查看: 4529|回复: 8
【重磅电子书】ARM嵌入式系统开发:软件设计与优化(英文...
发表于 2015-10-23 10:37:09 | 显示全部楼层 |阅读模式
Over the last ten years, the ARM architecture has become one of the most pervasive architectures in the world, with more than 2 billion ARM-based processors embedded in products ranging from cell phones to automotive braking systems. A world-wide community of ARM developers in semiconductor and product design companies includes software developers, system designers and hardware engineers. To date * book has directly addressed their need to develop the system and software for an ARM-based system. This text fills that gap. This book provides a comprehensive description of the operation of the ARM core from a developer perspective with a clear emphasis on software. It demonstrates *t only how to write efficient ARM software in C and assembly but also how to optimize code. Example code throughout the book can be integrated into commercial products or used as templates to enable quick creation of productive software. The book covers both the ARM and Thumb instruction sets, covers Intel's XScale Processors, outlines distinctions among the versions of the ARM architecture, demonstrates how to implement DSP algorithms, explains exception and interrupt handling, describes the cache tech*logies that surround the ARM cores as well as the most efficient memory management techniques. A final chapter looks forward to the future of the ARM architecture considering ARMv6, the latest change to the instruction set, which has been designed to improve the DSP and media processing capabilities of the architecture.* * other book describes the ARM core from a system and software perspective. * Author team combines extensive ARM software engineering experience with an in-depth k*wledge of ARM developer needs. * Practical, executable code is fully explained in the book and available on the publisher's Website. * Includes a simple embedded operating system.
目录:
ARM SYSTEM DEVELOPER’S GUIDE: DESIGNING AND OPTIMIZING SYSTEM SOFTWARE
ANDREW N. SLOSS, DOMINIC SYMES, CHRIS WRIGHT
Cover image
Title page
Table of Contents
ABOUT THE AUTHORS
Copyright
PREFACE
Chapter 1: ARM EMBEDDED SYSTEMS
1.1 THE RISC DESIGN PHILOSOPHY
1.2 THE ARM DESIGN PHILOSOPHY
1.3 EMBEDDED SYSTEM HARDWARE
1.4 EMBEDDED SYSTEM SOFTWARE
1.5 SUMMARY
Chapter 2: ARM PROCESSOR FUNDAMENTALS
2.1 REGISTERS
2.2 CURRENT PROGRAM STATUS REGISTER
2.3 PIPELINE
2.4 EXCEPTIONS, INTERRUPTS, AND THE VECTOR TABLE
2.5 CORE EXTENSIONS
2.6 ARCHITECTURE REVISIONS
2.7 ARM PROCESSOR FAMILIES
2.8 SUMMARY
Chapter 3: INTRODUCTION TO THE ARM INSTRUCTION SET
3.1 DATA PROCESSING INSTRUCTIONS
3.2 BRANCH INSTRUCTIONS
3.3 LOAD-STORE INSTRUCTIONS
3.4 SOFTWARE INTERRUPT INSTRUCTION
3.5 PROGRAM STATUS REGISTER INSTRUCTIONS
3.6 LOADING CONSTANTS
3.7 ARMV5E EXTENSIONS
3.8 CONDITIONAL EXECUTION
3.9 SUMMARY
Chapter 4: INTRODUCTION TO THE THUMB INSTRUCTION SET
4.1 THUMB REGISTER USAGE
4.2 ARM-THUMB INTERWORKING
4.3 OTHER BRANCH INSTRUCTIONS
4.4 DATA PROCESSING INSTRUCTIONS
4.5 SINGLE-REGISTER LOAD-STORE INSTRUCTIONS
4.6 MULTIPLE-REGISTER LOAD-STORE INSTRUCTIONS
4.7 STACK INSTRUCTIONS
4.8 SOFTWARE INTERRUPT INSTRUCTION
4.9 SUMMARY
Chapter 5: EFFICIENT C PROGRAMMING
5.1 OVERVIEW OF C COMPILERS AND OPTIMIZATION
5.2 BASIC C DATA TYPES
5.3 C LOOPING STRUCTURES
5.4 REGISTER ALLOCATION
5.5 FUNCTION CALLS
5.6 POINTER ALIASING
5.7 STRUCTURE ARRANGEMENT
5.8 BIT-FIELDS
5.9 UNALIGNED DATA AND ENDIANNESS
5.10 DIVISION
5.11 FLOATING POINT
5.12 INLINE FUNCTIONS AND INLINE ASSEMBLY
5.13 PORTABILITY ISSUES
5.14 SUMMARY
Chapter 6: WRITING AND OPTIMIZING ARM ASSEMBLY CODE
6.1 WRITING ASSEMBLY CODE
6.2 PROFILING AND CYCLE COUNTING
6.3 INSTRUCTION SCHEDULING
6.4 REGISTER ALLOCATION
6.5 CONDITIONAL EXECUTION
6.6 LOOPING CONSTRUCTS
6.7 BIT MANIPULATION
6.8 EFFICIENT SWITCHES
6.9 HANDLING UNALIGNED DATA
6.10 SUMMARY
Chapter 7: OPTIMIZED PRIMITIVES
7.1 DOUBLE-PRECISION INTEGER MULTIPLICATION
7.2 INTEGER NORMALIZATION AND COUNT LEADING ZEROS
7.3 DIVISION
7.4 SQUARE ROOTS
7.5 TRANSCENDENTAL FUNCTIONS: LOG, EXP, SIN, COS
7.6 ENDIAN REVERSAL AND BIT OPERATIONS
7.7 SATURATED AND ROUNDED ARITHMETIC
7.8 RANDOM NUMBER GENERATION
7.9 SUMMARY
Chapter 8: DIGITAL SIGNAL PROCESSING
8.1 REPRESENTING A DIGITAL SIGNAL
8.2 INTRODUCTION TO DSP ON THE ARM
8.3 FIR FILTERS
8.4 IIR FILTERS
8.5 THE DISCRETE FOURIER TRANSFORM
8.6 SUMMARY
Chapter 9: EXCEPTION AND INTERRUPT HANDLING
9.1 EXCEPTION HANDLING
9.2 INTERRUPTS
9.3 INTERRUPT HANDLING SCHEMES
9.4 SUMMARY
Chapter 10: FIRMWARE
10.1 FIRMWARE AND BOOTLOADER
10.2 EXAMPLE: SANDSTONE
10.3 SUMMARY
Chapter 11: EMBEDDED OPERATING SYSTEMS
11.1 FUNDAMENTAL COMPONENTS
11.2 EXAMPLE: SIMPLE LITTLE OPERATING SYSTEM
11.3 SUMMARY
Chapter 12: CACHES
12.1 THE MEMORY HIERARCHY AND CACHE MEMORY
12.2 CACHE ARCHITECTURE
12.3 CACHE POLICY
12.4 COPROCESSOR 15 AND CACHES
12.5 FLUSHING AND CLEANING CACHE MEMORY
12.6 CACHE LOCKDOWN
12.7 CACHES AND SOFTWARE PERFORMANCE
12.8 SUMMARY
Chapter 13: MEMORY PROTECTION UNITS
13.1 PROTECTED REGIONS
13.2 INITIALIZING THE MPU, CACHES, AND WRITE BUFFER
13.3 DEMONSTRATION OF AN MPU SYSTEM
13.4 SUMMARY
Chapter 14: MEMORY MANAGEMENT UNITS
14.1 MOVING FROM AN MPU TO AN MMU
14.2 HOW VIRTUAL MEMORY WORKS
14.3 DETAILS OF THE ARM MMU
14.4 PAGE TABLES
14.5 THE TRANSLATION LOOKASIDE BUFFER
14.6 DOMAINS AND MEMORY ACCESS PERMISSION
14.7 THE CACHES AND WRITE BUFFER
14.8 COPROCESSOR 15 AND MMU CONFIGURATION
14.9 THE FAST CONTEXT SWITCH EXTENSION
14.10 DEMONSTRATION: A SMALL VIRTUAL MEMORY SYSTEM
14.11 THE DEMONSTRATION AS MMUSLOS
14.12 SUMMARY
Chapter 15: THE FUTURE OF THE ARCHITECTURE
15.1 ADVANCED DSP AND SIMD SUPPORT IN ARMv6
15.2 SYSTEM AND MULTIPROCESSOR SUPPORT ADDITIONS TO ARMv6
15.3 ARMv6 IMPLEMENTATIONS
15.4 FUTURE TECHNOLOGIES BEYOND ARMv6
15.5 SUMMARY
Appendix A: ARM AND THUMB ASSEMBLER INSTRUCTIONS
Appendix B: ARM AND THUMB INSTRUCTION ENCODINGS
Appendix C: PROCESSORS AND ARCHITECTURE
Appendix D: INSTRUCTION CYCLE TIMINGS
Appendix E: SUGGESTED READING
INDEX
 楼主| 发表于 2015-10-23 10:44:55 | 显示全部楼层
ARM System Developer's Guide, Designing and Optimizing System Software
ARM System Developer’s Guide- Designing and Optimizing System Software.pdf
3.32 MB, 下载次数: 86, 下载积分: 威望 1
发表于 2015-10-23 10:51:40 | 显示全部楼层
楼主好人!非常感谢分享!
 楼主| 发表于 2015-10-23 11:55:44 | 显示全部楼层
补充中文版
ARM嵌入式系统开发:软件设计与优化.part1.rar
5 MB, 下载次数: 32, 下载积分: 威望 1
ARM嵌入式系统开发:软件设计与优化.part2.rar
5 MB, 下载次数: 30, 下载积分: 威望 1
 楼主| 发表于 2015-10-23 11:57:49 | 显示全部楼层
继续补充
ARM嵌入式系统开发:软件设计与优化.part3.rar
5 MB, 下载次数: 27, 下载积分: 威望 1
ARM嵌入式系统开发:软件设计与优化.part4.rar
5 MB, 下载次数: 26, 下载积分: 威望 1
发表于 2015-10-23 11:58:42 | 显示全部楼层
 楼主| 发表于 2015-10-23 11:58:43 | 显示全部楼层
继续补充
ARM嵌入式系统开发:软件设计与优化.part5.rar
5 MB, 下载次数: 31, 下载积分: 威望 1
ARM嵌入式系统开发:软件设计与优化.part6.rar
ARM嵌入式系统开发:软件设计与优化.part7.rar
5 MB, 下载次数: 29, 下载积分: 威望 1
ARM嵌入式系统开发:软件设计与优化.part8.rar
2.29 MB, 下载次数: 29, 下载积分: 威望 1
  • 签到天数: 7 天
    发表于 2015-10-24 11:39:52 | 显示全部楼层
    支持一下
    2018-12-25 13:50
  • 签到天数: 4 天
    发表于 2018-9-30 13:53:04 | 显示全部楼层
    真好
    GMT+8, 2025-9-30 18:53 , Processed in 0.113471 second(s), 27 queries , MemCache On.
