查看: 5755|回复: 10
[求助] 请教下在K64上使用I2C的问题
发表于 2015-12-17 10:04:16 | 显示全部楼层 |阅读模式
大家好,
我现在使用I2C的时候碰到了些问题,就是我发出的I2C波形总是一样的,并不是我想发出的数,我用的是I2C_DRV_MasterSendDataBlocking(chan, &device,NULL, 0,pdata, 1, 200);这个函数,但是不管我怎么改变pdata的值,I2C的波形发出来的都是只有启动和截止位,中间全是零
电路板没有问题,我用了frdmk64f的实例程序“i2c_blocking_master_example_frdmk64f 也是这样的,发送的数值pdata怎么改,发出的波形都是如下图
我的代码是基于KSDK1.2,运行在MQX4.2上的,编译环境是KDS3.0
编码如下,请帮我看看哪里有问题?
void main_task( task_param_t init_data ){
    _task_id                 rx_tid;
    _task_id                 tx_tid;
    TASK_PARAMS              task_p = {0};
    uint8_t result = 0;
    uint8_t temp;
    hardware_init();
    OSA_Init();
    button_init();
    i2c_init(0);
    uint8_t i;
    uint8_t length = 10;
    uint8_t data[length];
    for(i = 0;i<length;i++){
    data = i;
    while(1){
    i2c_sendbuf(0,data,length);
    _time_delay(5);
_WEAK_FUNCTION(void hardware_init(void)) {
    uint8_t i;
    /* enable clock for PORTs */
    for (i = 0; i < PORT_INSTANCE_COUNT; i++)
      CLOCK_SYS_EnablePortClock(i);
    /* Init board clock */
    BOARD_ClockInit();
    /* In case IO sub is turned off, dbg console should be used for printing */
#if !BSPCFG_ENABLE_IO_SUBSYSTEM
    dbg_uart_init(); //wangyufei
#endif
void i2c_init(uint8_t chan){
    uint32_t i = 0;
    // i2c master state
    i2c_master_state_t master;
    // i2c device configuration
    configure_i2c_pins(0);
    configure_i2c_pins(1);
    // Initialize i2c master
    I2C_DRV_MasterInit(0, &master);
    I2C_DRV_MasterInit(1, &master);
int i2c_sendbuf(uint8_t chan,uint8_t *data,uint8_t length)
    uint32_t i = 0;
    i2c_status_t status1;
    uint8_t pdata[10];
    for(i = 0; i < DATA_LENGTH; i++)
        txBuff = i + 1;
    uint8_t result;
    for(i = 0;i<10;i++)
    pdata = i+3;
    pdata[0] = 0x80;
    pdata[1] = 0xF3;
    result = I2C_DRV_MasterSendDataBlocking(chan, &device,
                        pdata, 1,pdata, 2, 200);
        // Delay to wait slave received data
    OSA_TimeDelay(10);
    // _time_delay(5);
    pdata[0] = 0x81;
                        pdata, 1,pdata, 1, 200);
    // Clear rxBuff
    for(i = 0; i < count; i++)
        rxBuff = 0;
    // Master receives count byte data from slave
    result = I2C_DRV_MasterReceiveDataBlocking(chan, &device,
                                              NULL, 0, rxBuff, 1, 200);
    OSA_TimeDelay(5);
我知道答案 目前已有10人回答
发表于 2015-12-17 13:52:44 | 显示全部楼层
楼主,你好!
我刚看了下FRDM-K64的KSDK I2C 代码:
C:\Freescale\KSDK_1.3.0\examples\frdmk64f\driver_examples\i2c\i2c_blocking
也就是使用
        I2C_DRV_MasterSendDataBlocking(BOARD_I2C_INSTANCE, &device,
                        (const uint8_t*)&count, 1, (const uint8_t*)txBuff, count, 1000);
这里你要注意下,这个函数每次都会先发一个自己的地址,后面才是数据字节。
也就是,如果count=1, 那么实际上发的是两个字节,第一个是地址字节,由device结构体配置,
    i2c_device_t device =
      .address = 0x7FU,
      .baudRate_kbps = 400   // 400 Kbps
发送的时候,address还要左移一位,也就是发0XFF。
第二个字节才是真正的数据字节。
所以,你这边看到的实际上是地址字节,还没有看到后面的数据字节。
而且发多字节的时候,一定要注意连上从机,因为如果没有从机的ACK的话,后面的数据字节就不会发送,只会发一个地址字节就结束了。
如果连上从机,并且接到地址字节后,回了ACK,函数才会继续发下面的数据字节。
更多详情,你可以用两个K64板子链接,然后分别烧录主机,从机,抓取I2C总线上的通信数据。
虽然上面讲的不是MQX的,是bare board的,但是对于KSDK里面的I2C_DRV_MasterSendDataBlocking函数,是一样的。
回复 支持 1 反对 0
发表于 2015-12-17 12:38:52 | 显示全部楼层
帮顶  有点难度
    发表于 2015-12-17 12:47:01 | 显示全部楼层
    估计是你没有配置好
    发表于 2015-12-17 13:57:22 | 显示全部楼层
    这里给出我的测试波形,发一个字节,主从机连接:
    如果从机不连接,第一个地址字节是NACK,不会有后面的数据字节了。
  • 签到天数: 736 天
    发表于 2015-12-17 15:54:58 | 显示全部楼层
    学习一下,版主回答的很到位
    发表于 2015-12-17 21:20:27 | 显示全部楼层
    我觉得FSL_TICS_ZJJ的解释应该是正理
  • 签到天数: 6 天
    发表于 2015-12-18 08:24:16 | 显示全部楼层
    如果从机不连接,第一个地址字节是NACK,不会有后面的数 ...
    这是用的示波器吗?
     楼主| 发表于 2015-12-18 09:20:08 | 显示全部楼层
    是这样的,昨天已经搞定了,地址应该是需要右移一位,因为函数里面会做左移一位的操作~
    发表于 2015-12-18 10:00:49 | 显示全部楼层
    modou0 发表于 2015-12-18 08:24
    这是用的示波器吗?
    我给出的波形是示波器的,你也可以使用逻辑分析仪。
    数据多的时候,肯定用逻辑分析仪方便,可以直接查看包数据。
    示波器就需要自己一个一个看,而且抓取数据有限。
    GMT+8, 2025-11-3 11:57 , Processed in 0.099581 second(s), 31 queries , MemCache On.
