查看: 5186|回复: 4
[已解决] imx6 怎么增加16c554 串口啊 在那个文件下?
    发表于 2015-12-10 16:12:37 | 显示全部楼层 |阅读模式
    内核中 增加 8250选择项 但是没有映射的地址啊
    Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
    8250___________INIT__266
    8250___________probe
    Unable to handle kernel NULL pointer dereference at virtual address 00000020
    pgd = c0004000
    [00000020] *pgd=00000000
    求思路。。。。
    我知道答案 目前已有4人回答
    今天天气不错!签到!
  • 签到天数: 2602 天
    发表于 2015-12-10 22:09:14 | 显示全部楼层
    了解下。。。
    发表于 2015-12-11 08:56:41 | 显示全部楼层
    感谢分享
     楼主| 发表于 2015-12-24 15:48:46 | 显示全部楼层
    OK问题已解决。。。增加EIM片选。/* These registers settings are just valid for Numonyx M29W256GL7AN6E. */
    static void mx6q_setup_weimcs(void)
            void __iomem *nor_reg = MX6_IO_ADDRESS(WEIM_BASE_ADDR);
            void __iomem *ccm_reg = MX6_IO_ADDRESS(CCM_BASE_ADDR);
            unsigned int reg;
            struct clk *clk;
            u32 rate;
            /* CLKCTL_CCGR6: Set emi_slow_clock to be on in all modes */
            reg = readl(ccm_reg + 0x80);
            reg |= 0x00000C00;
            writel(reg, ccm_reg + 0x80);
            /* Timing settings below based upon datasheet for M29W256GL7AN6E
               These setting assume that the EIM_SLOW_CLOCK is set to 132 MHz */
            clk = clk_get(NULL, "emi_slow_clk");
            if (IS_ERR(clk))
                    printk(KERN_ERR "emi_slow_clk not found\n");
            rate = clk_get_rate(clk);
            if (rate != 132000000)
                    printk(KERN_ERR "Warning: emi_slow_clk not set to 132 MHz!"
                           " WEIM NOR timing may be incorrect!\n");
             * For EIM General Configuration registers.
             * CS0GCR1:
             *        GBC = 0; CSREC = 6; DSZ = 2; BL = 0;
             *        CREP = 1; CSEN = 1;
             *        EIM Operation Mode: MUM = SRD = SWR = 0.
             *                (Async write/Async page read, none multiplexed)
             * CS0GCR2:
             *        ADH = 1
            writel(0x00620081, nor_reg);
            writel(0x00000001, nor_reg + 0x00000004);
             * For EIM Read Configuration registers.
             * CS0RCR1:
             *        RWSC = 1C;
             *        RADVA = 0; RADVN = 2;
             *        OEA = 2; OEN = 0;
             *        RCSA = 0; RCSN = 0
             * CS0RCR2:
             *        APR = 1 (Async Page Read);
             *        PAT = 4 (6 EIM clock sycles)
            writel(0x1C022000, nor_reg + 0x00000008);
            writel(0x0000C000, nor_reg + 0x0000000C);
             * For EIM Write Configuration registers.
             * CS0WCR1:
             *        WWSC = 20;
             *        WADVA = 0; WADVN = 1;
             *        WBEA = 1; WBEN = 2;
             *        WEA = 1; WEN = 6;
             *        WCSA = 1; WCSN = 2;
             * CS0WCR2:
             *        WBCDD = 0
            writel(0x1404a38e, nor_reg + 0x00000010);
            writel(0x00000000, nor_reg + 0x00000014);
    6个寄存器的配置
    3364      writel(0x00660081, nor_reg + 0x00000000); 片选0  128M 映射空间 数据线16-23 8位的
    3365     writel(0x00000001, nor_reg + 0x00000004);
    3366     writel(0x1c022000, nor_reg + 0x00000008);
    3367     writel(0x0000C000, nor_reg + 0x0000000c);
    3368     writel(0x1404a38e, nor_reg + 0x00000010);
    3369     writel(0x00000000, nor_reg + 0x00000014);
    3370     writel(0x00000001, nor_reg + 0x90);
    3371     printk("GPR1__CSx____is____end%x\n",reg);
    今天天气不错!签到!
    发表于 2015-12-29 17:08:11 | 显示全部楼层
    杨帆!起航! 发表于 2015-12-24 15:48
    OK问题已解决。。。增加EIM片选。/* These registers settings are just valid for Numonyx M29W256GL7AN6E ...
    恭喜楼主问题已经解决,并热心分享解决方法。
    GMT+8, 2026-4-6 00:47 , Processed in 0.097087 second(s), 28 queries , Redis On.
