查看: 2150|回复: 1
mc9s08pa32 修改堆栈问题
发表于 2016-1-25 14:37:30 | 显示全部楼层 |阅读模式
/* This is a linker parameter file for the mc9s08pa32 */
NAMES END /* CodeWarrior will pass all the needed files to the linker by command line. But here you may add your own files too. */
SEGMENTS /* Here all RAM/ROM areas of the device are listed. Used in PLACEMENT below. */
    Z_RAM                    =  READ_WRITE   0x0048 TO 0x00FF;
    RAM                      =  READ_WRITE   0x0100 TO 0x07FF;
    SS_RAM                      =  READ_WRITE   0x0800 TO 0x103F; /********/
    ROM                      =  READ_ONLY    0x8000 TO 0xFF6F;
    ROM1                     =  READ_ONLY    0xFF80 TO 0xFFAF;
    EEPROM                   =  READ_ONLY    0x3100 TO 0x31FF;
/* INTVECTS                 =  READ_ONLY    0xFFB0 TO 0xFFFF; Reserved for Interrupt Vectors */
END
PLACEMENT /* Here all predefined and user segments are placed into the SEGMENTS defined above. */
    FAR_RAM                      /* non-zero page variables */
                                        INTO  RAM;
    SSTACK                              INTO  SS_RAM;  /*********/
    _PRESTART,                          /* startup code */
    STARTUP,                            /* startup data structures */
    ROM_VAR,                            /* constant variables */
    STRINGS,                            /* string literals */
    VIRTUAL_TABLE_SEGMENT,              /* C++ virtual table segment */
    DEFAULT_ROM,
    COPY                                /* copy down information: how to initialize variables */
                                        INTO  ROM; /* ,ROM1: To use "ROM1" as well, pass the option -OnB=b to the compiler */
    _DATA_ZEROPAGE,                     /* zero page variables */
    MY_ZEROPAGE, DEFAULT_RAM            INTO  Z_RAM;
END
STACKSIZE 0x200
VECTOR 0 _Startup /* Reset vector: this is the default entry point for an application. */
/*******/部分为改动部分,改动后程序运行不正常,请问错误的地方?
发表于 2016-1-26 09:20:33 | 显示全部楼层
那请问楼主改动的目标是什么呢,以及具体改动了哪些呢?
GMT+8, 2026-4-15 19:51 , Processed in 0.089839 second(s), 21 queries , Redis On.
