查看: 5388|回复: 11
[求助] 我对ke02的flash进行擦除问题,有个问题不解
发表于 2015-11-27 10:48:12 | 显示全部楼层 |阅读模式
我对ke02的flash进行擦除,直接调用例程FLASH_EraseSector(16*512);擦除,他就从0x2000向下擦除,但是我没有指定擦除的区域啊,有点不解。为什么?问:不用指定查出区域吗?求专业解答
还有
  4 952 bytes of readonly  code memory
     48 bytes of readwrite code memory
    752 bytes of readonly  data memory (+ 16 absolute)
      8 bytes of readwrite data memory
分别占用FLASH和RAM多少啊?怎么看啊?
我知道答案 目前已有11人回答
发表于 2015-11-27 11:23:34 | 显示全部楼层
建议楼主还是先到FLASH_EraseSector函数定义的地方,看看具体是怎么样的
  • 签到天数: 736 天
    发表于 2015-11-27 11:26:35 | 显示全部楼层
    帮顶一下
  • 签到天数: 736 天
    发表于 2015-11-27 11:26:58 | 显示全部楼层
    增加下知识,以后也会遇到这种问题
     楼主| 发表于 2015-11-27 12:04:41 | 显示全部楼层
    就是这个函数啊,
    uint16_t FLASH_EraseSector(uint32_t u32NVMTargetAddress)
            uint16_t u16Err = FLASH_ERR_SUCCESS;
            // Check address to see if it is aligned to 4 bytes
            // Global address [1:0] must be 00.
            if(u32NVMTargetAddress & 0x03)
                    u16Err = FLASH_ERR_INVALID_PARAM;
                    return (u16Err);
            // Clear error flags
            FTMRH->FSTAT = 0x30;
            // Write index to specify the command code to be loaded
            FTMRH->FCCOBIX = 0x0;
            // Write command code and memory address bits[23:16]
            FTMRH->FCCOBHI = FLASH_CMD_ERASE_SECTOR;// EEPROM FLASH command
            FTMRH->FCCOBLO = u32NVMTargetAddress>>16;// memory address bits[23:16]
            // Write index to specify the lower byte memory address bits[15:0] to be loaded
            FTMRH->FCCOBIX = 0x1;
            // Write the lower byte memory address bits[15:0]
            FTMRH->FCCOBLO = u32NVMTargetAddress;
            FTMRH->FCCOBHI = u32NVMTargetAddress>>8;
            // Launch the command
            FLASH_LaunchCMD(TRUE);
            // Check error status
            if(FTMRH->FSTAT & FTMRH_FSTAT_ACCERR_MASK)
                    u16Err |= FLASH_ERR_ACCESS;
            if(FTMRH->FSTAT & FTMRH_FSTAT_FPVIOL_MASK)
                    u16Err |= FLASH_ERR_PROTECTION;
            if(FTMRH->FSTAT & FTMRH_FSTAT_MGSTAT0_MASK)
                    u16Err |= FLASH_ERR_MGSTAT0;
            if(FTMRH->FSTAT & FTMRH_FSTAT_MGSTAT1_MASK)
                    u16Err |= FLASH_ERR_MGSTAT1;
    #if defined(CPU_KE02)
            if(FTMRH->FERSTAT & (FTMRH_FERSTAT_SFDIF_MASK))
                    u16Err |= EEPROM_ERR_SINGLE_BIT_FAULT;
            if(FTMRH->FERSTAT & (FTMRH_FERSTAT_DFDIF_MASK))
                    u16Err |= EEPROM_ERR_DOUBLE_BIT_FAULT;
    #endif
            return (u16Err);
    主程序是这样写
        FLASH_Init(BUS_CLK_HZ);
        /* Erase 99th sector */
        FLASH_EraseSector(fstart*FLASH_SECTOR_SIZE);
        但是我没有指定擦除的区域啊
    发表于 2015-11-27 12:38:17 | 显示全部楼层
    ke02不能擦除flash吧?
    发表于 2015-11-27 13:01:20 | 显示全部楼层
    发表于 2015-11-27 13:10:20 | 显示全部楼层
    学习一下
    发表于 2015-11-27 13:48:18 | 显示全部楼层
    kankanni 发表于 2015-11-27 12:04
    就是这个函数啊,
    你看看u32NVMTargetAddress这个变量的值
     楼主| 发表于 2015-11-27 14:11:54 | 显示全部楼层
    就是一个基地址,和例程一样,是32*512
    GMT+8, 2025-11-4 10:35 , Processed in 0.139851 second(s), 30 queries , MemCache On.
