查看: 1324|回复: 0
[求助] Kgdbwait into wait state, but GDB timeout, can not connect
发表于 2015-10-20 10:20:23 | 显示全部楼层 |阅读模式
on i.mx6 dual
~# echo g > /proc/sysrq-trigger work good
but  Kgdbwait into wait state, but GDB can not connect
of course I exit the mincom~ also try to use
git://git.kernel.org/pub/scm/utils/kernel/kgdb/agent-proxy.git
still can not work
/////gdb message
174,060 &"symbol-file /root/project_board/free_imx/out/matrix_io/kernel/vmlinux\n"
174,060 ~"Reading symbols from /root/project_board/free_imx/out/matrix_io/kernel/vmlinux..."
174,118 12-list-thread-groups
175,042 ~"done.\n"
175,044 11^done
175,044 (gdb)
175,044 &"\n"
175,045 ^done
175,045 (gdb)
175,045 12^done,groups=[{id="i1",type="process"}]
175,045 (gdb)
175,046 13-target-select remote /dev/ttyUSB0
196,053 ~"Ignoring packet error, continuing...\n"
196,053 &"warning: unrecognized item \"timeout\" in \"qSupported\" response\n"
/////bootargs message
boot
booti mmc1
kernel   @ 14008000 (9372264)
ramdisk  @ 15000000 (507162)
fdt      @ 14f00000 (55103)
kernel cmdline:
    use boot.img command line:
    kgdboc=ttymxc0,115200 kgdbwait init=/init video=mxcfb0:dev=ldb,bpp=32 video=mxcfb1:dev=hdmi,1920x1080M@60,if=RGB24,bpp=32 video=mxcfb2ff video=mxcfb3ff vmalloc=400M androidboot.console=ttymxc0 consoleblank=0 androidboot.hardware=freescale cma=384M mem=1G
switch to ldo_bypass mode!
   Using Device Tree in place at 14f00000, end 14f1073e
Starting kernel ...
/////kernel boot message
2.336547] calling  sched_clock_syscore_init+0x0/0x24 @ 1
[    2.336580] initcall sched_clock_syscore_init+0x0/0x24 returned 0 after 2 usecs
[    2.336596] Doing 0
[    2.336623] calling  register_pmu_driver+0x0/0x6c @ 1
[    2.336974] hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
[    2.338491] initcall register_pmu_driver+0x0/0x6c returned 0 after 1789 usecs
[    2.338512] Doing 1
[    2.338542] calling  mxc_epit_driver_init+0x0/0x24 @ 1
[    2.339437] initcall mxc_epit_driver_init+0x0/0x24 returned 0 after 843 usecs
[    2.339458] Doing 2
[    2.339485] calling  ldo2p5_dummy_driver_init+0x0/0x24 @ 1
[    2.340766] initcall ldo2p5_dummy_driver_init+0x0/0x24 returned 0 after 1222 usecs
[    2.340786] Doing 3
[    2.340811] calling  busfreq_init+0x0/0x44 @ 1
[    2.341551] imx6_busfreq busfreq.16: DDR medium rate not supported.
[    2.342400] Bus freq driver module loaded
[    2.342437] initcall busfreq_init+0x0/0x44 returned 0 after 1557 usecs
[    2.342453] Doing 4
[    2.342479] calling  mxc_bt_rfkill_driver_init+0x0/0x24 @ 1
[    2.342991] initcall mxc_bt_rfkill_driver_init+0x0/0x24 returned 0 after 470 usecs
[    2.343009] Doing 5
[    2.343035] calling  mx6_ir_driver_init+0x0/0x24 @ 1
[    2.343503] initcall mx6_ir_driver_init+0x0/0x24 returned 0 after 427 usecs
[    2.343520] Doing 6
[    2.343545] calling  mxc_ramoops_driver_init+0x0/0x24 @ 1
[    2.353513] console [pstore-1] enabled
[    2.353540] ramoops: attached 0x100000@0x4bf00000, ecc: 0/0
[    2.353578] mxc_ramoops device success loaded
[    2.353730] initcall mxc_ramoops_driver_init+0x0/0x24 returned 0 after 9909 usecs
[    2.353752] Doing 7
[    2.353785] calling  proc_execdomains_init+0x0/0x68 @ 1
[    2.353844] initcall proc_execdomains_init+0x0/0x68 returned 0 after 23 usecs
[    2.353862] Doing 8
[    2.353892] calling  ioresources_init+0x0/0xb0 @ 1
[    2.353951] initcall ioresources_init+0x0/0xb0 returned 0 after 26 usecs
[    2.353971] Doing 9
[    2.354000] calling  uid_cache_init+0x0/0x104 @ 1
[    2.354063] initcall uid_cache_init+0x0/0x104 returned 0 after 28 usecs
[    2.354082] Doing 10
[    2.354114] calling  init_posix_timers+0x0/0x538 @ 1
[    2.354242] initcall init_posix_timers+0x0/0x538 returned 0 after 88 usecs
[    2.354342] Doing 11
[    2.354379] calling  init_posix_cpu_timers+0x0/0x200 @ 1
[    2.354418] initcall init_posix_cpu_timers+0x0/0x200 returned 0 after 1 usecs
[    2.354436] Doing 12
[    2.354468] calling  proc_schedstat_init+0x0/0x68 @ 1
[    2.354522] initcall proc_schedstat_init+0x0/0x68 returned 0 after 18 usecs
[    2.354542] Doing 13
[    2.354573] calling  android_power_init+0x0/0x98 @ 1
[    2.354632] initcall android_power_init+0x0/0x98 returned 0 after 24 usecs
[    2.354651] Doing 14
[    2.354684] calling  suspend_time_syscore_init+0x0/0x2c @ 1
[    2.354716] initcall suspend_time_syscore_init+0x0/0x2c returned 0 after 2 usecs
[    2.354735] Doing 15
[    2.354765] calling  timekeeping_init_ops+0x0/0x24 @ 1
[    2.354799] initcall timekeeping_init_ops+0x0/0x24 returned 0 after 1 usecs
[    2.354817] Doing 16
[    2.354847] calling  init_clocksource_sysfs+0x0/0x98 @ 1
[    2.355254] initcall init_clocksource_sysfs+0x0/0x98 returned 0 after 356 usecs
[    2.355277] Doing 17
[    2.355309] calling  init_timer_list_procfs+0x0/0x84 @ 1
[    2.355364] initcall init_timer_list_procfs+0x0/0x84 returned 0 after 15 usecs
[    2.355385] Doing 18
[    2.355416] calling  alarmtimer_init+0x0/0x380 @ 1
[    2.356013] initcall alarmtimer_init+0x0/0x380 returned 0 after 541 usecs
[    2.356037] Doing 19
[    2.356069] calling  init_tstats_procfs+0x0/0x84 @ 1
[    2.356126] initcall init_tstats_procfs+0x0/0x84 returned 0 after 17 usecs
[    2.356147] Doing 20
[    2.356175] calling  futex_init+0x0/0x214 @ 1
[    2.356351] futex hash table entries: 512 (order: 3, 32768 bytes)
[    2.356441] initcall futex_init+0x0/0x214 returned 0 after 219 usecs
[    2.356460] Doing 21
[    2.356489] calling  proc_modules_init+0x0/0x68 @ 1
[    2.356539] initcall proc_modules_init+0x0/0x68 returned 0 after 17 usecs
[    2.356560] Doing 22
[    2.356586] calling  kallsyms_init+0x0/0x68 @ 1
[    2.356628] initcall kallsyms_init+0x0/0x68 returned 0 after 13 usecs
[    2.356650] Doing 23
[    2.356676] calling  audit_init+0x0/0x2ac @ 1
[    2.356697] audit: initializing netlink socket (disabled)
[    2.356786] type=2000 audit(2.270:1): initialized
[    2.356832] initcall audit_init+0x0/0x2ac returned 0 after 120 usecs
[    2.356850] Doing 24
[    2.356877] calling  audit_watch_init+0x0/0x80 @ 1
[    2.356913] initcall audit_watch_init+0x0/0x80 returned 0 after 7 usecs
[    2.356930] Doing 25
[    2.356955] calling  audit_tree_init+0x0/0xc4 @ 1
[    2.356991] initcall audit_tree_init+0x0/0xc4 returned 0 after 7 usecs
[    2.357010] Doing 26
[    2.357035] calling  init_kprobes+0x0/0x1cc @ 1
[    2.794178] initcall init_kprobes+0x0/0x1cc returned 0 after 426854 usecs
[    2.794209] Doing 27
[    2.794238] calling  irq_gc_init_ops+0x0/0x24 @ 1
[    2.794321] initcall irq_gc_init_ops+0x0/0x24 returned 0 after 1 usecs
[    2.794343] Doing 28
[    2.794370] calling  irq_pm_init_ops+0x0/0x24 @ 1
[    2.794401] initcall irq_pm_init_ops+0x0/0x24 returned 0 after 1 usecs
[    2.794419] Doing 29
[    2.794448] calling  utsname_sysctl_init+0x0/0x24 @ 1
[    2.794526] initcall utsname_sysctl_init+0x0/0x24 returned 0 after 45 usecs
[    2.794547] Doing 30
[    2.794582] calling  init_tracepoints+0x0/0x2c @ 1
[    2.794615] initcall init_tracepoints+0x0/0x2c returned 0 after 1 usecs
[    2.794634] Doing 31
[    2.794661] calling  stack_trace_init+0x0/0xf8 @ 1
[    2.794777] initcall stack_trace_init+0x0/0xf8 returned 0 after 80 usecs
[    2.794800] Doing 32
[    2.794832] calling  irq_work_init_cpu_notifier+0x0/0x48 @ 1
[    2.794872] initcall irq_work_init_cpu_notifier+0x0/0x48 returned 0 after 7 usecs
[    2.794890] Doing 33
[    2.794917] calling  perf_event_sysfs_init+0x0/0x148 @ 1
[    2.795692] initcall perf_event_sysfs_init+0x0/0x148 returned 0 after 718 usecs
[    2.795719] Doing 34
[    2.795752] calling  init_per_zone_wmark_min+0x0/0xac @ 1
[    2.797220] initcall init_per_zone_wmark_min+0x0/0xac returned 0 after 1392 usecs
[    2.797247] Doing 35
[    2.797281] calling  kswapd_init+0x0/0x58 @ 1
[    2.797913] initcall kswapd_init+0x0/0x58 returned 0 after 575 usecs
[    2.797940] Doing 36
[    2.797970] calling  extfrag_debug_init+0x0/0xc4 @ 1
[    2.798081] initcall extfrag_debug_init+0x0/0xc4 returned 0 after 75 usecs
[    2.798105] Doing 37
[    2.798139] calling  setup_vmstat+0x0/0x1c8 @ 1
[    2.798244] initcall setup_vmstat+0x0/0x1c8 returned 0 after 69 usecs
[    2.798265] Doing 38
[    2.798293] calling  mm_sysfs_init+0x0/0x60 @ 1
[    2.798352] initcall mm_sysfs_init+0x0/0x60 returned 0 after 26 usecs
[    2.798372] Doing 39
[    2.798404] calling  init_reserve_notifier+0x0/0x30 @ 1
[    2.798437] initcall init_reserve_notifier+0x0/0x30 returned 0 after 1 usecs
[    2.798454] Doing 40
[    2.798486] calling  init_admin_reserve+0x0/0xac @ 1
[    2.798518] initcall init_admin_reserve+0x0/0xac returned 0 after 2 usecs
[    2.798536] Doing 41
[    2.798562] calling  init_user_reserve+0x0/0xac @ 1
[    2.798596] initcall init_user_reserve+0x0/0xac returned 0 after 1 usecs
[    2.798613] Doing 42
[    2.798643] calling  proc_vmalloc_init+0x0/0x68 @ 1
[    2.798693] initcall proc_vmalloc_init+0x0/0x68 returned 0 after 15 usecs
[    2.798712] Doing 43
[    2.798743] calling  memblock_init_debugfs+0x0/0x98 @ 1
[    2.798845] initcall memblock_init_debugfs+0x0/0x98 returned 0 after 63 usecs
[    2.798864] Doing 44
[    2.798895] calling  init_emergency_pool+0x0/0xbc @ 1
[    2.798930] initcall init_emergency_pool+0x0/0xbc returned 0 after 2 usecs
[    2.798950] Doing 45
[    2.798980] calling  procswaps_init+0x0/0x68 @ 1
[    2.799029] initcall procswaps_init+0x0/0x68 returned 0 after 15 usecs
[    2.799049] Doing 46
[    2.799076] calling  ksm_init+0x0/0x11c @ 1
[    2.799455] initcall ksm_init+0x0/0x11c returned 0 after 327 usecs
[    2.799476] Doing 47
[    2.799510] calling  slab_sysfs_init+0x0/0x1c4 @ 1
[    2.809432] initcall slab_sysfs_init+0x0/0x1c4 returned 0 after 9642 usecs
[    2.809456] Doing 48
[    2.809488] calling  fcntl_init+0x0/0x50 @ 1
[    2.809549] initcall fcntl_init+0x0/0x50 returned 0 after 25 usecs
[    2.809570] Doing 49
[    2.809597] calling  proc_filesystems_init+0x0/0x68 @ 1
[    2.809652] initcall proc_filesystems_init+0x0/0x68 returned 0 after 21 usecs
[    2.809673] Doing 50
[    2.809701] calling  dio_init+0x0/0x50 @ 1
[    2.809997] initcall dio_init+0x0/0x50 returned 0 after 258 usecs
[    2.810017] Doing 51
[    2.810045] calling  fsnotify_mark_init+0x0/0x9c @ 1
[    2.810330] initcall fsnotify_mark_init+0x0/0x9c returned 0 after 242 usecs
[    2.810353] Doing 52
[    2.810378] calling  dnotify_init+0x0/0xd0 @ 1
[    2.810753] initcall dnotify_init+0x0/0xd0 returned 0 after 330 usecs
[    2.810774] Doing 53
[    2.810804] calling  inotify_user_setup+0x0/0xb0 @ 1
[    2.810874] initcall inotify_user_setup+0x0/0xb0 returned 0 after 39 usecs
[    2.810896] Doing 54
[    2.810920] calling  aio_setup+0x0/0x8c @ 1
[    2.810993] initcall aio_setup+0x0/0x8c returned 0 after 41 usecs
[    2.811012] Doing 55
[    2.811040] calling  proc_locks_init+0x0/0x68 @ 1
[    2.811091] initcall proc_locks_init+0x0/0x68 returned 0 after 20 usecs
[    2.811110] Doing 56
[    2.811136] calling  init_mbcache+0x0/0x24 @ 1
[    2.811172] initcall init_mbcache+0x0/0x24 returned 0 after 5 usecs
[    2.811189] Doing 57
[    2.811214] calling  dquot_init+0x0/0x248 @ 1
[    2.811234] VFS: Disk quotas dquot_6.5.2
[    2.812017] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    2.812056] initcall dquot_init+0x0/0x248 returned 0 after 791 usecs
[    2.812075] Doing 58
[    2.812100] calling  quota_init+0x0/0x58 @ 1
[    2.812174] initcall quota_init+0x0/0x58 returned 0 after 41 usecs
[    2.812195] Doing 59
[    2.812221] calling  proc_cmdline_init+0x0/0x68 @ 1
[    2.812271] initcall proc_cmdline_init+0x0/0x68 returned 0 after 17 usecs
[    2.812290] Doing 60
[    2.812317] calling  proc_consoles_init+0x0/0x68 @ 1
[    2.812361] initcall proc_consoles_init+0x0/0x68 returned 0 after 14 usecs
[    2.812381] Doing 61
[    2.812408] calling  proc_cpuinfo_init+0x0/0x68 @ 1
[    2.812452] initcall proc_cpuinfo_init+0x0/0x68 returned 0 after 14 usecs
[    2.812471] Doing 62
[    2.812497] calling  proc_devices_init+0x0/0x68 @ 1
[    2.812542] initcall proc_devices_init+0x0/0x68 returned 0 after 13 usecs
[    2.812562] Doing 63
[    2.812588] calling  proc_interrupts_init+0x0/0x68 @ 1
[    2.812632] initcall proc_interrupts_init+0x0/0x68 returned 0 after 13 usecs
[    2.812651] Doing 64
[    2.812678] calling  proc_loadavg_init+0x0/0x68 @ 1
[    2.812723] initcall proc_loadavg_init+0x0/0x68 returned 0 after 14 usecs
[    2.812744] Doing 65
[    2.812769] calling  proc_meminfo_init+0x0/0x68 @ 1
[    2.812816] initcall proc_meminfo_init+0x0/0x68 returned 0 after 14 usecs
[    2.812836] Doing 66
[    2.812864] calling  proc_stat_init+0x0/0x68 @ 1
[    2.812943] initcall proc_stat_init+0x0/0x68 returned 0 after 45 usecs
[    2.812963] Doing 67
[    2.812991] calling  proc_uptime_init+0x0/0x68 @ 1
[    2.813038] initcall proc_uptime_init+0x0/0x68 returned 0 after 14 usecs
[    2.813058] Doing 68
[    2.813086] calling  proc_version_init+0x0/0x68 @ 1
[    2.813133] initcall proc_version_init+0x0/0x68 returned 0 after 14 usecs
[    2.813151] Doing 69
[    2.813179] calling  proc_softirqs_init+0x0/0x68 @ 1
[    2.813224] initcall proc_softirqs_init+0x0/0x68 returned 0 after 14 usecs
[    2.813243] Doing 70
[    2.813270] calling  proc_kmsg_init+0x0/0x68 @ 1
[    2.813317] initcall proc_kmsg_init+0x0/0x68 returned 0 after 14 usecs
[    2.813336] Doing 71
[    2.813361] calling  proc_page_init+0x0/0xb0 @ 1
[    2.813419] initcall proc_page_init+0x0/0xb0 returned 0 after 27 usecs
[    2.813438] Doing 72
[    2.813463] calling  configfs_init+0x0/0x148 @ 1
[    2.814148] initcall configfs_init+0x0/0x148 returned 0 after 632 usecs
[    2.814170] Doing 73
[    2.814199] calling  init_devpts_fs+0x0/0xc0 @ 1
[    2.814753] initcall init_devpts_fs+0x0/0xc0 returned 0 after 504 usecs
[    2.814776] Doing 74
[    2.814807] calling  init_ext3_fs+0x0/0x88 @ 1
[    2.815359] initcall init_ext3_fs+0x0/0x88 returned 0 after 504 usecs
[    2.815381] Doing 75
[    2.815410] calling  init_ext2_fs+0x0/0x88 @ 1
[    2.815691] initcall init_ext2_fs+0x0/0x88 returned 0 after 243 usecs
[    2.815714] Doing 76
[    2.815748] calling  ext4_init_fs+0x0/0x298 @ 1
[    2.817225] initcall ext4_init_fs+0x0/0x298 returned 0 after 1402 usecs
[    2.817248] Doing 77
[    2.817281] calling  journal_init+0x0/0x38 @ 1
[    2.817873] initcall journal_init+0x0/0x38 returned 0 after 540 usecs
[    2.817897] Doing 78
[    2.817927] calling  journal_init+0x0/0x40 @ 1
[    2.818087] initcall journal_init+0x0/0x40 returned 0 after 121 usecs
[    2.818107] Doing 79
[    2.818137] calling  init_ramfs_fs+0x0/0x24 @ 1
[    2.818178] initcall init_ramfs_fs+0x0/0x24 returned 0 after 8 usecs
[    2.818196] Doing 80
[    2.818223] calling  init_fat_fs+0x0/0x60 @ 1
[    2.818723] initcall init_fat_fs+0x0/0x60 returned 0 after 452 usecs
[    2.818745] Doing 81
[    2.818774] calling  init_vfat_fs+0x0/0x24 @ 1
[    2.818814] initcall init_vfat_fs+0x0/0x24 returned 0 after 8 usecs
[    2.818833] Doing 82
[    2.818861] calling  init_msdos_fs+0x0/0x24 @ 1
[    2.818901] initcall init_msdos_fs+0x0/0x24 returned 0 after 7 usecs
[    2.818919] Doing 83
[    2.818949] calling  init_iso9660_fs+0x0/0x88 @ 1
[    2.819495] initcall init_iso9660_fs+0x0/0x88 returned 0 after 487 usecs
[    2.819516] Doing 84
[    2.819547] calling  init_nfs_fs+0x0/0x1b0 @ 1
[    2.821193] initcall init_nfs_fs+0x0/0x1b0 returned 0 after 1562 usecs
[    2.821219] Doing 85
[    2.821249] calling  init_nfs_v2+0x0/0x24 @ 1
[    2.821285] initcall init_nfs_v2+0x0/0x24 returned 0 after 2 usecs
[    2.821304] Doing 86
[    2.821332] calling  init_nfs_v3+0x0/0x24 @ 1
[    2.821365] initcall init_nfs_v3+0x0/0x24 returned 0 after 2 usecs
[    2.821384] Doing 87
[    2.821411] calling  init_nfs_v4+0x0/0x6c @ 1
[    2.821432] NFS: Registering the id_resolver key type
[    2.821530] Key type id_resolver registered
[    2.821558] Key type id_legacy registered
[    2.821624] initcall init_nfs_v4+0x0/0x6c returned 0 after 172 usecs
[    2.821645] Doing 88
[    2.821674] calling  init_nlm+0x0/0x9c @ 1
[    2.821756] initcall init_nlm+0x0/0x9c returned 0 after 46 usecs
[    2.821777] Doing 89
[    2.821808] calling  init_nls_cp437+0x0/0x24 @ 1
[    2.821842] initcall init_nls_cp437+0x0/0x24 returned 0 after 2 usecs
[    2.821861] Doing 90
[    2.821890] calling  init_nls_ascii+0x0/0x24 @ 1
[    2.821925] initcall init_nls_ascii+0x0/0x24 returned 0 after 2 usecs
[    2.821943] Doing 91
[    2.821972] calling  init_nls_iso8859_1+0x0/0x24 @ 1
[    2.822007] initcall init_nls_iso8859_1+0x0/0x24 returned 0 after 2 usecs
[    2.822025] Doing 92
[    2.822054] calling  init_nls_iso8859_15+0x0/0x24 @ 1
[    2.822089] initcall init_nls_iso8859_15+0x0/0x24 returned 0 after 2 usecs
[    2.822108] Doing 93
[    2.822138] calling  init_nls_utf8+0x0/0x6c @ 1
[    2.822175] initcall init_nls_utf8+0x0/0x6c returned 0 after 6 usecs
[    2.822193] Doing 94
[    2.822220] calling  init_ntfs_fs+0x0/0x32c @ 1
[    2.822239] NTFS driver 2.1.30 [Flags: R/W DEBUG].
[    2.822899] initcall init_ntfs_fs+0x0/0x32c returned 0 after 623 usecs
[    2.822922] Doing 95
[    2.822953] calling  init_jffs2_fs+0x0/0x124 @ 1
[    2.822974] jffs2: version 2.2. (NAND) �© 2001-2006 Red Hat, Inc.
[    2.825337] initcall init_jffs2_fs+0x0/0x124 returned 0 after 2279 usecs
[    2.825365] Doing 96
[    2.825397] calling  init_autofs4_fs+0x0/0x44 @ 1
[    2.825840] initcall init_autofs4_fs+0x0/0x44 returned 0 after 392 usecs
[    2.825864] Doing 97
[    2.825895] calling  fuse_init+0x0/0xf0 @ 1
[    2.825918] fuse init (API version 7.22)
[    2.826833] initcall fuse_init+0x0/0xf0 returned 0 after 875 usecs
[    2.826858] Doing 98
[    2.826887] calling  init_udf_fs+0x0/0x68 @ 1
[    2.827199] initcall init_udf_fs+0x0/0x68 returned 0 after 274 usecs
[    2.827221] Doing 99
[    2.827247] calling  init_pstore_fs+0x0/0xa4 @ 1
[    2.827306] initcall init_pstore_fs+0x0/0xa4 returned 0 after 27 usecs
[    2.827326] Doing 100
[    2.827351] calling  ipc_init+0x0/0x30 @ 1
[    2.827406] msgmni has been set to 1965
[    2.827468] initcall ipc_init+0x0/0x30 returned 0 after 84 usecs
[    2.827487] Doing 101
[    2.827515] calling  ipc_sysctl_init+0x0/0x24 @ 1
[    2.827607] initcall ipc_sysctl_init+0x0/0x24 returned 0 after 58 usecs
[    2.827627] Doing 102
[    2.827654] calling  key_proc_init+0x0/0x88 @ 1
[    2.827703] initcall key_proc_init+0x0/0x88 returned 0 after 19 usecs
[    2.827726] Doing 103
[    2.827753] calling  selinux_nf_ip_init+0x0/0xac @ 1
[    2.827773] SELinux:  Registering netfilter hooks
[    2.827806] initcall selinux_nf_ip_init+0x0/0xac returned 0 after 24 usecs
[    2.827823] Doing 104
[    2.827848] calling  init_sel_fs+0x0/0x150 @ 1
[    2.829091] initcall init_sel_fs+0x0/0x150 returned 0 after 1179 usecs
[    2.829113] Doing 105
[    2.829140] calling  selnl_init+0x0/0xd4 @ 1
[    2.829202] initcall selnl_init+0x0/0xd4 returned 0 after 29 usecs
[    2.829224] Doing 106
[    2.829251] calling  sel_netif_init+0x0/0xcc @ 1
[    2.829295] initcall sel_netif_init+0x0/0xcc returned 0 after 12 usecs
[    2.829314] Doing 107
[    2.829341] calling  sel_netnode_init+0x0/0xf8 @ 1
[    2.829383] initcall sel_netnode_init+0x0/0xf8 returned 0 after 13 usecs
[    2.829402] Doing 108
[    2.829428] calling  sel_netport_init+0x0/0xf8 @ 1
[    2.829471] initcall sel_netport_init+0x0/0xf8 returned 0 after 14 usecs
[    2.829490] Doing 109
[    2.829516] calling  aurule_init+0x0/0x50 @ 1
[    2.829546] initcall aurule_init+0x0/0x50 returned 0 after 3 usecs
[    2.829565] Doing 110
[    2.829590] calling  crypto_algapi_init+0x0/0x1c @ 1
[    2.829647] initcall crypto_algapi_init+0x0/0x1c returned 0 after 24 usecs
[    2.829666] Doing 111
[    2.829692] calling  skcipher_module_init+0x0/0x78 @ 1
[    2.829724] initcall skcipher_module_init+0x0/0x78 returned 0 after 1 usecs
[    2.829742] Doing 112
[    2.829768] calling  chainiv_module_init+0x0/0x24 @ 1
[    2.829803] initcall chainiv_module_init+0x0/0x24 returned 0 after 6 usecs
[    2.829822] Doing 113
[    2.829847] calling  eseqiv_module_init+0x0/0x24 @ 1
[    2.829879] initcall eseqiv_module_init+0x0/0x24 returned 0 after 3 usecs
[    2.829898] Doing 114
[    2.829923] calling  seqiv_module_init+0x0/0x24 @ 1
[    2.829958] initcall seqiv_module_init+0x0/0x24 returned 0 after 4 usecs
[    2.829975] Doing 115
[    2.830004] calling  crypto_user_init+0x0/0xcc @ 1
[    2.830055] initcall crypto_user_init+0x0/0xcc returned 0 after 20 usecs
[    2.830079] Doing 116
[    2.830106] calling  hmac_module_init+0x0/0x24 @ 1
[    2.830139] initcall hmac_module_init+0x0/0x24 returned 0 after 4 usecs
[    2.830160] Doing 117
[    2.830188] calling  crypto_null_mod_init+0x0/0x88 @ 1
[    2.831507] initcall crypto_null_mod_init+0x0/0x88 returned 0 after 1247 usecs
[    2.831534] Doing 118
[    2.831563] calling  md4_mod_init+0x0/0x24 @ 1
[    2.831849] initcall md4_mod_init+0x0/0x24 returned 0 after 244 usecs
[    2.831872] Doing 119
[    2.831900] calling  md5_mod_init+0x0/0x24 @ 1
[    2.832184] initcall md5_mod_init+0x0/0x24 returned 0 after 242 usecs
[    2.832207] Doing 120
[    2.832234] calling  rmd128_mod_init+0x0/0x24 @ 1
[    2.832513] initcall rmd128_mod_init+0x0/0x24 returned 0 after 237 usecs
[    2.832537] Doing 121
[    2.832564] calling  rmd160_mod_init+0x0/0x24 @ 1
[    2.832846] initcall rmd160_mod_init+0x0/0x24 returned 0 after 240 usecs
[    2.832869] Doing 122
[    2.832898] calling  rmd256_mod_init+0x0/0x24 @ 1
[    2.833176] initcall rmd256_mod_init+0x0/0x24 returned 0 after 238 usecs
[    2.833199] Doing 123
[    2.833226] calling  rmd320_mod_init+0x0/0x24 @ 1
[    2.833503] initcall rmd320_mod_init+0x0/0x24 returned 0 after 234 usecs
[    2.833527] Doing 124
[    2.833554] calling  sha1_generic_mod_init+0x0/0x24 @ 1
[    2.833833] initcall sha1_generic_mod_init+0x0/0x24 returned 0 after 236 usecs
[    2.833860] Doing 125
[    2.833891] calling  sha256_generic_mod_init+0x0/0x28 @ 1
[    2.834564] initcall sha256_generic_mod_init+0x0/0x28 returned 0 after 618 usecs
[    2.834590] Doing 126
[    2.834622] calling  sha512_generic_mod_init+0x0/0x28 @ 1
[    2.835184] initcall sha512_generic_mod_init+0x0/0x28 returned 0 after 512 usecs
[    2.835208] Doing 127
[    2.835235] calling  wp512_mod_init+0x0/0x28 @ 1
[    2.836049] initcall wp512_mod_init+0x0/0x28 returned 0 after 758 usecs
[    2.836073] Doing 128
[    2.836101] calling  tgr192_mod_init+0x0/0x28 @ 1
[    2.836869] initcall tgr192_mod_init+0x0/0x28 returned 0 after 712 usecs
[    2.836894] Doing 129
[    2.836924] calling  crypto_ecb_module_init+0x0/0x24 @ 1
[    2.836962] initcall crypto_ecb_module_init+0x0/0x24 returned 0 after 5 usecs
[    2.836981] Doing 130
[    2.837008] calling  crypto_cbc_module_init+0x0/0x24 @ 1
[    2.837041] initcall crypto_cbc_module_init+0x0/0x24 returned 0 after 3 usecs
[    2.837061] Doing 131
[    2.837088] calling  crypto_cts_module_init+0x0/0x24 @ 1
[    2.837122] initcall crypto_cts_module_init+0x0/0x24 returned 0 after 4 usecs
[    2.837141] Doing 132
[    2.837166] calling  crypto_module_init+0x0/0x24 @ 1
[    2.837198] initcall crypto_module_init+0x0/0x24 returned 0 after 3 usecs
[    2.837219] Doing 133
[    2.837245] calling  crypto_module_init+0x0/0x24 @ 1
[    2.837278] initcall crypto_module_init+0x0/0x24 returned 0 after 4 usecs
[    2.837296] Doing 134
[    2.837321] calling  crypto_ctr_module_init+0x0/0x74 @ 1
[    2.837358] initcall crypto_ctr_module_init+0x0/0x74 returned 0 after 7 usecs
[    2.837376] Doing 135
[    2.837402] calling  crypto_gcm_module_init+0x0/0x14c @ 1
[    2.837451] initcall crypto_gcm_module_init+0x0/0x14c returned 0 after 18 usecs
[    2.837470] Doing 136
[    2.837496] calling  crypto_ccm_module_init+0x0/0xa4 @ 1
[    2.837537] initcall crypto_ccm_module_init+0x0/0xa4 returned 0 after 11 usecs
[    2.837556] Doing 137
[    2.837583] calling  des_generic_mod_init+0x0/0x28 @ 1
[    2.838115] initcall des_generic_mod_init+0x0/0x28 returned 0 after 483 usecs
[    2.838140] Doing 138
[    2.838169] calling  blowfish_mod_init+0x0/0x24 @ 1
[    2.838530] initcall blowfish_mod_init+0x0/0x24 returned 0 after 317 usecs
[    2.838555] Doing 139
[    2.838584] calling  twofish_mod_init+0x0/0x24 @ 1
[    2.838875] initcall twofish_mod_init+0x0/0x24 returned 0 after 244 usecs
[    2.838899] Doing 140
[    2.838926] calling  aes_init+0x0/0x24 @ 1
[    2.839207] initcall aes_init+0x0/0x24 returned 0 after 239 usecs
[    2.839230] Doing 141
[    2.839259] calling  camellia_init+0x0/0x24 @ 1
[    2.839548] initcall camellia_init+0x0/0x24 returned 0 after 246 usecs
[    2.839571] Doing 142
[    2.839599] calling  arc4_init+0x0/0x28 @ 1
[    2.840128] initcall arc4_init+0x0/0x28 returned 0 after 480 usecs
[    2.840152] Doing 143
[    2.840180] calling  deflate_mod_init+0x0/0x24 @ 1
[    2.840463] initcall deflate_mod_init+0x0/0x24 returned 0 after 239 usecs
[    2.840488] Doing 144
[    2.840517] calling  michael_mic_init+0x0/0x24 @ 1
[    2.840804] initcall michael_mic_init+0x0/0x24 returned 0 after 244 usecs
[    2.840828] Doing 145
[    2.840856] calling  crc32c_mod_init+0x0/0x24 @ 1
[    2.841196] initcall crc32c_mod_init+0x0/0x24 returned 0 after 295 usecs
[    2.841219] Doing 146
[    2.841251] calling  crypto_authenc_module_init+0x0/0x24 @ 1
[    2.841291] initcall crypto_authenc_module_init+0x0/0x24 returned 0 after 8 usecs
[    2.841311] Doing 147
[    2.841338] calling  crypto_authenc_esn_module_init+0x0/0x24 @ 1
[    2.841372] initcall crypto_authenc_esn_module_init+0x0/0x24 returned 0 after 3 usecs
[    2.841391] Doing 148
[    2.841416] calling  lzo_mod_init+0x0/0x24 @ 1
[    2.841698] initcall lzo_mod_init+0x0/0x24 returned 0 after 240 usecs
[    2.841723] Doing 149
[    2.841751] calling  krng_mod_init+0x0/0x24 @ 1
[    2.842071] initcall krng_mod_init+0x0/0x24 returned 0 after 276 usecs
[    2.842094] Doing 150
[    2.842123] calling  ghash_mod_init+0x0/0x24 @ 1
[    2.842419] initcall ghash_mod_init+0x0/0x24 returned 0 after 250 usecs
[    2.842442] Doing 151
[    2.842473] calling  proc_genhd_init+0x0/0xb0 @ 1
[    2.842551] initcall proc_genhd_init+0x0/0xb0 returned 0 after 43 usecs
[    2.842573] Doing 152
[    2.842602] calling  noop_init+0x0/0x24 @ 1
[    2.842625] io scheduler noop registered
[    2.842654] initcall noop_init+0x0/0x24 returned 0 after 22 usecs
[    2.842672] Doing 153
[    2.842699] calling  deadline_init+0x0/0x24 @ 1
[    2.842721] io scheduler deadline registered
[    2.842752] initcall deadline_init+0x0/0x24 returned 0 after 23 usecs
[    2.842773] Doing 154
[    2.842798] calling  cfq_init+0x0/0x108 @ 1
[    2.843228] io scheduler cfq registered (default)
[    2.843266] initcall cfq_init+0x0/0x108 returned 0 after 423 usecs
[    2.843286] Doing 155
[    2.843317] calling  libcrc32c_mod_init+0x0/0x84 @ 1
[    2.843371] initcall libcrc32c_mod_init+0x0/0x84 returned 0 after 21 usecs
[    2.843390] Doing 156
[    2.843416] calling  init_kmp+0x0/0x24 @ 1
[    2.843448] initcall init_kmp+0x0/0x24 returned 0 after 2 usecs
[    2.843466] Doing 157
[    2.843492] calling  init_bm+0x0/0x24 @ 1
[    2.843523] initcall init_bm+0x0/0x24 returned 0 after 2 usecs
[    2.843541] Doing 158
[    2.843567] calling  init_fsm+0x0/0x24 @ 1
[    2.843597] initcall init_fsm+0x0/0x24 returned 0 after 2 usecs
[    2.843616] Doing 159
[    2.843644] calling  percpu_counter_startup+0x0/0x28 @ 1
[    2.843682] initcall percpu_counter_startup+0x0/0x28 returned 0 after 7 usecs
[    2.843702] Doing 160
[    2.843729] calling  audit_classes_init+0x0/0x68 @ 1
[    2.843775] initcall audit_classes_init+0x0/0x68 returned 0 after 13 usecs
[    2.843795] Doing 161
[    2.843825] calling  weim_driver_init+0x0/0x24 @ 1
[    2.844472] imx-weim 21b8000.weim: WEIM driver registered.
[    2.844769] initcall weim_driver_init+0x0/0x24 returned 0 after 883 usecs
[    2.844792] Doing 162
[    2.844825] calling  imx_pwm_driver_init+0x0/0x24 @ 1
[    2.846388] initcall imx_pwm_driver_init+0x0/0x24 returned 0 after 1484 usecs
[    2.846411] Doing 163
[    2.846443] calling  pci_proc_init+0x0/0xd4 @ 1
[    2.846551] initcall pci_proc_init+0x0/0xd4 returned 0 after 68 usecs
[    2.846571] Doing 164
[    2.846602] calling  pcie_portdrv_init+0x0/0xb4 @ 1
[    2.847531] initcall pcie_portdrv_init+0x0/0xb4 returned 0 after 868 usecs
[    2.847555] Doing 165
[    2.847587] calling  aer_service_init+0x0/0x50 @ 1
[    2.847854] aer 0000:00:00.0:pcie02: service driver aer loaded
[    2.847948] initcall aer_service_init+0x0/0x50 returned 0 after 318 usecs
[    2.847969] Doing 166
[    2.848002] calling  pcie_pme_service_init+0x0/0x24 @ 1
[    2.848171] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[    2.848212] pcie_pme 0000:00:00.0:pcie01: service driver pcie_pme loaded
[    2.848306] initcall pcie_pme_service_init+0x0/0x24 returned 0 after 258 usecs
[    2.848328] Doing 167
[    2.848358] calling  fb_console_init+0x0/0x114 @ 1
[    2.848559] initcall fb_console_init+0x0/0x114 returned 0 after 162 usecs
[    2.848581] Doing 168
[    2.848615] calling  l4f00242t03_driver_init+0x0/0x24 @ 1
[    2.848714] initcall l4f00242t03_driver_init+0x0/0x24 returned 0 after 63 usecs
[    2.848735] Doing 169
[    2.848765] calling  platform_lcd_driver_init+0x0/0x24 @ 1
[    2.849304] initcall platform_lcd_driver_init+0x0/0x24 returned 0 after 487 usecs
[    2.849327] Doing 170
[    2.849358] calling  genericbl_driver_init+0x0/0x24 @ 1
[    2.849610] initcall genericbl_driver_init+0x0/0x24 returned 0 after 208 usecs
[    2.849632] Doing 171
[    2.849662] calling  pwm_backlight_driver_init+0x0/0x24 @ 1
[    2.851550] imx-pwm 2084000.pwm: pwm enabled
[    2.904465] initcall pwm_backlight_driver_init+0x0/0x24 returned 0 after 53472 usecs
[    2.904492] Doing 172
[    2.904521] calling  ldb_driver_init+0x0/0x24 @ 1
[    2.906488] initcall ldb_driver_init+0x0/0x24 returned 0 after 1879 usecs
[    2.906511] Doing 173
[    2.906543] calling  mipi_dsi_init+0x0/0x5c @ 1
[    2.907254] MIPI DSI driver module loaded
[    2.907293] initcall mipi_dsi_init+0x0/0x5c returned 0 after 697 usecs
[    2.907313] Doing 174
[    2.907343] calling  mxc_hdmi_i2c_init+0x0/0x28 @ 1
[    2.907615] initcall mxc_hdmi_i2c_init+0x0/0x28 returned 0 after 226 usecs
[    2.907638] Doing 175
[    2.907667] calling  mxc_hdmi_init+0x0/0x24 @ 1
[    2.909310] initcall mxc_hdmi_init+0x0/0x24 returned 0 after 1562 usecs
[    2.909336] Doing 176
[    2.909365] calling  mxc_lcdif_init+0x0/0x24 @ 1
[    2.909895] initcall mxc_lcdif_init+0x0/0x24 returned 0 after 480 usecs
[    2.909918] Doing 177
[    2.909949] calling  mxcfb_init+0x0/0x24 @ 1
[    2.910597] mxc_sdc_fb fb.24: registered mxc display driver ldb
[    2.954454] imx-ipuv3 2800000.ipu: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
[    3.172492] Console: switching to colour frame buffer device 128x37
[    3.210270] mxc_hdmi 20e0000.hdmi_video: Detected HDMI controller 0x13:0xa:0xa0:0xc1
[    3.210326] fbcvt: 1920x1080@60: CVT Name - 2.073M9
[    3.210515] mxc_sdc_fb fb.25: registered mxc display driver hdmi
[    3.320320] mxc_sdc_fb fb.26: Can't get fb option for mxcfb2!
[    3.320521] mxc_sdc_fb fb.27: Can't get fb option for mxcfb3!
[    3.320699] initcall mxcfb_init+0x0/0x24 returned 0 after 401079 usecs
[    3.320722] Doing 178
[    3.320755] calling  mxc_epdc_fb_driver_init+0x0/0x24 @ 1
[    3.321365] initcall mxc_epdc_fb_driver_init+0x0/0x24 returned 0 after 558 usecs
[    3.321388] Doing 179
[    3.321419] calling  sii902x_driver_init+0x0/0x28 @ 1
[    3.321589] initcall sii902x_driver_init+0x0/0x28 returned 0 after 131 usecs
[    3.321611] Doing 180
[    3.321641] calling  cabc_driver_init+0x0/0x24 @ 1
[    3.322098] initcall cabc_driver_init+0x0/0x24 returned 0 after 411 usecs
[    3.322118] Doing 181
[    3.322148] calling  mx3fb_init+0x0/0x4c @ 1
[    3.322398] initcall mx3fb_init+0x0/0x4c returned 0 after 210 usecs
[    3.322418] Doing 182
[    3.322446] calling  mxsfb_driver_init+0x0/0x24 @ 1
[    3.323124] initcall mxsfb_driver_init+0x0/0x24 returned 0 after 627 usecs
[    3.323144] Doing 183
[    3.323174] calling  pxp_driver_init+0x0/0x24 @ 1
[    3.323665] initcall pxp_driver_init+0x0/0x24 returned 0 after 445 usecs
[    3.323687] Doing 184
[    3.323716] calling  sdma_module_init+0x0/0x2c @ 1
[    3.324406] imx-sdma 20ec000.sdma: no iram assigned, using external mem
[    3.329132] imx-sdma 20ec000.sdma: loaded firmware 1.1
[    3.336107] imx-sdma 20ec000.sdma: initialized
[    3.336612] initcall sdma_module_init+0x0/0x2c returned 0 after 12549 usecs
[    3.336634] Doing 185
[    3.336667] calling  pfuze_driver_init+0x0/0x28 @ 1
[    3.338582] pfuze100-regulator 1-0008: Full lay: 2, Metal lay: 1
[    3.339328] pfuze100-regulator 1-0008: FAB: 0, FIN: 0
[    3.339361] pfuze100-regulator 1-0008: pfuze100 found.
[    3.341469] SW1AB: 300 <--> 1875 mV at 1150 mV
[    3.343964] SW1C: 300 <--> 1875 mV at 1175 mV
[    3.346466] SW2: 800 <--> 3300 mV at 3300 mV
[    3.348991] SW3A: 400 <--> 1975 mV at 1350 mV
[    3.351468] SW3B: 400 <--> 1975 mV at 1350 mV
[    3.354056] SW4: 800 <--> 1975 mV at 1800 mV
[    3.355891] SWBST: 5000 <--> 5150 mV at 5000 mV
[    3.357639] VSNVS: 1000 <--> 3000 mV at 3000 mV
[    3.358704] VREFDDR: 750 mV
[    3.359735] VGEN1: 800 <--> 1550 mV at 1200 mV
[    3.361530] VGEN2: 800 <--> 1550 mV at 1500 mV
[    3.364167] VGEN3: 1800 <--> 3300 mV at 2800 mV
[    3.366740] VGEN4: 1800 <--> 3300 mV at 3300 mV
[    3.369245] VGEN5: 1800 <--> 3300 mV at 3300 mV
[    3.371714] VGEN6: 1800 <--> 3300 mV at 3000 mV
[    3.375737] VCOIN: 3000 mV
[    3.376800] initcall pfuze_driver_init+0x0/0x28 returned 0 after     | usecs
[    3.376825] Doing 186                                               |
[    3.376858] calling  pty_init+0x0/0x1c @ 1
[    3.377261] initcall pty_init+0x0/0x1c returned 0 after 355 usecs
[    3.377286] Doing 187
[    3.377317] calling  sysrq_init+0x0/0x104 @ 1
[    3.377392] initcall sysrq_init+0x0/0x104 returned 0 after 40 usecs
[    3.377411] Doing 188
[    3.377441] calling  imx_serial_init+0x0/0x78 @ 1
[    3.377459] Serial: IMX driver
[    3.378182] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX
[    9.706144] console [ttymxc0] enabled
[    9.711306] 21ec000.serial: ttymxc2 at MMIO 0x21ec000 (irq = 60) is a IMX
[    9.719339] 21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 61) is a IMX
[    9.727160] 21f4000.serial: ttymxc4 at MMIO 0x21f4000 (irq = 62) is a IMX
[    9.734940] initcall imx_serial_init+0x0/0x78 returned 0 after 6208452 usecs
[    9.742022] Doing 189
[    9.744384] calling  init_kgdboc+0x0/0x38 @ 1
[    9.748800] kgdb: Registered I/O driver kgdboc.
[    9.753371] kgdb: Waiting for connection from remote gdb...
我知道答案 目前已有0人回答
GMT+8, 2026-4-19 02:49 , Processed in 0.087371 second(s), 21 queries , Redis On.
