在线时间30 小时
UID3086401
注册时间2014-12-24
NXP金币0
 - 240
 - 2017-6-28
KDS下使用KSDK库操作FLASH,芯片型号MK22FN1M0A,把数据写入FLASH后,读出来都是0x00,
但是读flashSSDConfig.PFlashBase + PFLASH_IFR中的数据是0xFF
参考的是KSDK1.3中的DEMO
#define LAUNCH_CMD_SIZE         0x100
#define CALLBACK_SIZE           0x80
#define TesetBufferSize        4
/* array to copy __Launch_Command func to RAM */
uint16_t __ram_func[LAUNCH_CMD_SIZE/2];
uint16_t __ram_for_callback[CALLBACK_SIZE/2]; /* length of this array depends on total size of the functions need to be copied to RAM*/
uint8 UserFlashWriteBuffer[TesetBufferSize] = {0};
uint8 UserFlashReadBuffer[TesetBufferSize] = {0};
FLASH_SSD_CONFIG flashSSDConfig =
        .ftfxRegBase = 1073872896U,
        .PFlashBase  = 0U,
        .PFlashSize  = 1048576U,
        .DFlashBase  = 268435456U,
        .DFlashSize  = 0x00U,
        .EERAMBase   = 335544320U,
        .EEESize     = 0x00U,
        .DebugEnable        = false,
        .CallBack = NULL_CALLBACK,
pFLASHCOMMANDSEQUENCE g_FlashLaunchCommand = (pFLASHCOMMANDSEQUENCE)0xFFFFFFFF;
void UserFlash_Callback(void)
void UserFlash_Init(void)
           uint32_t ret;
           uint32_t destination;          /* Address of the target location */
         uint32_t size;
         uint32_t end;
         uint8_t  securityStatus;
         uint16_t number;
         uint32_t margin_read_level;
         uint32_t i, FailAddr;
         FlashInit(&flashSSDConfig);
          * Set CallBack to callback function
        flashSSDConfig.CallBack = (PCALLBACK)RelocateFunction((uint32_t)__ram_for_callback , CALLBACK_SIZE , (uint32_t)UserFlash_Callback);
        g_FlashLaunchCommand = (pFLASHCOMMANDSEQUENCE)RelocateFunction((uint32_t)__ram_func , LAUNCH_CMD_SIZE ,(uint32_t)FlashCommandSequence);
        destination = flashSSDConfig.PFlashBase + (flashSSDConfig.PFlashSize - FTFx_PSECTOR_SIZE);
    //ERASE
        size = FTFx_PSECTOR_SIZE;
        ret = FlashEraseSector(&flashSSDConfig, destination, size, g_FlashLaunchCommand);
        if (FTFx_OK != ret)
                printf("Erase Error\n");
        else
                printf("Erase OK\n");
        /* Verify section for several sector of PFLASH */
        number = FTFx_PSECTOR_SIZE/FSL_FEATURE_FLASH_PFLASH_SECTION_CMD_ADDRESS_ALIGMENT;
        for(margin_read_level = 0; margin_read_level < 0x2; margin_read_level++)
                ret = FlashVerifySection(&flashSSDConfig, destination, number, margin_read_level, g_FlashLaunchCommand);
                if (FTFx_OK != ret)
                        printf("Check Error\n");
        //Get secuity state
        securityStatus = 0x0;
        ret = FlashGetSecurityState(&flashSSDConfig, &securityStatus);
        switch(securityStatus)
      case FLASH_NOT_SECURE:
      default:
          printf("\r\n\r\n---->Flash is UNSECURE!");
          break;
      case FLASH_SECURE_BACKDOOR_ENABLED:
          printf("\r\n\r\n---->Flash is SECURE, BACKDOOR is ENABLED!");
          break;
      case FLASH_SECURE_BACKDOOR_DISABLED:
            printf("\r\n\r\n---->Flash is SECURE, BACKDOOR is DISABLED!");
            break;
        /* Read on P-Flash */
        destination = flashSSDConfig.PFlashBase + 0xC0;//PFLASH_IFR; /* Start address of Program Once Field */
        ret = FlashReadResource(&flashSSDConfig, destination, UserFlashReadBuffer, 0x0, g_FlashLaunchCommand);
        //write
        ret = FlashReadResource(&flashSSDConfig, destination, UserFlashReadBuffer, 0x0, g_FlashLaunchCommand);//结果是是0XFF
        for(i=0; i<TesetBufferSize; i++)
                UserFlashWriteBuffer[i] = i;
        size = TesetBufferSize;
        ret = FlashProgram(&flashSSDConfig, destination, size, UserFlashWriteBuffer, g_FlashLaunchCommand);
        if (FTFx_OK != ret)
                printf("Program Error\n");
        //read
        FlashReadResource(&flashSSDConfig, destination, UserFlashReadBuffer, 0, g_FlashLaunchCommand);//结果全是0X00,应该是0,1,2,3
        printf("End");
        while(1);
