查看: 5208|回复: 6
[CodeWarrior] CodeWarrior Flash烧写
发表于 2016-5-30 10:42:33 | 显示全部楼层 |阅读模式
请教高手:CodeWarrior Flash烧写的步骤,CodeWarrior烧写器与电脑连接的方式,是USB还是网线,驱动怎么安装?我在烧写时提示JTAG clock speed change error,please check your JTAG clock speed。
CCSProtocolPlugin::Could not connect to the requested core core #0.
我知道答案 目前已有6人回答
  • 签到天数: 20 天
    发表于 2016-5-30 10:49:44 | 显示全部楼层
    USB连接  驱动会自动检测安装的
    签到 签到
     楼主| 发表于 2016-5-30 13:10:25 | 显示全部楼层
    肖久 发表于 2016-5-30 10:49
    USB连接  驱动会自动检测安装的
    那我Flash烧写的时候选择USB TAP吗    C:\Users\wbw\Desktop\QQ截图20160530130821.bmp
  • 签到天数: 20 天
    发表于 2016-5-30 13:17:27 | 显示全部楼层
    你的图片 要选择上传  直接负责我看不到的
    签到 签到
  • 签到天数: 20 天
    签到 签到
     楼主| 发表于 2016-5-31 15:13:08 | 显示全部楼层
    USB连接  驱动会自动检测安装的
    是我软件补丁的问题,但是现在烧写Flash又出现个新问题,擦除没问题,烧写总是失败
     楼主| 发表于 2016-5-31 15:13:39 | 显示全部楼层
    烧写失败,提示:Flash Programmer:  Flash driver reports the following error(s): The flash device algorithm was interrupted during execution. Please check if the flash base address is correct or if there are any flash devices mapped inside the selected memory space. If a custom target initialization file was used then check the following parameters: flash base address, flash bank size and flash bank port size. Please enable Verify Target Memory Writes in Target Configuration to check that the algorithm downloads correctly. If you are downloading the algorithm to DDR try checking your DDR configuration.
    GMT+8, 2025-10-30 00:33 , Processed in 0.091704 second(s), 27 queries , MemCache On.
