查看: 4691|回复: 3
[讨论] [FRDM KL27Z] KL27自带ROM bootloader
  • 签到天数: 64 天
    发表于 2016-3-7 18:38:31 | 显示全部楼层 |阅读模式
    看了下KL27Z的手册,介绍自带ROM bootloader,支持多种通信方式与上位机交互升级。
    file:///C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\msohtmlclip1\01\clip_image002.jpg
    期待!
  • 签到天数: 64 天
     楼主| 发表于 2016-3-7 18:40:02 | 显示全部楼层
    Chapter 11
    Kinetis ROM Bootloader
    11.1 Chip-Specific Information
    This device has various peripherals (UART, I2C, SPI ) supported by the Kinetis ROM
    Bootloader. To use an interface for bootloader communications, the peripheral must be
    enabled in the BCA, as shown in Table 11-3. If the BCA is invalid (such as all 0xFF
    bytes), then all peripherals will be enabled by default.The next table shows the pads used
    by the Kinetis ROM Bootloader.
    Table 11-1. Kinetis Bootloader Peripheral Pinmux
    Port Signal
    PTB0 SPI0_SCK
    PTB1 LPUART0_TX
    PTB2 LPUART0_RX
    PTB3 I2C0_SCL
    PTB4 I2C0_SDA
    PTA5 SPI0_SS_b
    PTA6 SPI0_MISO
    PTA7 SPI0_MOSI
    发表于 2016-3-9 15:17:35 | 显示全部楼层
    什么意思没有明白?是要分享报告吗?
    发表于 2016-3-11 08:56:03 | 显示全部楼层
    学习了
    GMT+8, 2025-10-25 01:00 , Processed in 0.093860 second(s), 23 queries , MemCache On.
