查看: 14182|回复: 6
[已解决] imx6dl linux RTL8723蓝牙如何工作?WIFI已调好
    发表于 2016-6-7 17:38:09 | 显示全部楼层 |阅读模式
    各位大神好:
       我在imx6dl  linux上增加 RTL8723bu 模块。RTL8723是 wifi蓝牙二合一的USB接口。我这WIFI可以正常工作,但是!
    增加蓝牙驱动模块。应该是好使的
    [root@fscltool]# insmod rtk_btusb.ko
    [   18.814000] rtk_btusb: Realtek Bluetooth USB driver module init, version 3.0
    [   18.816000] rtk_btusb: Register usb char device interface for BT driver
    [   18.824000] rtk_btusb: btusb_probe: usb_interface e2f3ec00, bInterfaceNumber
    0, idVendor 0x0bda, idProduct 0x0000
    [   18.833000] rtk_btusb: get_fw_table_entry: Product id = 0xb720, fw table entr
    y size 40
    [   18.841000] rtk_btusb: firmware_info_init: Auto suspend is disabled
    [   18.847000] rtk_btusb: btusb_probe: download begining...
    [   18.852000] rtk_btusb: btusb_probe: download ending...
    [   18.858000] rtk_btusb: btusb_probe: Check bt reset flag 0
    [   18.863000] usbcore: registered new interface driver rtk_btusb
    查看蓝牙设备
    [root@fscltool]# hciconfig
    [root@fscltool]# hciconfig -a
    [root@fscltool]# hcitool hci0
    Unknown command - "hci0"
    [root@fscltool]# hcitool hci0 up
    [root@fscltool]#
    找不到 蓝牙设备 ifconfig -a 也没有
    [root@fscltool]# ifconfig -a
    eth0      Link encap:Ethernet  HWaddr 08:90:90:90:90:90
              inet addr:192.168.1.232  Bcast:192.168.1.255  Mask:255.255.255.0
              inet6 addr: fe80::a90:90ff:fe90:9090/64 Scopeink
              UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
              RX packets:2309 errors:0 dropped:6 overruns:0 frame:0
              TX packets:6 errors:0 dropped:0 overruns:0 carrier:0
              collisions:0 txqueuelen:1000
              RX bytes:181851 (177.5 KiB)  TX bytes:468 (468.0 B)
              Interrupt:80
    ip6tnl0   Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
    -00
              NOARP  MTU:1452  Metric:1
              RX packets:0 errors:0 dropped:0 overruns:0 frame:0
              TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
              collisions:0 txqueuelen:0
              RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
    lo        Link encapocal Loopback
              inet addr:127.0.0.1  Mask:255.0.0.0
              inet6 addr: ::1/128 Scope:Host
              UP LOOPBACK RUNNING  MTU:16436  Metric:1
    p2p0      Link encap:Ethernet  HWaddr 7E:C7:09:9A:F3:0A
              BROADCAST MULTICAST  MTU:1500  Metric:1
    sit0      Link encap:IPv6-in-IPv4
              NOARP  MTU:1480  Metric:1
    wlan0     Link encap:Ethernet  HWaddr 7C:C7:09:9A:F3:0A
    请问大神们,这个蓝牙怎么调试可以让他工作起来?
    我知道答案 目前已有6人回答
    今天天气不错!签到!
     楼主| 发表于 2016-6-7 18:34:02 | 显示全部楼层
    经过一下午的努力,终于 有点进展了
    hci0:   Type: BR/EDR  Bus: USB
            BD Address: 7C:C7:08:9A:F3:0A  ACL MTU: 1021:8  SCO MTU: 255:16
            DOWN
            RX bytes:467 acl:0 sco:0 events:18 errors:0
            TX bytes:317 acl:0 sco:0 commands:18 errors:0
            Features: 0xff 0xff 0xff 0xfe 0xdb 0xfd 0x7b 0x87
            Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
            Link policy: RSWITCH HOLD SNIFF PARK
            Link mode: SLAVE ACCEPT
    [root@fscltool]#
    啦啦啦啦,下班了,明天继续玩喽
    今天天气不错!签到!
     楼主| 发表于 2016-6-8 11:21:02 | 显示全部楼层
    今天弄了弄 OK了 能PING 通了
    [root@fscltool]# hciconfig hci0 up
    [root@fscltool]# hcitool scan
    Scanning ...
    [ 1598.330000] rtk_btusb: notify wifi inquiry start
    [ 1608.575000] rtk_btusb: notify wifi inquiry end
            10:2A:B3:52:40:0B        红米手机
    [root@fscltool]#
    PING  ip地址
    [root@fscltool]# l2ping 10:2A:B3:52:40:0B
    [  163.352000] rtk_btusb: hci0 evt 1
    [  163.352000] rtk_btusb: btusb_notify : hci0 evt 1
    [  163.356000] rtk_btusb: notify wifi start page
    [  163.518000] rtk_btusb: notify wifi page success end
    Ping: 10:2A:B3:52:40:0B from 7C:C7:08:9A:F3:0A (data size 44) ...
    44 bytes from 10:2A:B3:52:40:0B id 0 time 9.86ms
    44 bytes from 10:2A:B3:52:40:0B id 1 time 34.38ms
    44 bytes from 10:2A:B3:52:40:0B id 2 time 106.00ms
    44 bytes from 10:2A:B3:52:40:0B id 3 time 109.26ms
    就是这么完美! OK 搞定了
    今天天气不错!签到!
     楼主| 发表于 2016-6-8 18:12:04 | 显示全部楼层
    另外 还需要把固件文件
    将这2个文件放在/lib/firmware下
    rtl8723b_fw       rtl8723bu_config
    /*********************无密码链接蓝牙**************************/
    export PATH=/mnt/sdcard/bluez-4.95/binPATH
    export PATH=/mnt/sdcard/bluez-4.95/sbinPATH
    export LD_LIBRARY_PATH=/mnt/sdcard/bluez-4.95/libLD_LIBRARY_PATH
    mount /mnt/sdcard/bluez-4.95 /usr/local/bluez-4.95/
    hciconfig
    hciconfig hci0 up
    rm /mnt/sdcard/bluez-4.95/var/run/dbus/pid
    dbus-daemon --system
    bluetoothd
    hciconfig hci0 up piscan
    今天天气不错!签到!
    发表于 2017-5-31 13:48:34 | 显示全部楼层
    怎么弄成功的也没说下,希望补充供后来人参考下,谢谢
    发表于 2017-5-31 13:53:07 | 显示全部楼层
    我的提示是:
    root@freescale /opt/arm$ hciconfig
    root@freescale /opt/arm$ hciconfig hci0
    Can't get device info: No such device
    root@freescale /opt/arm$ lsmod
    Module                  Size  Used by
    rtk_btusb              21172  0
    8723bu               1221882  0
  • 签到天数: 11 天
    优秀版主
    发表于 2017-5-31 16:18:47 | 显示全部楼层
    驱动问题吧,难道你买个电脑插个鼠标不能用要找英特尔或者微软么
    GMT+8, 2026-4-9 02:56 , Processed in 0.102424 second(s), 28 queries , Redis On.
