FreeRTOS学习笔记 FreeRTOS 是高度可配置的,所有的可配置项都在FreeRTOSConfig.h 文件中。每一个FreeRTOS Demo中都必须包含了一个配置好的FreeRTOSConfig.h文件,用户根据实际应用来裁剪定制FreeRTOS内核。这个配置文件是针对用户程序的,而非内核。 下面列出 上次已移植成功的工程中的FreeRTOSConfig.h配置文件定义(如表一所示),随后会说明里面的每一个参数定义。 表一 FreeRTOSConfig.h - #ifndef FREERTOS_CONFIG_H
- #define FREERTOS_CONFIG_H
- #define configUSE_PREEMPTION 1
- #define configUSE_IDLE_HOOK 0
- #define configUSE_TICK_HOOK 0
- #define configCPU_CLOCK_HZ (SystemCoreClock)
- #define configTICK_RATE_HZ ((TickType_t)1000)
- #define configMAX_PRIORITIES (5)
- #define configMINIMAL_STACK_SIZE ((unsigned short)90)
- #define configTOTAL_HEAP_SIZE ((size_t)(10 * 1024))
- #define configMAX_TASK_NAME_LEN (10)
- #define configUSE_TRACE_FACILITY 1
- #define configUSE_16_BIT_TICKS 0
- #define configIDLE_SHOULD_YIELD 1
- #define configUSE_MUTEXES 1
- #define configQUEUE_REGISTRY_SIZE 8
- #define configCHECK_FOR_STACK_OVERFLOW 0
- #define configUSE_RECURSIVE_MUTEXES 1
- #define configUSE_MALLOC_FAILED_HOOK 0
- #define configUSE_APPLICATION_TASK_TAG 0
- #define configUSE_COUNTING_SEMAPHORES 1
- #define configGENERATE_RUN_TIME_STATS 0
- #define configUSE_TIME_SLICING 0
- /* Co-routine definitions. */
- #define configUSE_CO_ROUTINES 0
- #define configMAX_CO_ROUTINE_PRIORITIES (2)
- /* Software timer definitions. */
- #define configUSE_TIMERS 1
- #define configTIMER_TASK_PRIORITY (2)
- #define configTIMER_QUEUE_LENGTH 10
- #define configTIMER_TASK_STACK_DEPTH (configMINIMAL_STACK_SIZE * 2)
- /* Set the following definitions to 1 to include the API function, or zero
- to exclude the API function. */
- #define INCLUDE_vTaskPrioritySet 1
- #define INCLUDE_uxTaskPriorityGet 1
- #define INCLUDE_vTaskDelete 1
- #define INCLUDE_vTaskCleanUpResources 1
- #define INCLUDE_vTaskSuspend 1
- #define INCLUDE_vTaskDelayUntil 1
- #define INCLUDE_vTaskDelay 1
- /* Cortex-M specific definitions. */
- #ifdef __NVIC_PRIO_BITS
- /* __BVIC_PRIO_BITS will be specified when CMSIS is being used. */
- #define configPRIO_BITS __NVIC_PRIO_BITS
- #else
- #define configPRIO_BITS 4 /* 15 priority levels */
- #endif
- /* The lowest interrupt priority that can be used in a call to a "set priority"
- function. */
- #define configLIBRARY_LOWEST_INTERRUPT_PRIORITY 0xf
- /* The highest interrupt priority that can be used by any interrupt service
- routine that makes calls to interrupt safe FreeRTOS API functions. DO NOT CALL
- INTERRUPT SAFE FREERTOS API FUNCTIONS FROM ANY INTERRUPT THAT HAS A HIGHER
- PRIORITY THAN THIS! (higher priorities are lower numeric values. */
- #define configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY 5
- /* Interrupt priorities used by the kernel port layer itself. These are generic
- to all Cortex-M ports, and do not rely on any particular library functions. */
- #define configKERNEL_INTERRUPT_PRIORITY (configLIBRARY_LOWEST_INTERRUPT_PRIORITY << (8 - configPRIO_BITS))
- /* !!!! configMAX_SYSCALL_INTERRUPT_PRIORITY must not be set to zero !!!!
- See http://www.FreeRTOS.org/RTOS-Cortex-M3-M4.html. */
- #define configMAX_SYSCALL_INTERRUPT_PRIORITY (configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY << (8 - configPRIO_BITS))
- /* Normal assert() semantics without relying on the provision of an assert.h
- header file. */
- #define configASSERT(x) \
- if ((x) == 0) \
- taskDISABLE_INTERRUPTS(); \
- for (;;) \
- /* Definitions that map the FreeRTOS port interrupt handlers to their CMSIS
- standard names. */
- #define vPortSVCHandler SVC_Handler
- #define xPortPendSVHandler PendSV_Handler
- #define xPortSysTickHandler SysTick_Handler
- #endif /* FREERTOS_CONFIG_H */
复制代码 |
