查看: 4186|回复: 7
[MPC] 【KL26Z申请】(掘坟方案)Freescale MPC5200开发板vxwork移植配....
发表于 2015-11-4 10:20:41 | 显示全部楼层 |阅读模式
当时的方案是基于Freescale MPC5200开发板移植了vxwork为os。以下是串口输出的状态信息
0x4b316a Bytes) OK
Loading .text @ 0x00010000 (4101184 bytes)
Loading .init$00 @ 0x003f9440 (28 bytes)
Loading .init$99 @ 0x003f945c (16 bytes)
Loading .fini$00 @ 0x003f946c (28 bytes)
Loading .fini$99 @ 0x003f9488 (16 bytes)
Loading .mitracinfo @ 0x003f9498 (290 bytes)
Loading .sdata2 @ 0x003f95c0 (416 bytes)
Loading .data @ 0x003f9760 (297888 bytes)
Loading .sdata @ 0x00442300 (3504 bytes)
Clearing .sbss @ 0x004430b0 (4000 bytes)
Clearing .bss @ 0x00444060 (687120 bytes)
## Using bootline (@ 0x4200): fec(0,0): e=10.0.1.3:ff000000 g=10.0.0.101 tn=DUT
## Starting vxWorks at 0x00010000 ...
Host Name: bootHost
User: target
Instantiating /ram as rawFs,  device = 0x20001
Formatting /ram for DOSFS
Formatting...Retrieved old volume params with %38 confidence:
Volume Parameters: FAT type: FAT32, sectors per cluster 0
  0 FAT copies, 0 clusters, 0 sectors per FAT
  Sectors reserved 0, hidden 0, FAT sectors 0
  Root dir entries 0, sysId (null)  , serial number 1d0000
  Label:"           " ...
Disk with 64 sectors of 512 bytes will be formatted with:
Volume Parameters: FAT type: FAT12, sectors per cluster 1
  2 FAT copies, 54 clusters, 1 sectors per FAT
  Sectors reserved 1, hidden 0, FAT sectors 2
  Root dir entries 112, sysId VXDOS12 , serial number 1d0000
  Label:"           " ...
OK.
Adding 9779 symbols for standalone.
                VxWorks
Copyright 1984-2007  Wind River Systems, Inc.
             CPU: MPC5200
    Runtime Name: VxWorks
Runtime Version: 6.6
     BSP version: 2.0/0
         Created: May 11 2011, 15:17:55
ED&R Policy Mode: Deployed
   WDB Comm Type: WDB_COMM_END
             WDB: Ready.
____________________________________________________________________________
CSS RTS Startup
The native startup mode is 2 (IDLE)
Hit any key to interrupt the startup process
Starting in mode 2 (IDLE)
CSS Run-time Monitor (Local terminal port OS_IO_COM1)
RTS_Mon(IDLE)->
Board addr  0: DTBB 411     base board type = 0  variant = 1
      Board temperature (1) is : 15
Board addr  8: DTPC 401      cpu board type = 5  variant = 2
      Board temperature (1) is : 16
Configuring VCU-C for DCY 1150A, 4-serial
MOBAD detected
Adding default gateway 10.0.0.101 to routing table succeeded
Adding target host DUT IP 127.0.0.1 to host table succeeded
================== BSP ===================
Build: vx_vcuc 3.9.1.0
Built by Bombardier Transportation (VAPPC)
Created  May 11 2011, 15:17:55
================ CSS RTS =================
Build: CSS 3.9.1.0
Created  May 11 2011, 15:25:50
TNM-Agent Version: 1.5.0.0
- Idle mode
RTS_Mon(IDLE)->WARNING: Shutdown device restart mode = 1 ID: 11312
U-Boot ubt-2-3-0 (Sep 19 2008 - 14:08:04)
CPU:   MPC5200 v2.2 at 396 MHz
       Bus 132 MHz, IPB 66 MHz, PCI 33 MHz
Board: DTPC 401A
I2C:   85 kHz, ready
DRAM:  128 MB
FLASH: 32 MB
PCI:   Bus Dev VenId DevId Class Int
In:    serial
Out:   serial
Err:   serial
Net:   100MBit Full Duplex FEC ETHERNET
Type "dhcp" to load using DHCP
Run command="mcp loop"
I2C:   85 kHz, ready
DRAM:  128 MB
POST memory test (level 1)
POST memory PASSED
FLASH: 32 MB
In:    serial
Out:   serial
Err:   serial
Net:   Autonegotiation failed. Link is down.
FEC ETHERNET
Run command="bootm fe000000"
## Booting image at fe000000 ...
   Image Name:   CSS [o] 3.10.2.0
   Image Type:   PowerPC VxWorks Kernel Image (gzip compressed)
   Data Size:    1944453 Bytes =  1.9 MB
   Load Address: 00800000
   Entry Point:  00800000
   Verifying Checksum ... OK
   Uncompressing Kernel Image ... (0x4b9021 Bytes) OK
Loading .text @ 0x00010000 (4121968 bytes)
Loading .init$00 @ 0x003fe570 (28 bytes)
Loading .init$99 @ 0x003fe58c (16 bytes)
Loading .fini$00 @ 0x003fe59c (28 bytes)
Loading .fini$99 @ 0x003fe5b8 (16 bytes)
Loading .mitracinfo @ 0x003fe5c8 (290 bytes)
Loading .sdata2 @ 0x003fe6f0 (416 bytes)
Loading .data @ 0x003fe8a0 (298992 bytes)
Loading .sdata @ 0x00447890 (3504 bytes)
Clearing .sbss @ 0x00448640 (4016 bytes)
Clearing .bss @ 0x00449600 (693328 bytes)
Host Name: bootHost
User: target
tffsDevCreate failed.
0x5eac320 (tRootTask): checkStatus() ERROR line 283
Instantiating /ram as rawFs,  device = 0x1
  Root dir entries 0, sysId (null)  , serial number 40000
  Label:"           " ...
  Root dir entries 112, sysId VXDOS12 , serial number 40000
  Label:"           " ...
OK.
Adding 9828 symbols for standalone.
我知道答案 目前已有7人回答
mpc5200评估板
mpc5200评估板
MPC5200.pdf
6.58 MB, 下载次数: 15, 下载积分: 威望 1
mpc5200手册
发表于 2015-11-4 11:28:44 | 显示全部楼层
支持一下
发表于 2015-11-4 12:30:54 | 显示全部楼层
vxwork系统移植需要源代码吗?据说vxwork费用较高
 楼主| 发表于 2015-11-4 12:47:56 | 显示全部楼层
商用vxworks费用相当高
发表于 2015-11-4 13:19:19 | 显示全部楼层
掘坟方案
发表于 2015-11-4 14:52:28 | 显示全部楼层
没看明白啊
    发表于 2015-11-4 21:25:26 | 显示全部楼层
    谢谢分享学习一下
    发表于 2015-11-5 09:21:24 | 显示全部楼层
    GMT+8, 2025-11-3 01:30 , Processed in 0.248658 second(s), 29 queries , MemCache On.
