查看: 3492|回复: 8
[求助] KL05 如何控制IO接收信號中斷
发表于 2015-12-12 01:08:50 | 显示全部楼层 |阅读模式
請問KL05如何使用PE控制IO接收外部信號產生中斷,有無高手可以指導一下嗎??
我知道答案 目前已有8人回答
  • 签到天数: 736 天
    发表于 2015-12-12 11:24:15 | 显示全部楼层
    同问一下,对这个问题也不明白
    昨天 22:32
  • 签到天数: 2502 天
    连续签到: 3 天
    发表于 2015-12-13 10:55:22 | 显示全部楼层
    不是很懂,先了解下。。。
    发表于 2015-12-14 09:47:17 | 显示全部楼层
    帮顶
  • 签到天数: 736 天
    发表于 2015-12-14 10:00:14 | 显示全部楼层
    没有懂的人帮帮忙吗
    发表于 2015-12-14 11:07:18 | 显示全部楼层
    楼主你好!
    如果想直接使用PE的模块生成IO的接收中断,你可以使用GPIO_LDD模块,
    选择模块之后,右击模块选择help on component-> component GPIO_LDD Typical usage.
    这里面的典型应用中有关于中断的配置以及代码编写。
    发表于 2015-12-14 11:08:13 | 显示全部楼层
    GPIO_LDD
    Input signal alternation toggles output signal through external interruptThis example shows how to detect button pressing and change states light on/off of LED. There are used two components. First one is for pin configured as external interrupt and second one is for pin configured as output.
    Required component setup of GPIO1:
    • Interrupt service/event: Enabled
    • Bit fields: 1
    • Field name: Button
    • Initial pin direction: Input
    • Initial pin event: Falling edge or Rising edge
    • OnPortEvent: Enabled
    • Events: OnPortEvent
    Required component setup of GPIO2:
    • Interrupt service/event: Disabled
    • Bit fields: 1
    • Field name: Led
    • Initial pin direction: Output
    • Initial pin event: Disabled
    • Methods: ToggleFieldBits
    Content of ProcessorExpert.c:
    LDD_TDeviceData *MyGPIO1Ptr, *MyGPIO2Ptr;void main(void){  ...  MyGPIO1Ptr = GPIO1_Init((LDD_TUserData *)NULL);        /* Initialize the button pin */  MyGPIO2Ptr = GPIO2_Init((LDD_TUserData *)NULL);        /* Initialize the led pin */}Content of Event.c:
    extern LDD_TDeviceData *MyGPIO2Ptr;void GPIO1_OnPortEvent(LDD_TUserData *UserDataPtr){  GPIO2_ToggleFieldBits(MyGPIO2Ptr, Led, 0x1U);          /* Toggle led pin */}
     楼主| 发表于 2015-12-15 22:56:41 | 显示全部楼层
    FSL_TICS_ZJJ 发表于 2015-12-14 11:08
    GPIO_LDD
    Input signal alternation toggles output signal through external interruptThis example shows ...
    感謝!! 我在試看看
    发表于 2015-12-16 09:56:56 | 显示全部楼层
    不客气,后续如果还有问题,欢迎继续发帖交流。
    GMT+8, 2025-9-12 11:58 , Processed in 0.107689 second(s), 30 queries , MemCache On.
