查看: 3123|回复: 2
[求助] Android 5.1 在imx6q上的移植kernel该如何配置?
发表于 2016-3-10 11:22:07 | 显示全部楼层 |阅读模式
u-boot已经能够跑起来了,目前移植kernel有点问题,log如下,停在了start kernel:
U-Boot 2015.04-14409-g6cf684a-dirty (Feb 26 2016 - 10:05:01)
CPU:   Freescale i.MX6Q rev1.5 at 792 MHz
CPU:   Temperature 19 C
Reset cause: POR
Board: MX6-SabreSD
I2C:   ready
DRAM:  2 GiB
PMIC:  PFUZE100 ID=0x10
MMC:   FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2
*** Warning - bad CRC, using default environment
No panel detected: default to Hannstar-XGA
Display: Hannstar-XGA (1024x768)
In:    serial
Out:   serial
Err:   serial
check_and_clean: reg 0, flag_set 0
Fastboot: Normal
flash target is MMC:1
Net:   Phy 1 not found
PHY reset timed out
FEC [PRIME]
Error: FEC address not set.
Normal Boot
boota mmc1
kernel   @ 14008000 (7272264)
ramdisk  @ 15000000 (868699)
fdt      @ 14f00000 (44216)
endp:
## Current stack ends at 0x8ef3cbf0 ## Booting Android Image at 0x12000000 ...
Kernel load addr 0x14008000 size 7102 KiB
Kernel command line: console=ttymxc1,115200 init=/init video=mxcfb0:dev=ldb,bpp=32 video=mxcfb1ff video=mxcfb2ff video=mxcfb3ff vmalloc=256M androidboot.console=ttymxc1 consoleblank=0 androidboot.hardware=freescale cma=384M
   kernel data at 0x12000800, len = 0x006ef748 (7272264)
*  fdt: cmdline image address = 0x14f00000
## Checking for 'FDT'/'FDT Image' at 14f00000
*  fdt: raw FDT blob
## Flattened Device Tree blob at 14f00000
   Booting using the fdt blob at 0x14f00000
   of_flat_tree at 0x14f00000 size 0x0000acb8
   Loading Kernel Image ... OK
   kernel loaded at 0x14008000, end = 0x146f7748
using: FDT
   Using Device Tree in place at 14f00000, end 14f0dcb7
switch to ldo_bypass mode!
## Transferring control to Linux (at address 14008000)...
Starting kernel ...
编译boot.img的时候选择的是sabresd_6dq-eng
kernel中uart也改过了
现在无法确定是dts有问题还是uart配置不对,本来想reset之后在u-boot阶段dump ddr的信息,
无奈reset之后没抓到log,看上去像是code reset了。
请问该如何移植kernel呢?
我知道答案 目前已有2人回答
发表于 2016-3-21 17:43:44 | 显示全部楼层
楼主你好,建议你参考我们官网提供的porting文档,我们官网没有单独关于android版本BSP的移植文档,那你可以参考linux BSP 版本中的porting文档,都是差不多的。
发表于 2016-3-22 10:26:20 | 显示全部楼层
stary666 发表于 2016-3-21 19:04
看看,,,,,,,
欢迎有问题在本论坛中交流讨论哈~~
GMT+8, 2025-10-28 12:13 , Processed in 0.086492 second(s), 22 queries , MemCache On.
