查看: 3870|回复: 0
[S12] MC9S12G系列芯片,FLASH擦写时能开总中断吗?
  • 签到天数: 39 天
    发表于 2016-4-22 09:27:56 | 显示全部楼层 |阅读模式
    求助线上FAE FLASH擦写可以开中断吗(所用芯片是MC9S12G48)?因为擦(PFLASH)FLASH Sector时有好几十毫秒延时,关了总中断,定时器的定时时间就会有偏差,还有CallFnCmdInRam这个函数,为什么擦FLASH时要放到RAM执行,顺便发送一份擦FLASH的函数代码给予那些FLASH擦写没函数的学友们。
    byte IFsh1_EraseSector(IFsh1_TAddress Addr)
      if (BlockOutOfRange(Addr, Addr)) {   /* Check range of address */
        return(ERR_RANGE);
      EnterCritical();                     /* Enter critical section */
      ClearFlags();                        /* Clear all flags */
      if (FSTAT_CCIF == 0U) {              /* Is command buffer full ? */
        ExitCritical();                    /* Exit critical section */
        return ERR_BUSY;                   /* If yes then error */
      FCCOBIX = 0U;                        /* Clear index register */
      FCCOBHI = 0x0AU;                     /* Erase P-Flash sector command */
      FCCOBLO = (byte)(Addr >> 16U);       /* High address word */
      FCCOBIX++;                           /* Shift index register */
      FCCOB = (word)(Addr & 0xFFFFFFF8UL); /* Low address word aligned to 8 byte phrase*/
      CallFnCmdInRam();                    /* Copy Wait in RAM routine to stack and launch the flash process */
      if (FSTAT_FPVIOL == 1U) {            /* Is protection violation detected ? */
        return ERR_NOTAVAIL;               /* If yes then error */
      if (FSTAT_ACCERR == 1U) {            /* Is acces error detected ? */
      if (FSTAT_MGSTAT) {                  /* Was attempt to erase the sector errorneous? */
        return ERR_VALUE;                  /* If yes then error */
      return ERR_OK;                       /* OK */
    /*部分调用函数*/
    #define EnterCritical() \
    /*lint -save  -e950 -esym(960,14.3) Disable MISRA rule (1.1,14.3) checking. */\
        { __asm(pshc); __asm(sei); __asm(movb 1,SP+,CCR_reg); } /* This macro is used by Processor Expert. It saves CCR register and disable global interrupts. */ \
    #define ExitCritical() \
        { __asm(movb CCR_reg, 1,-SP); __asm(pulc); } /* This macro is used by Processor Expert. It restores CCR register saved in SaveStatusReg(). */ \
    #define ClearFlags()  (FSTAT = 0x30U)
    static void FnCmdInRam_(void)
      FSTAT = 0x80U;                       /* Clear flag command buffer empty */
      while (FSTAT_CCIF == 0U) {}          /* Wait to command complete */
      return;
    #pragma MESSAGE DISABLE C12056         /* Disable warning C12056 "SP debug info incorrect becouse of optimization or inline assembler" */
    /* Types definitions */
    typedef struct {
       uint8_t code[15];             /* Structure required to copy code to ram memory */
      /* Size of this structure needs to be at least (but best) the size of the FnCmdInRam_ */
    } FnCmdInRamStruct;
    typedef void (* near pFnCmdInRam)(void);
    #pragma MESSAGE DISABLE C1805          /* Disable warning C1805 "Non-standard conversion used" */
    /*lint -save  -e740 -e931 Disable MISRA rule (1.2) checking. */
    static void CallFnCmdInRam()
      FnCmdInRamStruct FnCmdInRam = *(FnCmdInRamStruct *)(FnCmdInRam_); /* Create a copy of Wait in RAM routine on stack */
      ((pFnCmdInRam)&FnCmdInRam)();        /* Call code in RAM */
      return;
    我知道答案 目前已有0人回答
    GMT+8, 2025-10-30 16:11 , Processed in 0.072715 second(s), 21 queries , MemCache On.
