在线时间128 小时
UID2091686
注册时间2014-5-7
NXP金币0
TA的每日心情 | 开心 2017-4-27 08:44 |
签到天数: 64 天 连续签到: 1 天 [LV.6]常住居民II
- 1703
- 1970-1-1
楼主 |
发表于 2016-1-12 13:58:36
显示全部楼层
另外我使用IAR 编译debug下载时提示如下warning:
Tue Jan 12, 2016 13:54:13: Loaded macro file: C:\Program Files\IAR Systems\Embedded Workbench 6.5\arm\config\flashloader\Freescale\FlashKLxx.mac
Tue Jan 12, 2016 13:54:13: JLINK command: ProjectFile = E:\Project\KL03Z_MCU\iar\settings\app_Debug.jlink, return = 0
Tue Jan 12, 2016 13:54:13: Device "UNSPECIFIED" selected (0 KB flash, 0 KB RAM).
Tue Jan 12, 2016 13:54:13: DLL version: V4.92
Tue Jan 12, 2016 13:54:13: Firmware: J-Link ARM V8 compiled Nov 28 2014 13:44:46
Tue Jan 12, 2016 13:54:13: Selecting SWD as current target interface.
Tue Jan 12, 2016 13:54:13: JTAG speed is initially set to: 1000 kHz
Tue Jan 12, 2016 13:54:13: Found SWD-DP with ID 0x0BC11477
Tue Jan 12, 2016 13:54:13: Found Cortex-M0 r0p1, Little endian.
Tue Jan 12, 2016 13:54:13: FPUnit: 2 code (BP) slots and 0 literal slots
Tue Jan 12, 2016 13:54:13: Hardware reset with strategy 0 was performed
Tue Jan 12, 2016 13:54:13: Initial reset was performed
Tue Jan 12, 2016 13:54:14: ----- Prepare hardware for Flashloader -----
Tue Jan 12, 2016 13:54:14: 768 bytes downloaded and verified (9.62 Kbytes/sec)
Tue Jan 12, 2016 13:54:14: Loaded debugee: C:\Program Files\IAR Systems\Embedded Workbench 6.5\arm\config\flashloader\Freescale\FlashKLxx2K.out
Tue Jan 12, 2016 13:54:14: Target reset
Tue Jan 12, 2016 13:54:14: Downloaded E:\Project\KL03Z_MCU\app\Exe\app.out to flash memory.
Tue Jan 12, 2016 13:54:14: Hardware reset with strategy 0 was performed
Tue Jan 12, 2016 13:54:15: 9016 bytes downloaded into FLASH and verified (8.05 Kbytes/sec)
Tue Jan 12, 2016 13:54:15: Warning:
Verify error at address 0x0000040D, target byte: 0xFF, byte in file: 0x3D
Tue Jan 12, 2016 13:54:16: Warning: There were warnings during download, see Log Window
Tue Jan 12, 2016 13:54:16: Loaded debugee: E:\Project\KL03Z_MCU\app\Exe\app.out
Tue Jan 12, 2016 13:54:16: Hardware reset with strategy 0 was performed
Tue Jan 12, 2016 13:54:16: Target reset
Tue Jan 12, 2016 13:54:16: There was 1 warning during the initialization of the debugging session.
这个是怎么回事,有谁遇到过吗? |
