查看: 3866|回复: 1
[求助] imx6dl 使用ANDORID 5.0 LCD 驱动 LVDS 屏 DT 配置
发表于 2015-10-22 14:31:38 | 显示全部楼层 |阅读模式
imx6dl 使用ANDORID 5.0  LVDS 屏  目前屏还没点亮,能有背光
cmdline:
console=ttymxc0,115200 init=/init video=mxcfb0:dev=ldb,LDBXGA,if=RGB24,bpp=18 video=mxcfb1ff video=mxcfb2ff fbmem=10M fb0base
=0x27b00000 vmalloc=400M androidboot.console=ttymxc0 androidboot.hardware=freescale androidboot.selinux=disabled androidboot.dm_v
erity=disabled
DT 里是这样配置的
如何在DT里配置DI0_PIN15这个管脚为LCD使能脚?我的配置如下,可是行不通
FB里添加GPIO:
    mxcfb1: fb@0 {
        compatible = "fsl,mxc_sdc_fb";
        disp_dev = "ldb";
        interface_pix_fmt = "RGB24";
        mode_str ="1280x800@60";
        default_bpp = <18>;
        int_clk = <0>;
        late_init = <0>;
        pinctrl-names = "default";
        my_lcd_pin = <&pinctrl_mylcd>;
        status = "ok";
管脚配置:
    mylcdmux {
        pinctrl_mylcd: mylcd {
            fsl,pins = <
                MX6QDL_PAD_DI0_PIN15__LCD_ENABLE 0x1b0b1
驱动中使用:(主要是在这里调用的时候有问题
    plat_data->gpio_int = of_get_named_gpio(np, "my_lcd_pin", 0);
    if (plat_data->gpio_int == -EPROBE_DEFER)
        return -1;
    if (!gpio_is_valid(plat_data->gpio_int)) {
        printk("ERROR, emmmxxoo--->failed to get interrupt gpio\n");
        return 1;
    lcd_enable = gpio_get_value(plat_data->gpio_int);
    printk("shady---->lcd_eanble = %d\n", lcd_enable);
错误日志:
[    0.393015] /fb@0: could not get #gpio-cells for /soc/aips-bus@02000000/iomuxc@020e0000/mylcdmux/mylcd
[    0.393024] ERROR, emmmxxoo--->failed to get interrupt gpio
我知道答案 目前已有1人回答
发表于 2017-3-28 16:42:07 | 显示全部楼层
楼主,问题解了没?能不能分享一下,谢谢
GMT+8, 2026-4-16 20:40 , Processed in 0.090600 second(s), 22 queries , Redis On.
