void) /*初始化CAN_0*/
uint8_t i;
CAN_0.MCR.R = 0x5000003F; /* Put in Freeze Mode & enable all 64 msg bufs */ /*Freeze Mode(It is enabled when the FRZ bit in the MCR is asserted.)*/
CAN_0.CR.R = 0x04DB0006; /* Configure for 8MHz OSC, 100KHz bit time */
/*怎么配置波特率*/
CAN_0.BUF[i].CS.B.CODE = 0; /* Inactivate all message buffers */
CAN_0.IMRL.B.BUF00M=1;
CAN_0.BUF[0].CS.B.IDE = 0; /* Use standard ID length */ /*IDE=0表示Frame format(帧格式) is standard*/
CAN_0.BUF[0].ID.B.STD_ID = 555; /* Transmit ID is 555 */ /*ID(帧标识符)*/
CAN_0.BUF[0].CS.B.RTR = 0; /* Data frame, not remote Tx request frame */ /*RTR=0表示Indicates the current MB has a Data Frame to be transmitted(表明当前信息缓冲寄存器将要发送)*/ /*RTR=Remote Transmission Request(远程发送请求)*/
// CAN_0.RXGMASK.R = 0x1FFFFFFF;
CAN_0.BUF[0].CS.B.CODE = 8; /* Message Buffer 0 set to TX INACTIVE */ /*CODE=0x1000表示INACTIVE: MB does not participate in the arbitration process.*/
SIU.PCR[16].R = 0x0624; /* MPC56xxB: Config port B0 as CAN0TX, open drain */
SIU.PCR[17].R = 0x0103; /* MPC56xxB: Configure port B1 as CAN0RX */ /*CAN_0的收发送*/
CAN_0.MCR.R = 0x0000003F; /* Negate FlexCAN 0 halt state for 64 MB */
/*发送端配置相对简单(或许在信息发送函数中进行了设置),只对TX设置为Inactive,而接收端设置比较复杂,比如帧和MB的设置*/
void TransmitMsg (void) /*发送信息函数*/
uint8_t i;
/* Assumption: Message buffer CODE is INACTIVE */
const uint8_t TxData[] = {"Hello"}; /* Transmit string*/
CAN_0.BUF[0].CS.B.LENGTH = sizeof(TxData) -1 ; /* # bytes to transmit w/o null */
for (i=0; i<sizeof(TxData); i++)
CAN_0.BUF[0].DATA.B[i] = TxData[i]; /* Data to be transmitted */ /*DATA表示数据段*/
CAN_0.BUF[0].CS.B.SRR = 1; /* Tx frame (not req'd for standard frame)*/ /*SRR=1表示 Recessive value is compulsory for transmission in Extended Format frames(在扩展帧格式下隐形值被强制发送)*/
CAN_0.BUF[0].CS.B.CODE =0xC; /* Activate msg. buf. to transmit data frame */ /*RTR=0且CODE=1时Transmit data frame unconditionally once. After transmission, the
MB automatically returns to the INACTIVE state.(发送结束后,MB自动返回到非活跃状态)*/
/*发送CAN_0选择缓冲寄存器BUF[0],接收CAN_1选择缓冲寄存器BUF[1]*/
void RecieveMsg (void) /*接收信息函数*/
uint8_t j;
uint32_t dummy;
while (CAN_1.IFRL.B.BUF04I == 0) {}; /* Wait for CAN 1 MB 4 flag */ /*等待标志位*/
RxCODE = CAN_1.BUF[4].CS.B.CODE; /* Read CODE, ID, LENGTH, DATA, TIMESTAMP(读取CAN_1的CODE和ID以及Length,Data,Timestamp等参数) */
RxID = CAN_1.BUF[4].ID.B.STD_ID;
RxLENGTH = CAN_1.BUF[4].CS.B.LENGTH;
for (j=0; j<RxLENGTH; j++)
RxDATA[j] = CAN_1.BUF[4].DATA.B[j];
RxTIMESTAMP = CAN_1.BUF[4].CS.B.TIMESTAMP;
dummy = CAN_1.TIMER.R; /* Read TIMER to unlock message buffers */
CAN_1.IFRL.R = 0x00000010; /* Clear CAN 1 MB 4 flag */
//void delay_ms(int x)
// int a,b;
// for(a=x;a>0;a--)
// for(b=16000;b>0;b--) ;
void main(void)
volatile uint32_t IdleCtr = 0;
// delay_ms(1000);
initModesAndClks(); /* Initialize mode entries */
initPeriClkGen(); /* Initialize peripheral clock generation for DSPIs */
disableWatchdog(); /* Disable watchdog */
initCAN_1(); /* Initialize FLEXCAN 1 & one of its buffers for receive*/
initCAN_0(); /* Initialize FlexCAN 0 & one of its buffers for transmit*/
// TransmitMsg(); /* Transmit one message from a FlexCAN 0 buffer */
// RecieveMsg(); /* Wait for the message to be recieved at FlexCAN 1 */
while (1)
IdleCtr++; /* Idle loop: increment counter */
这个是在找的例程的基础上有部分我修改了,在网上看到帖子说配SBC,不明白什么意思,请前辈给予指点
CAN模块原理图
