查看: 6854|回复: 6
[已解决] 新手求助,IMX6ULEVK开发板程序下载问题!!
发表于 2016-4-7 10:44:49 | 显示全部楼层 |阅读模式
新手,刚接触这款开发板,现在下载程序遇到问题:
到手的开发板为空板,我按说明使用MfgTool下载开发板程序,按要求连接好开发板后,我先是下载的:mfgtool2-yocto-mx-evk-sdcard-sd1.vbs,但提示到/dev/mmcblk0p1: No such file or directory后就没有反应了,下载失败;然后联系FAE说是下载的文件错了,要用mfgtool2-yocto-mx-14x14-arm2-sdcard-sd1.vbs的,但还是提示 Jumping to OS image后没有反应。我的Bsp是在官网下载的L3.14.38_6ul-ga_mfg-tools.tar.gz
我知道答案 目前已有6人回答
 楼主| 发表于 2016-4-7 10:51:25 | 显示全部楼层
补充一下两次烧写时串口打印的信息:
烧写mfgtool2-yocto-mx-14x14-arm2-sdcard-sd1.vbs时:U-Boot 2015.04-imx_v2015.04_3.14.38_6ul_ga+g5d63276 (Aug 18 2015 - 21:04:28)
CPU:   Freescale i.MX6UL rev1.0 at 396 MHz
CPU:   Temperature 38 C
Reset cause: POR
Board: MX6UL 14X14 DDR3 ARM2
I2C:   ready
DRAM:  1 GiB
force_idle_bus: sda=0 scl=0 sda.gp=0x3 scl.gp=0x2
Can't find PMICFUZE100
initcall sequence bff93d00 failed at call 87802e30 (err=-1)
### ERROR ### Please RESET the board ###
烧写mfgtool2-yocto-mx-evk-sdcard-sd1.vbs时:
前面省略……
   Device Boot Start   End    MiB    #blocks   Id  System
/dev/mmcblk0p1         7+   509-   503-    514080    c  W95 FAT32 (LBA)
/dev/mmcblk0p2       596+   596-     0          0   83  Linux
/dev/mmcblk0p3         0      -      0          0    0  Empty
/dev/mmcblk0p4         0      -      0          0    0  Empty
sfdisk: Warning: partition 2 has size 0 but is not marked Empty
sfdisk: Warning: partition 1 extends past end of disk
Successfully wrote the new partition table
sfdisk: If you created or changed a DOS partition, /dev/foo7, say, then use dd(1)
to zero the first 512 bytes:  dd if=/dev/zero of=/dev/foo7 bs=512 count=1
(See fdisk(8).)
UTP: sending Success to kernel for command $ sh mksdcard.sh /dev/mmcblk0.
utp_poll: pass returned.
UTP: received command 'send'
UTP: sending Success to kernel for command send.
UTP: received command '$ dd if=/dev/zero of=/dev/mmcblk0 bs=1k seek=384 conv=fsync count=129'
UTP: executing "dd if=/dev/zero of=/dev/mmcblk0 bs=1k seek=384 conv=fsync count=129"
129+0 records in
129+0 records out
132096 bytes (132 kB) copied, 0.002673 s, 49.4 MB/s
UTP: sending Success to kernel for command $ dd if=/dev/zero of=/dev/mmcblk0 bs=1k seek=384 conv=fsync count=129.
UTP: received command '$ dd if=$FILE of=/dev/mmcblk0 bs=1k seek=1 conv=fsync'
UTP: executing "dd if=$FILE of=/dev/mmcblk0 bs=1k seek=1 conv=fsync"
351+0 records in
351+0 records out
359424 bytes (359 kB) copied, 0.008344 s, 43.1 MB/s
UTP: sending Success to kernel for command $ dd if=$FILE of=/dev/mmcblk0 bs=1k seek=1 conv=fsync.
UTP: received command '$ mkfs.vfat /dev/mmcblk0p1'
UTP: executing "mkfs.vfat /dev/mmcblk0p1"
mkfs.vfat 2.11 (12 Mar 2005)
UTP: sending Non-success to kernel for command $ mkfs.vfat /dev/mmcblk0p1.
utp_poll: exit with status 256
发表于 2016-4-13 17:18:28 | 显示全部楼层
楼主你好,请问你这里是要下载到哪个Flash上啊,sd card?
发表于 2016-4-21 16:10:19 | 显示全部楼层
使用mfgtool2-yocto-mx-evk-sdcard-sd2.vbs就可以了,《IMX6ULTRALITEQSG.pdf》文档中有说明,详细看看 IMX6ULTRALITEQSG.pdf (1.57 MB, 下载次数: 58)
发表于 2016-4-22 16:52:30 | 显示全部楼层
楼上正解,楼主按照文档操作就OK,有问题我们再沟通哈。
 楼主| 发表于 2016-5-4 12:51:56 | 显示全部楼层
抱歉,最近一直在忙!
已经解决了,是SD卡容量的问题,我用了一个2G的内存卡。
谢谢!
发表于 2016-5-5 11:43:45 | 显示全部楼层
FSL新手学徒 发表于 2016-5-4 12:51
抱歉,最近一直在忙!
谢谢! ...
不客气的,很高兴楼主问题已经解决,欢迎有问题继续在我们论坛中交流讨论哈
GMT+8, 2026-4-19 23:33 , Processed in 0.108665 second(s), 28 queries , Redis On.
