在线时间447 小时
UID3070798
注册时间2015-4-27
NXP金币0
TA的每日心情 | 开心 2020-5-24 10:39 |
- 3913
- 2020-5-24
先祝大家中秋快乐
接上一篇:每天解决一个问题34:谈K60时钟(2) - 飞思卡尔江湖 - 飞思卡尔技术社区 https://www.nxpic.org.cn/modul ... 1&extra=#pid2153171
时钟如何由FEI模式进入PEE模式?怎么转换呢?参考如下程序
- 1. unsigned char pll_init(unsigned char clk_option, unsigned char crystal_val)
- 2. {
- 3. unsigned char pll_freq;
- 4.
- 5. if (clk_option > 3) {return 0;} //return 0 if one of the available options is not selected
- 6. if (crystal_val > 15) {return 1;} // return 1 if one of the available crystal options is not available
- 7. //This assumes that the MCG is in default FEI mode out of reset.
- 8.
- 9. // First move to FBE mode
- 10. #if (defined(K60_CLK) || defined(ASB817))
- 11. MCG_C2 = 0;
- 12. #else
- 13. // Enable external oscillator, RANGE=2, HGO=1, EREFS=1, LP=0, IRCS=0
- 14. MCG_C2 = MCG_C2_RANGE(2) | MCG_C2_HGO_MASK | MCG_C2_EREFS_MASK;
- 15. #endif
- 16.
- 17. // after initialization of oscillator release latched state of oscillator and GPIO
- 18. SIM_SCGC4 |= SIM_SCGC4_LLWU_MASK;
- 19. LLWU_CS |= LLWU_CS_ACKISO_MASK;
- 20.
- 21. // Select external oscilator and Reference Divider and clear IREFS to start ext osc
- 22. // CLKS=2, FRDIV=3, IREFS=0, IRCLKEN=0, IREFSTEN=0
- 23. MCG_C1 = MCG_C1_CLKS(2) | MCG_C1_FRDIV(3);
- 24.
- 25. /* if we aren't using an osc input we don't need to wait for the osc to init */
- 26. #if (!defined(K60_CLK) && !defined(ASB817))
- 27. while (!(MCG_S & MCG_S_OSCINIT_MASK)){}; // wait for oscillator to initialize
- 28. #endif
- 29.
- 30. while (MCG_S & MCG_S_IREFST_MASK){}; // wait for Reference clock Status bit to clear
- 31.
- 32. while (((MCG_S & MCG_S_CLKST_MASK) >> MCG_S_CLKST_SHIFT) != 0x2){}; // Wait for clock status bits to show clock source is ext ref clk
- 33.
- 34. // Now in FBE
- 35.
- 36. #if (defined(K60_CLK))
- 37. //MCG_C5 = MCG_C5_PRDIV(0x18);
- 38. MCG_C5 = MCG_C5_PRDIV(0x18); //基频2M 外部时钟源是50M时, 50/25=2M
- 39. #else
- 40. // Configure PLL Ref Divider, PLLCLKEN=0, PLLSTEN=0, PRDIV=5
- 41. // The crystal frequency is used to select the PRDIV value. Only even frequency crystals are supported
- 42. // that will produce a 2MHz reference clock to the PLL.
- 43. MCG_C5 = MCG_C5_PRDIV(crystal_val); // Set PLL ref divider to match the crystal used
- 44. #endif
- 45.
- 46. // Ensure MCG_C6 is at the reset default of 0. LOLIE disabled, PLL disabled, clk monitor disabled, PLL VCO divider is clear
- 47. MCG_C6 = 0x0;
- 48. // Select the PLL VCO divider and system clock dividers depending on clocking option
- 49. switch (clk_option) {
- 50. case 0:
- 51. // Set system options dividers
- 52. //MCG=PLL, core = MCG, bus = MCG, FlexBus = MCG, Flash clock= MCG/2
- 53. set_sys_dividers(0,0,0,1);
- 54. // Set the VCO divider and enable the PLL for 50MHz, LOLIE=0, PLLS=1, CME=0, VDIV=1
- 55. MCG_C6 = MCG_C6_PLLS_MASK | MCG_C6_VDIV(1); //VDIV = 1 (x25)
- 56. pll_freq = 50;
- 57. break;
- 58. case 1:
- 59. // Set system options dividers
- 60. //MCG=PLL, core = MCG, bus = MCG/2, FlexBus = MCG/2, Flash clock= MCG/4
- 61. set_sys_dividers(0,1,1,3);
- 62. // Set the VCO divider and enable the PLL for 100MHz, LOLIE=0, PLLS=1, CME=0, VDIV=26
- 63. MCG_C6 = MCG_C6_PLLS_MASK | MCG_C6_VDIV(26); //VDIV = 26 (x50)
- 64. pll_freq = 100;
- 65. break;
- 66. case 2:
- 67. // Set system options dividers
- 68. //MCG=PLL, core = MCG, bus = MCG/2, FlexBus = MCG/2, Flash clock= MCG/4
- 69. set_sys_dividers(0,1,1,3);
- 70. // Set the VCO divider and enable the PLL for 96MHz, LOLIE=0, PLLS=1, CME=0, VDIV=24
- 71. MCG_C6 = MCG_C6_PLLS_MASK | MCG_C6_VDIV(24); //VDIV = 24 (x48)
- 72. pll_freq = 96;
- 73. break;
- 74. case 3:
- 75. // Set system options dividers
- 76. //MCG=PLL, core = MCG, bus = MCG, FlexBus = MCG, Flash clock= MCG/2
- 77. set_sys_dividers(0,0,0,1);
- 78. // Set the VCO divider and enable the PLL for 48MHz, LOLIE=0, PLLS=1, CME=0, VDIV=0
- 79. MCG_C6 = MCG_C6_PLLS_MASK; //VDIV = 0 (x24)
- 80. pll_freq = 48;
- 81. break;
- 82. }
- 83. while (!(MCG_S & MCG_S_PLLST_MASK)){}; // wait for PLL status bit to set
- 84.
- 85. while (!(MCG_S & MCG_S_LOCK_MASK)){}; // Wait for LOCK bit to set
- 86.
- 87. // Now running PBE Mode
- 88.
- 89. // Transition into PEE by setting CLKS to 0
- 90. // CLKS=0, FRDIV=3, IREFS=0, IRCLKEN=0, IREFSTEN=0
- 91. MCG_C1 &= ~MCG_C1_CLKS_MASK;
- 92.
- 93. // Wait for clock status bits to update
- 94. while (((MCG_S & MCG_S_CLKST_MASK) >> MCG_S_CLKST_SHIFT) != 0x3){};
- 95.
- 96. // Now running PEE Mode
- 97.
- 98. return pll_freq;
- 99. } //pll_init
