查看: 3381|回复: 7
[求助] 关于KL25低功耗的编程问题
发表于 2016-5-18 13:54:19 | 显示全部楼层 |阅读模式
有没有大神,帮我解释一下下面的KL25低功耗例程中的代码,最好详细点,初学者。万分感谢!int main (void)
#ifdef CMSIS
        start();
#endif
        /*Enable all operation modes because this is a write once register*/
        SMC_PMPROT =  SMC_PMPROT_AVLLS_MASK |
                      SMC_PMPROT_ALLS_MASK  |
                      SMC_PMPROT_AVLP_MASK;
        /*PTC3(SW3) is configured to wake up MCU from VLLSx and LLS modes, Interrup is ne*/
        LLWU_Init();
        /*Configure Tower hardware for the application*/
        Port_Init(IO_NMI_DEF);
        SW_LED_Init();
        EnableInterrupts;
        /*Start test*/
        LowPowerModes_test();
void LowPowerModes_test(void)
  int i;
  unsigned char op_mode,fcrdiv_val;
  int test_num = UNDEF_VALUE;
  int wait_count;
  char test_val;
        while(1)
            while (test_num > 22 | test_num < 0){
               LED0_ON;
               LED1_ON;
               LED2_ON;
               #ifndef FREEDOM
               LED3_ON;
               #endif
               if ((SMC_PMSTAT & SMC_PMSTAT_PMSTAT_MASK)== 4){
                        printf("  in VLPR Mode !  ");
                } else if ((SMC_PMSTAT & SMC_PMSTAT_PMSTAT_MASK)== 1){
                        printf("  in Run Mode  !  ");
printf("\n\r > ");
                test_val = uart0_getchar(UART0_BASE_PTR);
                uart0_putchar(UART0_BASE_PTR,test_val);
                printf("\n\r");
                if((test_val>=0x30) && (test_val<=0x39))
                      test_num = test_val - 0x30;
                if((test_val>=0x41) && (test_val<=0x4C))
                      test_num = test_val - 0x37;
                if((test_val>=0x61) && (test_val<=0x6C))
                      test_num = test_val - 0x57;
            LED0_OFF;
            LED1_OFF;
            LED2_OFF;
#ifndef FREEDOM
            LED3_OFF;
            case 3://LLS loop wake up every 1000 ms
                printf("Press any key to enter LLS with LPTMR 1 Second wakeup loop\n\r ");
                llwu_configure(0x0000, LLWU_PIN_FALLING, 0x1);
                    LPTMR_init(1000,LPTMR_USE_LPOCLK);
                    printf("Press SW4 to wake up from VLLS2\n\r ");
                for (i=0;i<10;i++)
                      printf("  Entering LLS mode");
                      clockMonitor(OFF);
                      set_4_lp(0);
                      enter_lls();
                      set_4_lp(1);
                      clockMonitor(ON);
                      /*After LLS wake up that was enter from PEE the exit will be on PBE */
                      /*  for this reason after wake up make sure to get back to desired  */
                      /*  clock mode                                                      */
                      op_mode = what_mcg_mode();
                      if(op_mode==PBE)
                          mcg_clk_hz = pbe_pee(CLK0_FREQ_HZ);
                          uart0_clk_khz = ((mcg_clk_hz / 2) / 1000); // UART0 clock frequency will equal half the PLL frequency
                          uart_configure(uart0_clk_khz,SIM_SOPT2_UART0SRC(1));
                      printf(" Loop Count 0x%02X ",i) ;
                      printf("  Back in RUN mode \n\r");
               LPTMR0_CSR &= ~LPTMR_CSR_TEN_MASK;
               break;
case 0x12://VLPR in BLPI 4 MHZ
                /*Maximum clock frequency for this mode is core 4MHz and Flash 1Mhz*/
                printf("Press any key to enter VLPR in BLPI mode \n\r ");
                printf("Configure clock frequency to 4MHz core clock and 1MHz flash clock\n\r ");
                /*Get out of VLPR to change clock dividers*/
                exit_vlpr();  // get out of VLPR back to RUN
                vlp_clock_config(BLPI);
                // default clock divider is set to divide by 1 of Fast IRC and Div2 for Bus
                SIM_CLKDIV1 = (   SIM_CLKDIV1_OUTDIV1(0)
                                | SIM_CLKDIV1_OUTDIV4(4) );
                fcrdiv_val = (1 << ((MCG_SC & MCG_SC_FCRDIV_MASK) >> MCG_SC_FCRDIV_SHIFT)); // calculate the fast IRC divder factor
                mcg_clk_hz =  (fast_irc_freq / fcrdiv_val); // MCGOUT frequency equals fast IRC frequency divided by 2
                mcg_clk_hz =  mcg_clk_hz / (((SIM_CLKDIV1 & SIM_CLKDIV1_OUTDIV1_MASK) >> 28)+ 1);
                /*Go to VLPR*/
                enter_vlpr();   // get into VLPR
                        printf("  in VLPR Mode !\n\r ");
                        printf("  in Run Mode  !\n\r ");
                    clockMonitor(ON);
                break;
void demo_lptmr_isr(void)
  volatile unsigned int dummyread;
  if(MCM_CPO & MCM_CPO_CPOACK_MASK){
      MCM_CPO &= ~MCM_CPO_CPOREQ_MASK;
      while (MCM_CPO & MCM_CPO_CPOACK_MASK);
      printf("         \n\rLPTRM Interrupt pulled OUT of Compute Mode  \n\r");
  SIM_SCGC5 |= SIM_SCGC5_LPTMR_MASK;
  printf(" \r[demo_lptmr_isr] \n\r  > ");
  LPTMR0_CSR |=  LPTMR_CSR_TCF_MASK;   // write 1 to TCF to clear the LPT timer compare flag
  LPTMR0_CSR = ( LPTMR_CSR_TEN_MASK | LPTMR_CSR_TIE_MASK | LPTMR_CSR_TCF_MASK  );
      // enable timer
      // enable interrupts
      // clear the flag
  /*wait for write to complete to  before returning */
  dummyread = LPTMR0_CSR;
  return;
void SW_LED_Init(void)
#ifdef TOWER
   SIM_SCGC5 |= SIM_SCGC5_PORTB_MASK | SIM_SCGC5_PORTA_MASK ; /* PORT clock enablement */
         LED0_EN; // (PORTA_PCR16 = PORT_PCR_MUX(1))
         GPIOA_PDDR |= (1<<16);
         LED1_EN; // (PORTA_PCR17 = PORT_PCR_MUX(1))
         GPIOA_PDDR |= (1<<17);
         LED2_EN; // (PORTB_PCR8 = PORT_PCR_MUX(1))
         GPIOB_PDDR |= (1<<8);
         LED3_EN; // (PORTA_PCR5 = PORT_PCR_MUX(1))
   GPIOA_PDDR |= (1<<5);
#else
   SIM_SCGC5 |= SIM_SCGC5_PORTB_MASK | SIM_SCGC5_PORTD_MASK ; /* PORT clock enablement */
         LED0_EN;
   GPIOB_PDDR |= (1<<19);
         LED1_EN;
   GPIOB_PDDR |= (1<<18);
        LED2_EN;
   GPIOD_PDDR |= 1;
#endif
我知道答案 目前已有7人回答
发表于 2016-5-18 15:35:25 | 显示全部楼层
楼主自己去看这个分享帖子:
https://www.nxpic.org.cn/module/forum/thread-555664-1-1.html
回复 支持 1 反对 0
发表于 2016-5-18 14:12:03 | 显示全部楼层
回帖奖励 +10 NXP金币
帮顶  帮顶
发表于 2016-5-18 14:12:53 | 显示全部楼层
怎么又回帖奖励
 楼主| 发表于 2016-5-18 17:41:05 | 显示全部楼层
小恩GG 发表于 2016-5-18 15:35
楼主自己去看这个分享帖子:
这个我看了,讲的很粗略。。
发表于 2016-5-19 09:11:04 | 显示全部楼层
wz15996410106 发表于 2016-5-18 17:41
这个我看了,讲的很粗略。。
对的,我们一般会对关键语句进行注释,其他的代码建议客户对照参考手册理解
 楼主| 发表于 2016-5-19 13:17:44 | 显示全部楼层
小恩GG 发表于 2016-5-19 09:11
对的,我们一般会对关键语句进行注释,其他的代码建议客户对照参考手册理解 ...
请问下FREEDOM板子运行的时候LED灯为什么是黄色的,LED0,LED1,LED3是什么意思?
发表于 2016-5-19 15:29:15 | 显示全部楼层
参考原理图和代码就一清二楚啊!
GMT+8, 2025-10-29 13:37 , Processed in 0.095142 second(s), 29 queries , MemCache On.
