查看: 2699|回复: 3
[MPC] ubuntu15.10 mpc8308 ltib出错
发表于 2015-12-30 20:25:53 | 显示全部楼层 |阅读模式
host_config.log:
Processing platform: Host support packages
using /home/ltib-mpc8308erdb-20100413/config/platform/host/ltib.preconfig
Processing: fake-provides
Processing: mkspooflinks
Processing: distcc
Processing: ccache
Processing: bison
Processing: flex
Processing: texinfo
Processing: autoconf
Processing: libtool
Processing: lkc
Build path taken because: directory build, no prebuilt rpm,
Cowardly refusing to clobber existing directory:
/opt/freescale/ltib/usr/src/rpm/BUILD/lkc-1.4
Remove this by hand if you really want to rebuild this package from scratch
Died at ./ltib line 1380.
traceback:
main::build_host_rpms:1380
  main::host_checks:1435
   main:542
Started: Wed Dec 30 20:14:57 2015
Ended:   Wed Dec 30 20:14:57 2015
Elapsed: 0 seconds
These packages failed to build:
lkc
Build Failed
修改menu.c
inline int next_id(int id, bool forward)  to int next_id(int id, bool forward)
gcc -O -Wall -g -fPIC -c conf.c -o conf.o
bison -l -b zconf -p zconf zconf.y
flex -L -Pzconf zconf.l
gcc -O0 -Wall -g -fPIC -c zconf.tab.c -o zconf.tab.o
gcc  conf.o zconf.tab.o -o conf
gcc -O0 -Wall -g -fPIC -c mconf.c -o mconf.o
cd lxdialog && make
make[1]: Entering directory '/opt/freescale/ltib/usr/src/rpm/BUILD/lkc-1.4/lxdialog'
cc  -DCURSES_LOC="<ncurses.h>" -I. -c checklist.c -o checklist.o
cc  -DCURSES_LOC="<ncurses.h>" -I. -c menubox.c -o menubox.o
cc  -DCURSES_LOC="<ncurses.h>" -I. -c textbox.c -o textbox.o
cc  -DCURSES_LOC="<ncurses.h>" -I. -c yesno.c -o yesno.o
cc  -DCURSES_LOC="<ncurses.h>" -I. -c inputbox.c -o inputbox.o
cc  -DCURSES_LOC="<ncurses.h>" -I. -c util.c -o util.o
cc  -DCURSES_LOC="<ncurses.h>" -I. -c msgbox.c -o msgbox.o
ar rc lxdialog.a checklist.o menubox.o textbox.o yesno.o inputbox.o util.o msgbox.o
ranlib lxdialog.a
make[1]: Leaving directory '/opt/freescale/ltib/usr/src/rpm/BUILD/lkc-1.4/lxdialog'
gcc   mconf.o zconf.tab.o lxdialog/lxdialog.a -o mconf -lncurses
修改后编译正常,但ltib运行还是存在问题。
主要是使用ubuntu15.10 64位存在这样的问题,有人在这个系统上运行成功过吗?
 楼主| 发表于 2015-12-30 20:30:09 | 显示全部楼层
请工程师帮忙确认一下,是否因为系统ltib安装存在问题?
 楼主| 发表于 2015-12-31 15:48:46 | 显示全部楼层
有工程师帮忙试一下吗?或者论詓里有遇到这种问题吗?
 楼主| 发表于 2015-12-31 16:04:44 | 显示全部楼层
说明:ubuntu10.04LTS安装是没有问题的!
GMT+8, 2026-4-9 03:01 , Processed in 0.091148 second(s), 25 queries , Redis On.
