查看: 2573|回复: 2
[求助] 使用SD卡启动失败问题 求助
发表于 2015-11-24 11:15:33 | 显示全部楼层 |阅读模式
SD卡启动后报错如下  ,而用mfgtools烧emmc启动是ok的,
U-Boot 2013.04 (Apr 05 2014 - 08:50:42)
CPU:   Freescale i.MX6Q rev1.2 at 792 MHz
CPU:   Temperature 39 C, calibration data: 0x59e5017d
Reset cause: POR
Board: MX6Q/SDL-SabreSD
I2C:   ready
DRAM:  1 GiB
MMC:   FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2
*** Warning - bad CRC, using default environment
No panel detected: default to Hannstar-XGA
Display: Hannstar-XGA (1024x768)
In:    serial
Out:   serial
Err:   serial
Found PFUZE100! deviceid=10,revid=11
mmc1 is current device
Net:   FEC [PRIME]
Warning: FEC using MAC address from net device
Normal Boot
** Unrecognized filesystem type **
Booting from net ...
FEC Waiting for PHY auto negotiation to complete......... TIMEOUT !
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
另外 我安装  我按照  Running the Image from MMC/SD 中方法,设置uboot,最后提示内核format 格式问题 如下:
setenv loadaddr 0x12000000
setenv fdt_addr 0x18000000
setenv fdt_high 0xffffffff
setenv bootargs_base 'setenv bootargs console=ttymxc0,115200'
setenv bootargs_mmc 'setenv bootargs ${bootargs} root=/dev/mmcblk0p2 rootwait rw video=mxcfb1:dev=ldb,LDB-XGA,if=RGB666 video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24'
setenv bootcmd_mmc 'run bootargs_base bootargs_mmc;mmc dev 1;mmc read ${loadaddr} 0x800 0x2000;mmc read ${fdt_addr} 0x5000 0x800;bootm ${loadaddr} - ${fdt_addr}'
setenv bootcmd 'run bootcmd_mmc'
saveenv
Saving Environment to MMC...
Writing to MMC(1)... done
=> run bootcmd
MMC read: dev # 1, block # 2048, count 8192 ... 8192 blocks read: OK
MMC read: dev # 1, block # 20480, count 2048 ... 2048 blocks read: OK
Wrong Image Format for bootm command
ERROR: can't get kernel image!
请问如何解决呢 ,多谢
我知道答案 目前已有2人回答
发表于 2015-11-24 15:11:13 | 显示全部楼层
你这是怎么使用SD呢?
发表于 2015-11-25 08:58:25 | 显示全部楼层
make 学习。 还没到这个程度
GMT+8, 2025-11-4 10:37 , Processed in 0.105334 second(s), 24 queries , MemCache On.
