查看: 2958|回复: 1
[原创] FGPIO和GPIO寄存器的使用
发表于 2016-5-5 13:44:49 | 显示全部楼层 |阅读模式
我是用的是KL02处理器.
手册中既然说明了FGPIO是GPIO寄存器的别名,并且有单周期访问的特性,那么,是不是GPIO寄存器就没访问的必要,可以全部都访问FGPIO上,他们寄存器的表达是完全一样的.
The GPIO registers are also aliased to the IOPORT interface on the Cortex-M0+ from address 0xF800_0000. Accesses via the IOPORT interface occur in parallel with any instruction fetches and will therefore complete in a single cycle. This aliased Fast GPIO memory map is called FGPIO.
Any read or write access to the FGPIO memory space that is outside the valid memory map results in a bus error. All register accesses complete with zero wait states, except error accesses which complete with one wait state.
发表于 2016-5-5 16:29:32 | 显示全部楼层
从控制GPIO的输入,输出角度看,你可以这样理解
GMT+8, 2025-10-29 18:24 , Processed in 0.078637 second(s), 20 queries , MemCache On.
