查看: 2284|回复: 5
[其他] 每天一个问题35天3问 :wav信息的读取
    发表于 2015-9-28 22:17:05 | 显示全部楼层 |阅读模式
    一、问题提出:
    之前给大家分享了定义一个结构体来存储wav文件的信息,那如何编程实现呢?
    二、解决办法:
    1、有了前面的结构体变量,程序就容易实现了。
    2、今天调试了一个程序,给大家分享一下:
    这个函数返回值为0时,表示读取信息错误,为1时,表示读取正确
    参数时指向内存中的wav文件信息的片段,可以时数据缓冲区。wavPoint指向wav文件的开始。
    uint8_t ReadWAVInf(uint8_t * wavPoint)
            if (0 == strcompare("RIFF", (uint8_t *)wavPoint, 4))
                    return 0;
            else
                    strncpy(wavFile.wavRiffChunk.szRiffID, (uint8_t *)wavPoint, 4);
            if (0 == strcompare("WAVE", (uint8_t *)wavPoint + 8, 4))
                    return 0;
            else
                    strncpy(wavFile.wavRiffChunk.szRiffFormat, wavPoint + 8, 4);
            wavFile.wavRiffChunk.dwRiffSize = ((uint32_t)*(wavPoint + 4)) +
        (((uint32_t)*(wavPoint + 5)) << 8) +
        (((uint32_t)*(wavPoint + 6)) << 16) +
        (((uint32_t)*(wavPoint + 7)) << 24);
            wavPoint += 12;
            if (0 == strcompare("fmt ", (uint8_t *)wavPoint, 4))
                    return 0;
            else
                    strncpy(wavFile.wavFmtChunk.szFmtID, (uint8_t *)wavPoint, 4);
            wavFile.wavFmtChunk.dwFmtSize = ((uint32_t)*(wavPoint + 4)) +
            wavFile.wavFmtChunk.wavFormat.wFormatTag = ((uint32_t)*(wavPoint + 8)) +
        (((uint32_t)*(wavPoint + 9)) << 8);
            wavFile.wavFmtChunk.wavFormat.wChannels = ((uint32_t)*(wavPoint + 10)) +
        (((uint32_t)*(wavPoint + 11)) << 8);
            wavFile.wavFmtChunk.wavFormat.dwSamplesPerSec = ((uint32_t)*(wavPoint + 12)) +
        (((uint32_t)*(wavPoint + 13)) << 8) +
        (((uint32_t)*(wavPoint + 14)) << 16) +
        (((uint32_t)*(wavPoint + 15)) << 24);
            wavFile.wavFmtChunk.wavFormat.dwAvgBytesPerSec = ((uint32_t)*(wavPoint + 16)) +
        (((uint32_t)*(wavPoint + 17)) << 8) +
        (((uint32_t)*(wavPoint + 18)) << 16) +
        (((uint32_t)*(wavPoint + 19)) << 24);
            wavFile.wavFmtChunk.wavFormat.wBlockAlign = ((uint32_t)*(wavPoint + 20)) +
        (((uint32_t)*(wavPoint + 21)) << 8);
            wavFile.wavFmtChunk.wavFormat.wBitsPerSample = ((uint32_t)*(wavPoint + 22)) +
        (((uint32_t)*(wavPoint + 23)) << 8);
            wavPoint += wavFile.wavFmtChunk.dwFmtSize + 8;
            while (0 == strcompare("data", (uint8_t *)wavPoint, 4))
                    wavPoint += ((uint32_t)*(wavPoint + 4)) +
                                            (((uint32_t)*(wavPoint + 7)) << 24) + 8;
            strncpy(wavFile.wavDataChunk.szDataID, (uint8_t *)wavPoint, 4);
            wavFile.wavDataChunk.dwDataSize = ((uint32_t)*(wavPoint + 4)) +
            return 1;
    三、感想与收获:
    1、有了这个程序,就可以实现wav信息读取了,为下一步wav的播放提供了基础。
    我知道答案 目前已有5人回答
    发表于 2015-9-28 23:31:40 | 显示全部楼层
    原创的么 好厉害
     楼主| 发表于 2015-9-29 09:55:43 | 显示全部楼层
    自己按照格式写的,多谢支持
    发表于 2015-9-29 09:57:50 | 显示全部楼层
    lkl0305 发表于 2015-9-29 09:55
    自己按照格式写的,多谢支持
    按照格式?是在网上查到的wav格式嘛
     楼主| 发表于 2015-9-29 10:01:18 | 显示全部楼层
    发表于 2015-10-22 13:39:54 | 显示全部楼层
    感谢楼主分享
    GMT+8, 2025-11-4 18:05 , Processed in 0.095989 second(s), 27 queries , MemCache On.
