查看: 3544|回复: 1
[求助] keil能program, 但Verify有四个字节出错,
    发表于 2016-8-2 10:31:38 | 显示全部楼层 |阅读模式
    keil能将内容正确写入flash, 但Verify时,固定在0000001C~0000001F四个字节出错,flash中的内容是正确的,不能进入debug 界面,问题出在哪里呢?
    download 信息如下:
    Target info:
    Device: MK64FN1M0xxx12
    VTarget = 3.285V
    State of Pins:
    TCK: 0, TDI: 1, TDO: 0, TMS: 1, TRES: 1, TRST: 1
    Hardware-Breakpoints: 6
    Software-Breakpoints: 8192
    Watchpoints:          4
    JTAG speed: 4000 kHz
    Erase Done.
    Programming Done.
    Contents mismatch at: 0000001CH  (Flash=00H  Required=36H) !
    Contents mismatch at: 0000001DH  (Flash=00H  Required=C8H) !
    Contents mismatch at: 0000001EH  (Flash=00H  Required=FFH) !
    Contents mismatch at: 0000001FH  (Flash=00H  Required=DFH) !
    Verify Failed!
    Error: Flash Download failed  -  "Cortex-M4"
    Flash Load finished at 10:19:55
    我知道答案 目前已有1人回答
    发表于 2016-8-2 13:25:39 | 显示全部楼层
    楼主烧录不能进入debug界面?
    用的是什么仿真器?是否是正版的?
    GMT+8, 2025-10-28 03:03 , Processed in 0.083761 second(s), 23 queries , MemCache On.
