查看: 2129|回复: 1
[求助] K64 的port寄存器中 GPCLR,GPCHR详细解释
发表于 2015-11-21 17:26:32 | 显示全部楼层 |阅读模式
K64 的port寄存器中typedef struct {  __IO uint32_t PCR[32];                           /**< Pin Control Register n, array offset: 0x0, array step: 0x4 */
  __O  uint32_t GPCLR;                             /**< Global Pin Control Low Register, offset: 0x80 */
  __O  uint32_t GPCHR;                             /**< Global Pin Control High Register, offset: 0x84 */
       uint8_t RESERVED_0[24];
  __IO uint32_t ISFR;                              /**< Interrupt Status Flag Register, offset: 0xA0 */
       uint8_t RESERVED_1[28];
  __IO uint32_t DFER;                              /**< Digital Filter Enable Register, offset: 0xC0 */
  __IO uint32_t DFCR;                              /**< Digital Filter Clock Register, offset: 0xC4 */
  __IO uint32_t DFWR;                              /**< Digital Filter Width Register, offset: 0xC8 */
} PORT_Type;
GPCLR;
GPCHR;           这两个寄存器的含义是什么,看不懂,能否解释一下,谢谢!
我知道答案 目前已有1人回答
发表于 2015-11-23 10:16:17 | 显示全部楼层
GMT+8, 2025-11-4 17:18 , Processed in 0.086970 second(s), 22 queries , MemCache On.
