查看: 3490|回复: 4
[求助] imx6q的sd卡报错问题
发表于 2015-10-23 22:15:54 | 显示全部楼层 |阅读模式
我使用2GB的低速TF卡是可以正常使用的,使用三星8GTF卡(带HC),和闪迪16G(HC)TF卡会出现如此报错,挂载也会这样。求教啊。各位遇见过这种情况吗?
  1. / # hdparm -tT /dev/mmcblk0
  2. /dev/mmcblk0:
  3. mmcblk0: error -84 transferring data, sector 0, nr 512, cmd response 0x900, card status 0xb00
  4. mmcblk0: retrying using single block read
  5. Timing buffer-cache reads:   328 MB in 0.51 seconds = 654735 kB/s
  6. Timing buffered disk reads:mmcblk0: error -84 transferring data, sector 16384, nr 512, cmd response 0x900, card status 0xb00
  7. mmcblk0: retrying using single block read
  8. mmcblk0: error -84 transferring data, sector 16457, nr 439, cmd response 0x900, card status 0x0
  9. end_request: I/O error, dev mmcblk0, sector 16457
  10. mmcblk0: error -84 transferring data, sector 16458, nr 438, cmd response 0x900, card status 0x0
  11. end_request: I/O error, dev mmcblk0, sector 16458
  12. Buffer I/O error on device mmcblk0, logical block 2057
  13. mmcblk0: error -84 transferring data, sector 16477, nr 419, cmd response 0x900, card status 0x0
  14. end_request: I/O error, dev mmcblk0, sector 16477
  15. Buffer I/O error on device mmcblk0, logical block 2059
  16. mmcblk0: error -84 transferring data, sector 16480, nr 416, cmd response 0x900, card status 0x0
  17. end_request: I/O error, dev mmcblk0, sector 16480
  18. mmc0: Got data interrupt 0x00000002 even though no data operation was in progress.
  19. mmcblk0: error -84 transferring data, sector 16485, nr 411, cmd response 0x900, card status 0x0
  20. end_request: I/O error, dev mmcblk0, sector 16485
  21. mmcblk0: error -84 transferring data, sector 16486, nr 410, cmd response 0x900, card status 0x0
  22. end_request: I/O error, dev mmcblk0, sector 16486
  23. Buffer I/O error on device mmcblk0, logical block 2060
  24. mmcblk0: error -84 transferring data, sector 16502, nr 394, cmd response 0x900, card status 0x0
  25. end_request: I/O error, dev mmcblk0, sector 16502
  26. Buffer I/O error on device mmcblk0, logical block 2062
  27. mmcblk0: error -84 transferring data, sector 16505, nr 391, cmd response 0x900, card status 0x0
  28. end_request: I/O error, dev mmcblk0, sector 16505
  29. Buffer I/O error on device mmcblk0, logical block 2063
  30. mmcblk0: error -84 transferring data, sector 16695, nr 201, cmd response 0x900, card status 0x0
  31. end_request: I/O error, dev mmcblk0, sector 16695
  32. Buffer I/O error on device mmcblk0, logical block 2086
  33. mmcblk0: error -84 transferring data, sector 16715, nr 181, cmd response 0x900, card status 0x0
  34. end_request: I/O error, dev mmcblk0, sector 16715
  35. Buffer I/O error on device mmcblk0, logical block 2089
  36. mmcblk0: error -84 transferring data, sector 16748, nr 148, cmd response 0x900, card status 0x0
  37. end_request: I/O error, dev mmcblk0, sector 16748
  38. Buffer I/O error on device mmcblk0, logical block 2093
  39. mmc0: Got data interrupt 0x00000002 even though no data operation was in progress.
  40. mmcblk0: error -84 transferring data, sector 16758, nr 138, cmd response 0x900, card status 0x0
  41. end_request: I/O error, dev mmcblk0, sector 16758
  42. Buffer I/O error on device mmcblk0, logical block 2094
  43. mmcblk0: error -84 transferring data, sector 16789, nr 107, cmd response 0x900, card status 0x0
  44. end_request: I/O error, dev mmcblk0, sector 16789
  45. Buffer I/O error on device mmcblk0, logical block 2098
  46. mmcblk0: error -84 transferring data, sector 16824, nr 72, cmd response 0x900, card status 0x0
  47. end_request: I/O error, dev mmcblk0, sector 16824
  48. mmcblk0: error -84 transferring data, sector 16827, nr 69, cmd response 0x900, card status 0x0
  49. end_request: I/O error, dev mmcblk0, sector 16827
  50. mmcblk0: error -84 transferring data, sector 16862, nr 34, cmd response 0x900, card status 0x0
  51. end_request: I/O error, dev mmcblk0, sector 16862
  52. mmcblk0: error -84 transferring data, sector 16883, nr 13, cmd response 0x900, card status 0x0
  53. end_request: I/O error, dev mmcblk0, sector 16883
  54. mmcblk0: error -84 transferring data, sector 16472, nr 8, cmd response 0x900, card status 0xb00
  55. mmcblk0: retrying using single block read
  56. mmcblk0: error -84 transferring data, sector 16496, nr 8, cmd response 0x900, card status 0xb00
  57. mmcblk0: retrying using single block read
  58. mmcblk0: error -84 transferring data, sector 16896, nr 256, cmd response 0x900, card status 0xb00
  59. mmcblk0: retrying using single block read
  60. mmcblk0: error -84 transferring data, sector 16913, nr 239, cmd response 0x900, card status 0x0
  61. end_request: I/O error, dev mmcblk0, sector 16913
  62. mmcblk0: error -84 transferring data, sector 16961, nr 191, cmd response 0x900, card status 0x0
  63. end_request: I/O error, dev mmcblk0, sector 16961
  64. mmcblk0: error -84 transferring data, sector 16970, nr 182, cmd response 0x900, card status 0x0
  65. end_request: I/O error, dev mmcblk0, sector 16970
  66. mmcblk0: error -84 transferring data, sector 16987, nr 165, cmd response 0x900, card status 0x0
  67. end_request: I/O error, dev mmcblk0, sector 16987
  68. mmcblk0: error -84 transferring data, sector 17013, nr 139, cmd response 0x900, card status 0x0
  69. end_request: I/O error, dev mmcblk0, sector 17013
  70. mmcblk0: error -84 transferring data, sector 17052, nr 100, cmd response 0x900, card status 0x0
  71. end_request: I/O error, dev mmcblk0, sector 17052
  72. mmcblk0: error -84 transferring data, sector 17065, nr 87, cmd response 0x900, card status 0x0
  73. end_request: I/O error, dev mmcblk0, sector 17065
  74. mmcblk0: error -84 transferring data, sector 17073, nr 79, cmd response 0x900, card status 0x0
  75. end_request: I/O error, dev mmcblk0, sector 17073
  76. mmcblk0: error -84 transferring data, sector 17088, nr 64, cmd response 0x900, card status 0x0
  77. end_request: I/O error, dev mmcblk0, sector 17088
  78. mmcblk0: error -84 transferring data, sector 16712, nr 8, cmd response 0x900, card status 0xb00
  79. mmcblk0: retrying using single block read
  80. mmcblk0: error -84 transferring data, sector 16784, nr 8, cmd response 0x900, card status 0xb00
  81. mmcblk0: retrying using single block read
  82. mmc0: Got data interrupt 0x00000002 even though no data operation was in progress.
  83. mmcblk0: error -84 transferring data, sector 16787, nr 5, cmd response 0x900, card status 0x0
  84. end_request: I/O error, dev mmcblk0, sector 16787
  85. mmcblk0: error -84 transferring data, sector 16791, nr 1, cmd response 0x900, card status 0x0
  86. end_request: I/O error, dev mmcblk0, sector 16791
  87. mmcblk0: error -84 transferring data, sector 16784, nr 8, cmd response 0x900, card status 0xb00
  88. mmcblk0: retrying using single block read
  89. mmcblk0: error -84 transferring data, sector 17152, nr 64, cmd response 0x900, card status 0xb00
  90. mmcblk0: retrying using single block read
  91. mmc0: Got data interrupt 0x00000002 even though no data operation was in progress.
  92. mmcblk0: error -84 transferring data, sector 17174, nr 42, cmd response 0x900, card status 0x0
  93. end_request: I/O error, dev mmcblk0, sector 17174
  94. mmcblk0: error -84 transferring data, sector 17187, nr 29, cmd response 0x900, card status 0x0
  95. end_request: I/O error, dev mmcblk0, sector 17187
  96. mmcblk0: error -84 transferring data, sector 16960, nr 8, cmd response 0x900, card status 0xb00
  97. mmcblk0: retrying using single block read
  98. mmcblk0: error -84 transferring data, sector 16968, nr 8, cmd response 0x900, card status 0xb00
  99. mmcblk0: retrying using single block read
  100. mmcblk0: error -84 transferring data, sector 16968, nr 8, cmd response 0x900, card status 0x0
  101. end_request: I/O error, dev mmcblk0, sector 16968
  102. mmcblk0: error -84 transferring data, sector 16984, nr 8, cmd response 0x900, card status 0xb00
  103. mmcblk0: retrying using single block read
  104. mmcblk0: error -84 transferring data, sector 17064, nr 8, cmd response 0x900, card status 0xb00
  105. mmcblk0: retrying using single block read
  106. mmcblk0: error -84 transferring data, sector 17072, nr 8, cmd response 0x900, card status 0xb00
  107. mmcblk0: retrying using single block read
  108. mmcblk0: error -84 transferring data, sector 17168, nr 8, cmd response 0x900, card status 0xb00
  109. mmcblk0: retrying using single block read
  110. mmcblk0: error -84 transferring data, sector 17216, nr 16, cmd response 0x900, card status 0xb00
  111. mmcblk0: retrying using single block read
  112. mmcblk0: error -84 transferring data, sector 17232, nr 32, cmd response 0x900, card status 0xb00
  113. mmcblk0: retrying using single block read
  114. mmcblk0: error -84 transferring data, sector 17264, nr 32, cmd response 0x900, card status 0xb00
  115. mmcblk0: retrying using single block read
  116. mmcblk0: error -84 transferring data, sector 17296, nr 32, cmd response 0x900, card status 0xb00
  117. mmcblk0: retrying using single block read
  118. mmcblk0: error -84 transferring data, sector 17328, nr 32, cmd response 0x900, card status 0xb00
  119. mmcblk0: retrying using single block read
  120. mmcblk0: error -84 transferring data, sector 17360, nr 32, cmd response 0x900, card status 0xb00
  121. mmcblk0: retrying using single block read
  122. mmcblk0: error -84 transferring data, sector 17392, nr 32, cmd response 0x900, card status 0xb00
  123. mmcblk0: retrying using single block read
  124. mmcblk0: error -84 transferring data, sector 17419, nr 5, cmd response 0x900, card status 0x0
  125. end_request: I/O error, dev mmcblk0, sector 17419
  126. mmcblk0: error -84 transferring data, sector 17416, nr 24, cmd response 0x900, card status 0xb00
  127. mmcblk0: retrying using single block read
  128. mmc0: Got data interrupt 0x00000002 even though no data operation was in progress.
  129. mmcblk0: error -84 transferring data, sector 17421, nr 19, cmd response 0x900, card status 0x0
  130. end_request: I/O error, dev mmcblk0, sector 17421
  131. mmcblk0: error -84 transferring data, sector 17440, nr 8, cmd response 0x900, card status 0xb00
  132. mmcblk0: retrying using single block read
  133. mmcblk0: error -84 transferring data, sector 17456, nr 8, cmd response 0x900, card status 0xb00
  134. mmcblk0: retrying using single block read
  135. mmcblk0: error -84 transferring data, sector 17461, nr 3, cmd response 0x900, card status 0x0
  136. end_request: I/O error, dev mmcblk0, sector 17461
  137. mmcblk0: error -84 transferring data, sector 17456, nr 8, cmd response 0x900, card status 0xb00
  138. mmcblk0: retrying using single block read
  139. mmcblk0: error -84 transferring data, sector 17460, nr 4, cmd response 0x900, card status 0x0
  140. end_request: I/O error, dev mmcblk0, sector 17460
  141. hdparm: short read
我知道答案 目前已有4人回答
  • 签到天数: 736 天
    发表于 2015-10-24 09:13:41 | 显示全部楼层
    帮顶一下
     楼主| 发表于 2015-10-24 10:38:13 | 显示全部楼层
    谢谢!希望您能咨询一下身边的朋友,遇见过此类问题没有
    发表于 2015-10-24 15:54:32 | 显示全部楼层
    imx6q上高端应用的板子,搞的人不多吧
     楼主| 发表于 2015-10-25 12:15:46 | 显示全部楼层
    研究生实验室用的这个
    GMT+8, 2026-4-19 02:47 , Processed in 0.094925 second(s), 28 queries , Redis On.
