查看: 3185|回复: 3
[求助] imx6d DDR2 2channel Fixed 3x32 Issue
发表于 2016-3-1 18:03:58 | 显示全部楼层 |阅读模式
Hi All,
We need some help for imx6 LPDDR2 dual-channel bring up.
Now board has passed ddr2 stress test,but if integrate new DCD cfg to u-boot and generate u-boot.imx,failed to download
it to board through mfgtools.mfgtools stop in "downloading u-boot".any can give some help?
DDR Config:Fixed 32x2 Config,
EDB8132B4PM: 256 Meg x 32@
DDR Chip:2 chip,1GB * 2, 8banks
If use DDR2 1 channel config,u-boot/kernel can run successfully in DDR2 400.
1)DDR datasheet
2)Micron-edb8132b4pm-0.04-2ch-2cs-400M-34ohm.inc (DDR test tool init script)
3)2ch_edb8132b4pm.cfg  ==u-boot use DCD cfg
4)hw-ddr2-layout.pdf (hardware DDR layout)
5)Mx6DQSDL LPDDR2 Script Aid V0.04-Micron EDB8132B4PM.xlsx aid script
相关文件可以从:http://community.freescale.com/message/620049#620049 下载。
 楼主| 发表于 2016-3-7 11:08:45 | 显示全部楼层
已经解决!
发表于 2016-3-21 17:38:52 | 显示全部楼层
恭喜楼主问题已经解决,欢迎有问题继续在本论坛中交流讨论哈
发表于 2016-3-21 17:39:00 | 显示全部楼层
GMT+8, 2026-4-16 19:25 , Processed in 0.091642 second(s), 24 queries , Redis On.
