查看: 3886|回复: 1
[S12] 用单片机mc9s12zvl的AD模块控制PWM调光一直不对,求各位大神...
发表于 2016-3-4 17:02:59 | 显示全部楼层 |阅读模式
用s12zvl的AN7口做AD口,硬件接的是一个光度传感器,控制PT3脚的PWM占空比,一直没有成功。请教一下各位大神
#include <hidef.h> /* forEnableInterrupts macro */
#include "derivative.h" /* includeperipheral declarations */
typedef unsigned char bool;
#define ERR_OK           0;
#define ERR_NOTAVAIL    9U;
static volatile word RVL[1] __attribute__ ((aligned (4)));
static volatile bool OutFlg;
static word RatioStore;
char BLUE;
byte* i;
static void SetRatio(void)
  PWMDTY1 = (byte)(((0xFFUL * (dword)RatioStore) + 0x8000UL) >> 0x10U); /* Calculate new value according to the given ratio */
byte PWM_BLUE_SetRatio8(byte Ratio)
  RatioStore = (((word)Ratio << 8U) + 0x80U); /* Store new value of the ratio */
  SetRatio();                          /* Calculate and set up new appropriate values of theduty and period registers */
  return ERR_OK;                       /* OK */
void PWM_BLUE_Init(void)
    PWMCNT1 = 0x00;
    PWMDTY1 = 0x9F;
    PWMPER1 = 0xFF;
    PWMPRCLK = 0x00;
    PWMSCLA = 0x3B;
    PWMCLK = 0x02;
    PWME = 0x02U;
void ADC_Init(void)
    ADC0CTL=0x8800;
    ADC0TIM=0x07;
    ADC0FMT=0x00;
    ADC0CMD=0x00170000;
    ADC0STS=0X01;
    ADC0TIM=0X07;
    ADC0CONIE=0x01;
ADC0CONIF=0X01;
ADC0CROFF1=0x00;
ADC0EIF=0x06;
ADC0EIE=0xFC;
    ADC0IF=0xC0;
ADC0IE=0xC0;
byte ADC_GetValue8(byte *Values)
  if (!OutFlg){                       /* Is measured value(s) available? */
    return ERR_NOTAVAIL;               /* If no then error */
    *Values = (byte)(RVL[0] >> 0x02U);   /* Storeconversion data to user buffer */
void main(void) {
     PWM_BLUE_Init();
     ADC_Init();
  EnableInterrupts;
  /* includeyour code here */
//for(;;)
    BLUE=ADC_GetValue8(i);
  PWM_BLUE_SetRatio8(BLUE);
  for(;;) {
    __RESET_WATCHDOG();  /* feeds the dog */
  } /* loopforever */
  /* pleasemake sure that you never leave main */
我知道答案 目前已有1人回答
发表于 2016-3-7 10:56:23 | 显示全部楼层
非常感谢你的技术问题。非常抱歉中国没有16位单片机方面的技术专家。请您在飞思卡尔的英文论坛提交请求。网址是http://community.freescale.com/welcome 谢谢。
GMT+8, 2026-4-18 00:40 , Processed in 0.083559 second(s), 22 queries , Redis On.
