查看: 2681|回复: 1
[已解决] KE02的头文件MKE02A.h里面NV_Register是干什么用的?
发表于 2016-6-27 14:11:59 | 显示全部楼层 |阅读模式
看到这段代码,不知道是作何用处的呀?芯片手册里面有介绍吗?
   -- NV Peripheral Access Layer
* @addtogroup NV_Peripheral_Access_Layer NV Peripheral Access Layer
/** NV - Register Layout Typedef */
typedef struct {
  __I  uint8_t BACKKEY0;                           /**< Backdoor Comparison Key 0, offset: 0x0 */
  __I  uint8_t BACKKEY1;                           /**< Backdoor Comparison Key 1, offset: 0x1 */
  __I  uint8_t BACKKEY2;                           /**< Backdoor Comparison Key 2, offset: 0x2 */
  __I  uint8_t BACKKEY3;                           /**< Backdoor Comparison Key 3, offset: 0x3 */
  __I  uint8_t BACKKEY4;                           /**< Backdoor Comparison Key 4, offset: 0x4 */
  __I  uint8_t BACKKEY5;                           /**< Backdoor Comparison Key 5, offset: 0x5 */
  __I  uint8_t BACKKEY6;                           /**< Backdoor Comparison Key 6, offset: 0x6 */
  __I  uint8_t BACKKEY7;                           /**< Backdoor Comparison Key 7, offset: 0x7 */
       uint8_t RESERVED_0[4];
  __I  uint8_t EEPROT;                             /**< Non-volatile E-Flash Protection Register, offset: 0xC */
  __I  uint8_t FPROT;                              /**< Non-volatile P-Flash Protection Register, offset: 0xD */
  __I  uint8_t FSEC;                               /**< Non-volatile Flash Security Register, offset: 0xE */
  __I  uint8_t FOPT;                               /**< Non-volatile Flash Option Register, offset: 0xF */
} NV_Type;
   -- NV Register Masks
* @addtogroup NV_Register_Masks NV Register Masks
/* BACKKEY0 Bit Fields */
#define NV_BACKKEY0_KEY_MASK                     0xFFu
#define NV_BACKKEY0_KEY_SHIFT                    0
#define NV_BACKKEY0_KEY(x)                       (((uint8_t)(((uint8_t)(x))<<NV_BACKKEY0_KEY_SHIFT))&NV_BACKKEY0_KEY_MASK)
/* BACKKEY1 Bit Fields */
#define NV_BACKKEY1_KEY_MASK                     0xFFu
#define NV_BACKKEY1_KEY_SHIFT                    0
#define NV_BACKKEY1_KEY(x)                       (((uint8_t)(((uint8_t)(x))<<NV_BACKKEY1_KEY_SHIFT))&NV_BACKKEY1_KEY_MASK)
/* BACKKEY2 Bit Fields */
#define NV_BACKKEY2_KEY_MASK                     0xFFu
#define NV_BACKKEY2_KEY_SHIFT                    0
#define NV_BACKKEY2_KEY(x)                       (((uint8_t)(((uint8_t)(x))<<NV_BACKKEY2_KEY_SHIFT))&NV_BACKKEY2_KEY_MASK)
/* BACKKEY3 Bit Fields */
#define NV_BACKKEY3_KEY_MASK                     0xFFu
#define NV_BACKKEY3_KEY_SHIFT                    0
#define NV_BACKKEY3_KEY(x)                       (((uint8_t)(((uint8_t)(x))<<NV_BACKKEY3_KEY_SHIFT))&NV_BACKKEY3_KEY_MASK)
/* BACKKEY4 Bit Fields */
#define NV_BACKKEY4_KEY_MASK                     0xFFu
#define NV_BACKKEY4_KEY_SHIFT                    0
#define NV_BACKKEY4_KEY(x)                       (((uint8_t)(((uint8_t)(x))<<NV_BACKKEY4_KEY_SHIFT))&NV_BACKKEY4_KEY_MASK)
/* BACKKEY5 Bit Fields */
#define NV_BACKKEY5_KEY_MASK                     0xFFu
#define NV_BACKKEY5_KEY_SHIFT                    0
#define NV_BACKKEY5_KEY(x)                       (((uint8_t)(((uint8_t)(x))<<NV_BACKKEY5_KEY_SHIFT))&NV_BACKKEY5_KEY_MASK)
/* BACKKEY6 Bit Fields */
#define NV_BACKKEY6_KEY_MASK                     0xFFu
#define NV_BACKKEY6_KEY_SHIFT                    0
#define NV_BACKKEY6_KEY(x)                       (((uint8_t)(((uint8_t)(x))<<NV_BACKKEY6_KEY_SHIFT))&NV_BACKKEY6_KEY_MASK)
/* BACKKEY7 Bit Fields */
#define NV_BACKKEY7_KEY_MASK                     0xFFu
#define NV_BACKKEY7_KEY_SHIFT                    0
#define NV_BACKKEY7_KEY(x)                       (((uint8_t)(((uint8_t)(x))<<NV_BACKKEY7_KEY_SHIFT))&NV_BACKKEY7_KEY_MASK)
/* EEPROT Bit Fields */
#define NV_EEPROT_DPS_MASK                       0x7u
#define NV_EEPROT_DPS_SHIFT                      0
#define NV_EEPROT_DPS(x)                         (((uint8_t)(((uint8_t)(x))<<NV_EEPROT_DPS_SHIFT))&NV_EEPROT_DPS_MASK)
#define NV_EEPROT_DPOPEN_MASK                    0x80u
#define NV_EEPROT_DPOPEN_SHIFT                   7
/* FPROT Bit Fields */
#define NV_FPROT_FPLS_MASK                       0x3u
#define NV_FPROT_FPLS_SHIFT                      0
#define NV_FPROT_FPLS(x)                         (((uint8_t)(((uint8_t)(x))<<NV_FPROT_FPLS_SHIFT))&NV_FPROT_FPLS_MASK)
#define NV_FPROT_FPLDIS_MASK                     0x4u
#define NV_FPROT_FPLDIS_SHIFT                    2
#define NV_FPROT_FPHS_MASK                       0x18u
#define NV_FPROT_FPHS_SHIFT                      3
#define NV_FPROT_FPHS(x)                         (((uint8_t)(((uint8_t)(x))<<NV_FPROT_FPHS_SHIFT))&NV_FPROT_FPHS_MASK)
#define NV_FPROT_FPHDIS_MASK                     0x20u
#define NV_FPROT_FPHDIS_SHIFT                    5
#define NV_FPROT_FPOPEN_MASK                     0x80u
#define NV_FPROT_FPOPEN_SHIFT                    7
/* FSEC Bit Fields */
#define NV_FSEC_SEC_MASK                         0x3u
#define NV_FSEC_SEC_SHIFT                        0
#define NV_FSEC_SEC(x)                           (((uint8_t)(((uint8_t)(x))<<NV_FSEC_SEC_SHIFT))&NV_FSEC_SEC_MASK)
#define NV_FSEC_KEYEN_MASK                       0xC0u
#define NV_FSEC_KEYEN_SHIFT                      6
#define NV_FSEC_KEYEN(x)                         (((uint8_t)(((uint8_t)(x))<<NV_FSEC_KEYEN_SHIFT))&NV_FSEC_KEYEN_MASK)
*/ /* end of group NV_Register_Masks */
/* NV - Peripheral instance base addresses */
/** Peripheral FTMRH_FlashConfig base address */
#define FTMRH_FlashConfig_BASE                   (0x400u)
/** Peripheral FTMRH_FlashConfig base pointer */
#define FTMRH_FlashConfig                        ((NV_Type *)FTMRH_FlashConfig_BASE)
/** Array initializer of NV peripheral base pointers */
#define NV_BASES                                 { FTMRH_FlashConfig }
楼主你好! 这段讲的就是KE系列的flash configuration field. 具体在reference manual的第225页。 也就是在flash从0X400开始,放置了些关于该芯片的秘钥,flash保护,EEPROM保护,芯片secure等功能的配置字节。 具体 ...
发表于 2016-6-27 14:48:30 | 显示全部楼层
楼主你好!
具体功能就是,是否对芯片上锁,上锁之后留秘钥的话,秘钥是多少,还有对flash以及EEPROM哪些区域予以保护功能。
更多具体功能,请仔细阅读参考手册的flash memory module章节。
GMT+8, 2025-10-28 19:56 , Processed in 0.096387 second(s), 23 queries , MemCache On.
