查看: 7302|回复: 7
[求助] yocto编译出错! 求解决
发表于 2015-12-8 09:57:35 | 显示全部楼层 |阅读模式
demo板子imx6qsabresd
yocto编译命令如下
root@ubuntu:~/fsl-release-bsp/
MACHINE=imx6qsabresd source fsl-setup-release.sh -b build-x11 -e x11
bitbake fsl-image-gui
当天下午下班前开始编译,第2天早上结果报错
0: serf-native-1.3.7-r0 do_fetch (pid 20109)
$<50>ERROR: Fetcher failure: Fetch command failed with exit code 4, no output
Currently 1 running tasks (1721 of 6778):
$<50>ERROR: Function failed: Fetcher failure for URL: 'http://serf.googlecode.com/svn/src_releases/serf-1.3.7.tar.bz2'. Unable to fetch URL from any source.
$<50>ERROR: Logfile of failure stored in: /home/like/newWorkbank/fsl-release-bsp/build-x11/tmp/work/i686-linux/serf-native/1.3.7-r0/temp/log.do_fetch.20109
No currently running tasks (1721 of 6778)
$<50>ERROR: Task 5618 (virtual:native:/home/like/newWorkbank/fsl-release-bsp/sources/poky/meta/recipes-support/serf/serf_1.3.7.bb, do_fetch) failed with exit code '1'
$<50>NOTE: Tasks Summary: Attempted 1721 tasks of which 16 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There were 19 WARNING messages shown.
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
like@ubuntu:~/newWorkbank/fsl-release-bsp/build-x11$
查看build-x11/tmp/deploy/images/imx6qsabresd$ 目录下镜像只有zImage--3.14.28-r0-imx6qsabresd-20151207131645.bin 和几个dtb生成了,
没有看到uboot和rootfs生成,
请问是否
$<50>ERROR: Function failed: Fetcher failure for URL: 'http://serf.googlecode.com/svn/src_releases/serf-1.3.7.tar.bz2'. Unable to fetch URL from any source. 这句话导致 编译失败的,
我ping serf.googlecode.com 确实ping不通,有其他网址替代吗? ,请问如何解决这个问题,这玩意编译实在太耗时间,很是郁闷啊!!!
nnd顺便吐槽下这个编译时间,都要介么长吗,网络不好的小伙伴就被yocto坑了吗??
我知道答案 目前已有7人回答
  • 签到天数: 418 天
    发表于 2015-12-8 09:59:37 | 显示全部楼层
    不懂帮顶。。。。
  • 签到天数: 736 天
    发表于 2015-12-8 11:55:16 | 显示全部楼层
    帮顶一下
  • 签到天数: 28 天
    发表于 2015-12-9 14:00:01 | 显示全部楼层
    你需要某种淘宝搜不到的服务
  • 签到天数: 28 天
    发表于 2015-12-9 14:00:50 | 显示全部楼层
    哦,还有不低于4核i7的CPU
     楼主| 发表于 2015-12-9 14:04:25 | 显示全部楼层
    请问,是不是要vpn翻墙啊,linux ubuntn下怎么设置呢,我设置过总是访问不了外网
    昨天 20:26
  • 签到天数: 2543 天
    发表于 2015-12-9 14:58:57 | 显示全部楼层
    先看看。。。
    发表于 2015-12-29 17:07:26 | 显示全部楼层
    楼主你好,yocto的编译时间是有些长。
    GMT+8, 2025-10-29 02:15 , Processed in 0.101225 second(s), 29 queries , MemCache On.
