查看: 7078|回复: 4
[已解决] KEA128\KEA06 官方库建立keil报错
发表于 2016-6-26 09:10:29 | 显示全部楼层 |阅读模式
common.h文件怎样配置,一致在这个文件下报错,defined(CPU_KE06)这个是什么意思?提示错误:
  • ..\..\..\..\src\cpu\headers\MKE06Z4.h(118): error:  #5: cannot open source input file "core_cm0plus.h": No such file or directory
[color=rgb(51, 102, 153) !important]复制代码
core_cm0plus.h这个文件是cw环境下才有的,从官方库中把keil分离出来就报错找不到这个文件。
  • #ifndef _COMMON_H_
  • #define _COMMON_H_
  • #define swap_bytes(ptrWord)   *ptrWord = (*ptrWord >>8) | (*ptrWord<<8)
  • typedef unsigned long   dword;
  • typedef unsigned short  word;
  • * Debug prints ON (#define) or OFF (#undef)
  • #define DEBUG
  • #define DEBUG_PRINT
  • * Include the generic CPU header file
  • #include "arm_cm0.h"
  • * Include the platform specific header file
  • #if (defined(FRDM_KE02))
  • #include  "ke02_config.h"
  • #elif (defined(FRDM_KE04))
  • #include  "ke04_config.h"
  • #elif (defined(FRDM_KE06))
  • #include  "ke06_config.h"
  • #else
  •   #error "No valid board defined"
  • #endif
  • * Include the cpu specific header file
  • #if (defined(CPU_KE02))
  • #include "MKE02Z2.h"
  • #elif (defined(CPU_KE04))
  • #include "MKE04Z4.h"
  • #elif (defined(CPU_KE06))
  • #include "MKE06Z4.h"
  • #else
  •   #error "No valid CPU defined"
  • #endif
  • * Include any toolchain specfic header files
  • #if (defined(__MWERKS__))
  •   #include "mwerks.h"
  • #elif (defined(__DCC__))
  •   #include "build/wrs/diab.h"
  • #elif (defined(__ghs__))
  •   #include "build/ghs/ghs.h"
  • #elif (defined(__GNUC__))
  •   #if (defined(IAR))
  •     #include "build/gnu/gnu.h"
  •   #endif
  • #elif (defined(IAR))
  •   #include "iar.h"
  • #elif (defined(KEIL))
  • #else
  • #warning "No toolchain specific header included"
  • #endif
  • * Include common utilities
  • #include "assert.h"
  • #include "io.h"
  • #include "startup.h"
  • #include "stdlib.h"
  • #include "intrinsics.h"
  • #endif
  • #endif /* _COMMON_H_ */
楼主你好! 你是不是想要KEA128的keil工程呢? 除了移植KE系列的KEIL代码之外, 你还可以到官方下载KEA128 keil的例程。 http://www.nxp.com/products/soft ... ab=Design_Tools_Tab 关于你移植的问题,你需要使用对 ...
 楼主| 发表于 2016-6-26 20:20:47 | 显示全部楼层
    发表于 2016-6-27 09:45:57 | 显示全部楼层
    core_cm0plus.h是CMSIS的文件,ARM通用的 总共3个文件
  • 签到天数: 11 天
    优秀版主
    发表于 2016-6-27 13:24:05 | 显示全部楼层
    送你一份,不谢
    CMSIS.zip
    144.79 KB, 下载次数: 80, 下载积分: 威望 1
    发表于 2016-6-27 13:55:49 | 显示全部楼层
    楼主你好!
    除了移植KE系列的KEIL代码之外,
    关于你移植的问题,你需要使用对应的core_cm0plus.h, 可以直接参考KE的KEIL工程。
    GMT+8, 2025-10-28 19:48 , Processed in 0.097384 second(s), 27 queries , MemCache On.
