查看: 3902|回复: 2
[MPC] MPC5646C 测试SPI PCR端如何配置?感激不尽
发表于 2016-4-8 17:06:30 | 显示全部楼层 |阅读模式
各位大神好,
       我是一个初学者,学习也是工作的一部分,附件是代码,想测试SPI通信,但看了官方的手册还是云里雾里的,
       对于DSPI PIN角的配置不太明白,请指教,在下感激不尽,例如下面代码:
SIU.PCR[13].R = 0x1204;        /* MPC56xxB: Config pad as DSPI_0 SOUT output */
  SIU.PCR[12].R = 0x0106;        /* MPC56xxB: Config pad as DSPI_0 SIN input */
  SIU.PCR[14].R = 0x1204;        /* MPC56xxB: Config pad as DSPI_0 SCK output */
  SIU.PSMI[5].R = 1;             /* MPC56xxB: Select PCR 14 for DSPI_0 SCK output */
  SIU.PCR[15].R = 0x1204;        /* MPC56xxB: Config pad as DSPI_0 PCS0 output */
  SIU.PSMI[6].R = 1;             /* MPC56xxB: Select PCR 15 for DSPI_0 SS output */
我知道答案 目前已有2人回答
demoGD5646C_DSPI.zip
180.63 KB, 下载次数: 7, 下载积分: 威望 1
模板代码
 楼主| 发表于 2016-4-11 14:29:58 | 显示全部楼层
问题已经解决,下面代码是已经验证过的,感谢关注!
void initDSPI_0(void) {
  DSPI_0.MCR.R = 0x80010001;     /* Configure DSPI_0 as master */
  DSPI_0.CTAR[0].R = 0x780A7727; /* Configure CTAR0  */
  DSPI_0.MCR.B.HALT = 0x0;             /* Exit HALT mode: go from STOPPED to RUNNING state*/
  SIU.PCR[13].R = 0x0604;        /* MPC5646C: Config pad as DSPI_0 SOUT output */
  SIU.PCR[12].R = 0x0103;        /* MPC5646C: Config pad as DSPI_0 SIN input */
  SIU.PCR[14].R = 0x0604;        /* MPC5646C: Config pad as DSPI_0 SCK output */
  SIU.PCR[15].R = 0x0604;        /* MPC5646C: Config pad as DSPI_0 PCS0 output */
void initDSPI_1(void) {
  DSPI_1.MCR.R = 0x00010001;     /* Configure DSPI_1 as slave */
  DSPI_1.CTAR[0].R = 0x01EE;     /* Configure CTAR0  */
  DSPI_1.MCR.B.HALT = 0x0;             /* Exit HALT mode: go from STOPPED to RUNNING state*/
  SIU.PCR[68].R = 0x0903;        /* MPC5646C: Config pad as DSPI_1 SCK input */
  SIU.PSMI[7].R = 1;             /* MPC5646C: Select PCR 68 for DSPI_1 SCK input */
  SIU.PCR[36].R = 0x0103;        /* MPC5646C: Config pad as DSPI_1 SIN input */
  SIU.PSMI[8].R = 0;             /* MPC5646C: Select PCR 8 for DSPI_1 SIN input */
  SIU.PCR[37].R = 0x0604;        /* MPC5646C: Config pad as DSPI_1 SOUT output*/
  SIU.PCR[69].R = 0x0903;        /* MPC5646C: Config pad as DSPI_1 PCS0/SS input */
  SIU.PSMI[9].R = 2;             /* MPC5646C: Selec PCR 15 for DSPI_1 SS input */
发表于 2016-4-11 14:42:55 | 显示全部楼层
恭喜楼主解决问题,参考一下
GMT+8, 2026-4-17 02:52 , Processed in 0.077970 second(s), 26 queries , Redis On.
