查看: 3318|回复: 3
[CodeWarrior] CodeWarrior Flash烧写
发表于 2016-5-31 15:14:45 | 显示全部楼层 |阅读模式
Flash擦除正常,烧写时失败提示
Flash Programmer:  Flash driver reports the following error(s): The flash device algorithm was interrupted during execution. Please check if the flash base address is correct or if there are any flash devices mapped inside the selected memory space. If a custom target initialization file was used then check the following parameters: flash base address, flash bank size and flash bank port size. Please enable Verify Target Memory Writes in Target Configuration to check that the algorithm downloads correctly. If you are downloading the algorithm to DDR try checking your DDR configuration.
    2024-3-21 15:13
  • 签到天数: 41 天
    发表于 2016-5-31 17:53:54 | 显示全部楼层
    嗯!帮顶,让高手看到解决问题,传说中不是有FAE在的嘛!
    好多年没来了
    回复 支持 1 反对 0
    发表于 2016-5-31 15:44:05 | 显示全部楼层
    你可以描述清楚点么
     楼主| 发表于 2016-6-1 13:41:26 | 显示全部楼层
    kaertor 发表于 2016-5-31 15:44
    你可以描述清楚点么
    我用CodeWarrior往一个NOR Flash里烧boot程序,烧写时初始化都过了,到要进行Flash programme的时候出现了上述错误
    GMT+8, 2025-10-30 00:33 , Processed in 0.091366 second(s), 24 queries , MemCache On.
