在线时间587 小时
UID3253488
注册时间2016-3-21
NXP金币0
TA的每日心情 | 怒 2017-1-4 08:05 |
签到天数: 11 天 连续签到: 1 天 [LV.3]偶尔看看II
- 2569
- 2019-3-28
好几天没有放大招了,由于人长得比较帅最近比较烦,收到多个人的骚扰。哈哈,开玩笑的由于是年中了公司项目验收比较忙,日日夜夜的加班撸代码,抽空写了这一KL27移植的教程,不足之处还请各位大神批评订正!下面开始:第一步:准备一个KL27基本的工程(采用SDK2.0,不会用SDK组建工程的下面跟帖,如果人多的话我连SDK2.0额用法一并讲一下)
基础工程
第二步:准备FreeRTOS源码(我们这次移植的是8.3.2)
第三步:讲源码放到我们第一步准备的工程目录下面(这一句貌似是废话,哈哈)
第四步:在Keil中建立相应的工程分组,并添加相应文件,FreeRTOS目录添加内核的源码以及内存管理代码文件,FreeRTOP_Porttable添加与内核相关的文件具体请看图。
第五步:添加头文件的路径(如图)
第六步:完善main函数,及配置FreeRTOS第七步:编译运行- /*
- FreeRTOS V8.2.3 - Copyright (C) 2015 Real Time Engineers Ltd.
- All rights reserved
- VISIT http://www.FreeRTOS.org TO ENSURE YOU ARE USING THE LATEST VERSION.
- This file is part of the FreeRTOS distribution.
- FreeRTOS is free software; you can redistribute it and/or modify it under
- the terms of the GNU General Public License (version 2) as published by the
- Free Software Foundation >>>> AND MODIFIED BY <<<< the FreeRTOS exception.
- >>! NOTE: The modification to the GPL is included to allow you to !<<
- >>! distribute a combined work that includes FreeRTOS without being !<<
- >>! obliged to provide the source code for proprietary components !<<
- >>! outside of the FreeRTOS kernel. !<<
- FreeRTOS is distributed in the hope that it will be useful, but WITHOUT ANY
- WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
- FOR A PARTICULAR PURPOSE. Full license text is available on the following
- link: http://www.freertos.org/a00114.html
- * FreeRTOS provides completely free yet professionally developed, *
- * robust, strictly quality controlled, supported, and cross *
- * platform software that is more than just the market leader, it *
- * is the industry's de facto standard. *
- * Help yourself get started quickly while simultaneously helping *
- * to support the FreeRTOS project by purchasing a FreeRTOS *
- * tutorial book, reference manual, or both: *
- * http://www.FreeRTOS.org/Documentation *
- http://www.FreeRTOS.org/FAQHelp.html - Having a problem? Start by reading
- the FAQ page "My application does not run, what could be wrong?". Have you
- defined configASSERT()?
- http://www.FreeRTOS.org/support - In return for receiving this top quality
- embedded software for free we request you assist our global community by
- participating in the support forum.
- http://www.FreeRTOS.org/training - Investing in training allows your team to
- be as productive as possible as early as possible. Now you can receive
- FreeRTOS training directly from Richard Barry, CEO of Real Time Engineers
- Ltd, and the world's leading authority on the world's leading RTOS.
- http://www.FreeRTOS.org/plus - A selection of FreeRTOS ecosystem products,
- including FreeRTOS+Trace - an indispensable productivity tool, a DOS
- compatible FAT file system, and our tiny thread aware UDP/IP stack.
- http://www.FreeRTOS.org/labs - Where new FreeRTOS products go to incubate.
- Come and try FreeRTOS+TCP, our new open source TCP/IP stack for FreeRTOS.
- http://www.OpenRTOS.com - Real Time Engineers ltd. license FreeRTOS to High
- Integrity Systems ltd. to sell under the OpenRTOS brand. Low cost OpenRTOS
- licenses offer ticketed support, indemnification and commercial middleware.
- http://www.SafeRTOS.com - High Integrity Systems also provide a safety
- engineered and independently SIL3 certified version for use in safety and
- mission critical applications that require provable dependability.
- 1 tab == 4 spaces!
- #ifndef FREERTOS_CONFIG_H
- #define FREERTOS_CONFIG_H
- * Application specific definitions.
- * These definitions should be adjusted for your particular hardware and
- * application requirements.
- * THESE PARAMETERS ARE DESCRIBED WITHIN THE 'CONFIGURATION' SECTION OF THE
- * FreeRTOS API DOCUMENTATION AVAILABLE ON THE FreeRTOS.org WEB SITE.
- * See http://www.freertos.org/a00110.html.
- #define configUSE_PREEMPTION 1
- #define configUSE_IDLE_HOOK 0
- #define configUSE_TICK_HOOK 0
- #define configCPU_CLOCK_HZ (SystemCoreClock)
- #define configTICK_RATE_HZ ((TickType_t)1000)
- #define configMAX_PRIORITIES (5)
- #define configMINIMAL_STACK_SIZE ((unsigned short)90)
- #define configTOTAL_HEAP_SIZE ((size_t)(10 * 1024))
- #define configMAX_TASK_NAME_LEN (10)
- #define configUSE_TRACE_FACILITY 1
- #define configUSE_16_BIT_TICKS 0
- #define configIDLE_SHOULD_YIELD 1
- #define configUSE_MUTEXES 1
- #define configQUEUE_REGISTRY_SIZE 8
- #define configCHECK_FOR_STACK_OVERFLOW 0
- #define configUSE_RECURSIVE_MUTEXES 1
- #define configUSE_MALLOC_FAILED_HOOK 0
- #define configUSE_APPLICATION_TASK_TAG 0
- #define configUSE_COUNTING_SEMAPHORES 1
- #define configGENERATE_RUN_TIME_STATS 0
- #define configUSE_TIME_SLICING 0
- /* Co-routine definitions. */
- #define configUSE_CO_ROUTINES 0
- #define configMAX_CO_ROUTINE_PRIORITIES (2)
- /* Software timer definitions. */
- #define configUSE_TIMERS 1
- #define configTIMER_TASK_PRIORITY (2)
- #define configTIMER_QUEUE_LENGTH 10
- #define configTIMER_TASK_STACK_DEPTH (configMINIMAL_STACK_SIZE * 2)
- /* Set the following definitions to 1 to include the API function, or zero
- to exclude the API function. */
- #define INCLUDE_vTaskPrioritySet 1
- #define INCLUDE_uxTaskPriorityGet 1
- #define INCLUDE_vTaskDelete 1
- #define INCLUDE_vTaskCleanUpResources 1
- #define INCLUDE_vTaskSuspend 1
- #define INCLUDE_vTaskDelayUntil 1
- #define INCLUDE_vTaskDelay 1
- /* Cortex-M specific definitions. */
- #ifdef __NVIC_PRIO_BITS
- /* __BVIC_PRIO_BITS will be specified when CMSIS is being used. */
- #define configPRIO_BITS __NVIC_PRIO_BITS
- #else
- #define configPRIO_BITS 4 /* 15 priority levels */
- #endif
- /* The lowest interrupt priority that can be used in a call to a "set priority"
- function. */
- #define configLIBRARY_LOWEST_INTERRUPT_PRIORITY 0xf
- /* The highest interrupt priority that can be used by any interrupt service
- routine that makes calls to interrupt safe FreeRTOS API functions. DO NOT CALL
- INTERRUPT SAFE FREERTOS API FUNCTIONS FROM ANY INTERRUPT THAT HAS A HIGHER
- PRIORITY THAN THIS! (higher priorities are lower numeric values. */
- #define configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY 5
- /* Interrupt priorities used by the kernel port layer itself. These are generic
- to all Cortex-M ports, and do not rely on any particular library functions. */
- #define configKERNEL_INTERRUPT_PRIORITY (configLIBRARY_LOWEST_INTERRUPT_PRIORITY << (8 - configPRIO_BITS))
- /* !!!! configMAX_SYSCALL_INTERRUPT_PRIORITY must not be set to zero !!!!
- See http://www.FreeRTOS.org/RTOS-Cortex-M3-M4.html. */
- #define configMAX_SYSCALL_INTERRUPT_PRIORITY (configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY << (8 - configPRIO_BITS))
- /* Normal assert() semantics without relying on the provision of an assert.h
- header file. */
- #define configASSERT(x) \
- if ((x) == 0) \
- taskDISABLE_INTERRUPTS(); \
- for (;;) \
- /* Definitions that map the FreeRTOS port interrupt handlers to their CMSIS
- standard names. */
- #define vPortSVCHandler SVC_Handler
- #define xPortPendSVHandler PendSV_Handler
- #define xPortSysTickHandler SysTick_Handler
- #endif /* FREERTOS_CONFIG_H */
- #include "FreeRTOS.h"
- #include "task.h"
- #include "queue.h"
- #include "timers.h"
- #include "hardware.h"
- #define hello_task_PRIORITY (configMAX_PRIORITIES - 1)
- static void hello_task(void *pvParameters);
- * @brief Application entry point.
- int main(void)
- /* Init board hardware. */
- HARDWARE_Init();
- BOARD_InitDebugConsole();
- xTaskCreate(hello_task, "Hello_task", configMINIMAL_STACK_SIZE, NULL, hello_task_PRIORITY, NULL);
- vTaskStartScheduler();
- for (;;)
- * @brief Task responsible for printing of "Hello world." message.
- for (;;)
- PRINTF("Hello world.\r\n");
- vTaskSuspend(NULL);
