查看: 5366|回复: 6
[求助] uboot lvds依然没有24bit输出,是不是还有什么没修改
发表于 2016-2-4 15:16:22 | 显示全部楼层 |阅读模式
我是参考这个修改的:http://community.freescale.com/docs/DOC-93617
Uboot splash screen:
   Change should be done in board file, like board/freescale/mx6q_sabresd/mx6q_sabresd.c:
   1. Set video mode in struct fb_videomode according to the new 24bit LVDS display panel’s spec(please, refer to the example at the end of this doc).
   2. Set up pwm, iomux/display related clock trees in lcd_enable(). Note that these should be aligned with Kernel settings to support smooth UI transition
       from Uboot splash screen to Kernel framebuffer.
   3. Set the output pixel format of IPUv3 display engine and LDB to IPU_PIX_FMT_RGB24 when calling ipuv3_fb_init().
   4. Set pixel clock according to the new 24bit LVDS display panel’s spec when calling ipuv3_fb_init().
   5. If dual LDB channels are needed to support tough display video mode(high resolution or high pixel clock frequency), we need to enable both of the two LDB
       channels and set LDB to work at split mode. LDB_CTRL register should be set accordingly in lcd_enable().
我修改的内容以下:
static struct fb_videomode lvds_xga = {
        "LDB-1280x800", 60, 1280, 800, 14065, 40, 40, 10, 3, 80, 10,
        FB_SYNC_EXT,
        FB_VMODE_NONINTERLACED,
        0,
ret = ipuv3_fb_init(&lvds_xga, di, IPU_PIX_FMT_RGB24,
                        DI_PCLK_LDB, 65000000);
BSP是L3.0.35的,现在内核logo正确显示了,uboot能显示,但是蒙蒙的,我是不是漏了哪里没有改?
我知道答案 目前已有6人回答
 楼主| 发表于 2016-2-4 15:35:30 | 显示全部楼层
@FSL_TICS_ZJJ
发表于 2016-2-5 10:03:12 | 显示全部楼层
楼主你好!
我会帮你转给我们的I.MX工程师,他会帮你解答,还请耐心等待下!
 楼主| 发表于 2016-2-5 18:47:02 | 显示全部楼层
FSL_TICS_ZJJ 发表于 2016-2-5 10:03
楼主你好!
我会帮你转给我们的I.MX工程师,他会帮你解答,还请耐心等待下! ...
先谢谢
发表于 2016-2-17 18:27:46 | 显示全部楼层
楼主你好,请问你这里使用的是哪个版本的BSP,板子是你自己设计的还是买的开发板?
 楼主| 发表于 2016-2-17 22:55:33 | 显示全部楼层
FSL_TICS_Rita 发表于 2016-2-17 18:27
楼主你好,请问你这里使用的是哪个版本的BSP,板子是你自己设计的还是买的开发板? ...
BSP3.0.35,板是参考mx6qsabresd设计的
发表于 2016-11-4 22:29:50 | 显示全部楼层
楼主问题解决了吗?
GMT+8, 2026-4-12 02:45 , Processed in 0.107247 second(s), 28 queries , Redis On.
