查看: 1643|回复: 1
[求助] KinetisUpdater找不到串口
发表于 2015-12-23 15:44:52 | 显示全部楼层 |阅读模式
KinetisUpdater在我电脑上能使用,但在我同事电脑上不能打开,
装了.NET 4.5之后软件能打开了,但找不到串口,设备管理器里面是有串口的。
急呀,他明天要出差。
我知道答案 目前已有1人回答
发表于 2015-12-23 17:01:57 | 显示全部楼层
看看这两个note:
NOTE
If the application fails to launch, check that the .NET Framework 4.5 and the
Visual C++ Redistributable 2013 are installed as noted in Toolchain requirements.
NOTE
Ensure that the x86 version of the package is installed, not x64 version. This even
applies for 64-bit systems.
你都满足了吗?
GMT+8, 2025-11-3 11:51 , Processed in 0.090340 second(s), 22 queries , MemCache On.
