查看: 3823|回复: 5
[S12] HCS12开了两个定时器中断,一个定时器中断无法进入,求助
发表于 2016-6-15 15:10:24 | 显示全部楼层 |阅读模式
写了一个定时器中断程序,pit0定时时间为20ms,pit1定时时间为40ms,两个定时器的中断优先级都相同,程序运行后能进入pit0 isr,led0会不断闪烁,周期为40ms,而pit1 isr不能进入,led1不闪烁,pit0和pit1单独使用时都能正常进入中断,程序如下,这是什么问题,哪位朋友能解答下,万分感谢!
#include <MC9S12XEP100.h>
#include <hidef.h>                              /* common defines and macros */
#include "derivative.h"                        /* derivative-specific definitions */
/* led initial */
void led_init()
    DDRA |= 0x3c;
    PORTA = 0;
/* pit0 isr */
#pragma CODE_SEG __NEAR_SEG NON_BANKED
void interrupt VectorNumber_Vpit0 pit0_irq(void)
     PITTF_PTF0 = 1;
     /* led0 jump */
     PORTA_PA2 = ~PORTA_PA2;
/* pit1 isr */
void interrupt VectorNumber_Vpit1 pit1_irq(void)
    PITTF_PTF1 = 1;
    /* led1 */
    PORTA_PA3 = ~PORTA_PA3;
/* clock initial */
void clock_init()
    /* set oscclk as sysclk */
    CLKSEL &= 0X7F;
    /* disable pll circuit */
    PLLCTL &= 0X8F;
    /* pllclk = 40m, fbus = 20m*/
    SYNR |= 0x53;
    REFDV |= 0X07;
    POSTDIV = 0;
    /* enable pll circuit */
    PLLCTL |= 0X70;
    asm NOP;
    asm NOP;
    /* pllclk is locked alredy */
    while (!(CRGFLG & 0X08));
    /* set pllclk as sysclk */
    CLKSEL |= 0X80;
/* 20ms */
void pit0_init()
    /* close PIT */
    PITCFLMT_PITE = 0;
    /* enable channel0 */
    PITCE_PCE0 = 1;
    /* 16-bit timer counts with micro time base 0 */
    PITMUX_PMUX0 = 0;
    /* micro timer0 count value */
    PITMTLD0 = 100 - 1;
    /* timer0 count value */
    PITLD0 = 4000 - 1;
    /* enable interrupt */
    PITINTE_PINTE0 = 1;
    /* enable PIT */
    PITCFLMT_PITE = 1;
/* 40ms */
void pit1_init()
    /* close PIT */
    PITCFLMT_PITE = 0;
    /* enable channel1 */
    PITCE_PCE1 = 1;
    /* 16-bit timer counts with micro time base 1 */
    PITMUX_PMUX1 = 1;
    /* micro timer1 count value */
    PITMTLD1 = 100 - 1;
    /* timer1 count value */
    PITLD1 = 8000 - 1;
    PITINTE_PINTE1 = 1;
    /* enable PIT */
    PITCFLMT_PITE = 1;
/* set pit0, pit1 interrrupt priority */
void interrupt_priority_set()
    /* set pit0 priority */
    INT_CFADDR = 0x70;
    INT_CFDATA5 = 0x06;
    /* set pit1 priority */
    INT_CFADDR = 0x70;
    INT_CFDATA4 = 0x06;
int main()
    DisableInterrupts;
    clock_init();
    led_init();
    pit0_init();
    pit1_init();
    interrupt_priority_set();
    EnableInterrupts;
    while (1);
我知道答案 目前已有5人回答
    发表于 2016-6-15 17:11:42 | 显示全部楼层
    先禁用pit0,看是否能够进入中断。
     楼主| 发表于 2016-6-17 15:11:48 | 显示全部楼层
    hellokity 发表于 2016-6-15 17:11
    先禁用pit0,看是否能够进入中断。
    pit0和pit1单独使用都能进入中断,但是一起开的时候pit1就无法进入了
    发表于 2016-6-20 15:13:29 | 显示全部楼层
    你的问题解决了吗,我现在也遇到同样的问题
     楼主| 发表于 2016-9-12 09:23:30 | 显示全部楼层
    还没有解决,你有解决了吗
     楼主| 发表于 2016-9-12 09:24:33 | 显示全部楼层
    还没有解决,你有解决了吗
    GMT+8, 2025-10-28 19:56 , Processed in 0.090235 second(s), 26 queries , MemCache On.
