查看: 2646|回复: 5
[求助] i.MX6烧机失败
发表于 2016-8-3 10:14:59 | 显示全部楼层 |阅读模式
昨天给机器升级,机器起不来了,想烧一下,结果在分区那里一直红,开关拨回发现启动只是亮屏,
求助
贴下串口信息:
U-Boot 2009.08-dirty (Sep 10 2015 - 17:05:23)
CPU: Freescale i.MX6 family TO1.2 at 792 MHz
Thermal sensor with ratio = 183
Temperature:   33 C, calibration data 0x5844ce7d
mx6q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
ipg clock     : 66000000Hz
ipg per clock : 66000000Hz
uart clock    : 80000000Hz
cspi clock    : 60000000Hz
ahb clock     : 132000000Hz
axi clock   : 198000000Hz
emi_slow clock: 99000000Hz
ddr clock     : 396000000Hz
usdhc1 clock  : 198000000Hz
usdhc2 clock  : 198000000Hz
usdhc3 clock  : 198000000Hz
usdhc4 clock  : 198000000Hz
nfc clock     : 24000000Hz
Board: i.MX6DL/Solo-SABRESD: unknown-board Board: 0x61012 [POR ]
Boot Device: MMC
DRAM:   1 GB
MMC:   FSL_USDHC: 0
Using default environment
In:    serial
Out:   serial
Err:   serial
Net:   got MAC address from IIM: 00:00:00:00:00:00
FEC0 [PRIME]
## Booting kernel from Legacy Image at 10800000 ...
   Image Name:   Linux-3.0.35+
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    3370264 Bytes =  3.2 MB
   Load Address: 10008000
   Entry Point:  10008000
   Verifying Checksum ... OK
## Loading init Ramdisk from Legacy Image at 10c00000 ...
   Image Name:   uboot initramfs rootfs
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    4545326 Bytes =  4.3 MB
   Load Address: 00000000
   Entry Point:  00000000
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Linux version 3.0.35+ (kk@kk-pc) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #9 SMP PREEMPT Thu Sep 10 17:49:33 CST 2015
[    0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
[    0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: Freescale i.MX 6Quad/DualLite/Solo Sabre Auto Board
[    0.000000] Memory policy: ECC disabled, Data cache writealloc
[    0.000000] CPU identified as i.MX6DL/SOLO, silicon rev 1.2
[    0.000000] PERCPU: Embedded 7 pages/cpu @c185f000 s5504 r8192 d14976 u32768
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 206848
[    0.000000] Kernel command line: console=ttymxc3,115200 rdinit=/linuxrc arm_freq=800 enable_wait_mode=off waitmode,rw
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 816MB = 816MB total
[    0.000000] Memory: 814040k/814040k available, 234536k reserved, 147456K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     DMA     : 0xfbe00000 - 0xffe00000   (  64 MB)
[    0.000000]     vmalloc : 0xea800000 - 0xf2000000   ( 120 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xea000000   ( 672 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .init : 0xc0008000 - 0xc003c000   ( 208 kB)
[    0.000000]       .text : 0xc003c000 - 0xc063a000   (6136 kB)
[    0.000000]       .data : 0xc063a000 - 0xc0692f40   ( 356 kB)
[    0.000000]        .bss : 0xc0692f64 - 0xc07d5f88   (1293 kB)
[    0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  Verbose stalled-CPUs detection is disabled.
[    0.000000] NR_IRQS:624
[    0.000000] MXC GPIO hardware
[    0.000000] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms
[    0.000000] Set periph_clk's parent to pll2_pfd_400M!
[    0.000000] arm_max_freq=800MHz
[    0.000000] MXC_Early serial console at MMIO 0x21f0000 (options '115200')
[    0.000000] bootconsole [ttymxc3] enabled
[    0.224509] Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
[    0.317348] pid_max: default: 32768 minimum: 301
[    0.322308] Mount-cache hash table entries: 512
[    0.327803] Initializing cgroup subsys cpuacct
[    0.332325] Initializing cgroup subsys freezer
[    0.336825] CPU: Testing write buffer coherency: ok
[    0.342052] hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
[    0.442720] CPU1: Booted secondary processor
[    0.482094] Brought up 2 CPUs
[    0.489353] SMP: Total of 2 processors activated (3162.11 BogoMIPS).
[    0.515022] print_constraints: dummy:
[    0.519061] NET: Registered protocol family 16
[    0.528199] print_constraints: vddpu: 725 <--> 1300 mV at 700 mV fast normal
[    0.535761] print_constraints: vddcore: 725 <--> 1300 mV at 1150 mV fast normal
[    0.543613] print_constraints: vddsoc: 725 <--> 1300 mV at 1200 mV fast normal
[    0.551313] print_constraints: vdd2p5: 2000 <--> 2775 mV at 2400 mV fast normal
[    0.559154] print_constraints: vdd1p1: 800 <--> 1400 mV at 1100 mV fast normal
[    0.566889] print_constraints: vdd3p0: 2625 <--> 3400 mV at 3000 mV fast normal
[    0.584732] set ssi0 clock: ssi0_sys_clk=12288000
[    0.589462] set ssi1 clock: ssi1_sys_clk=12288000
[    0.594214] set esai clock: esai_sys_clk=12288000
[    0.604351] Initialize Bluetooth power on
[    0.608207] Initialize Bluetooth reset
[    0.782022] Initialize WiFi
[    0.842031] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[    0.849028] hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step.
[    0.856392] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.862286] L310 cache controller enabled
[    0.866315] l2x0: 16 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x02050000, Cache size: 524288 B
[    0.902851] bio: create slab <bio-0> at 0
[    0.910508] mxs-dma mxs-dma-apbh: initialized
[    0.915292] print_constraints: vmmc: 3300 mV
[    0.921277] SCSI subsystem initialized
[    0.925596] spi_imx imx6q-ecspi.0: probed
[    0.930067] spi_imx imx6q-ecspi.2: probed
[    0.935080] usbcore: registered new interface driver usbfs
[    0.940749] usbcore: registered new interface driver hub
[    0.946281] usbcore: registered new device driver usb
[    0.951351] Freescale USB OTG Driver loaded, $Revision: 1.55 $
[    0.972081] imx-ipuv3 imx-ipuv3.0: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
[    0.980392] Advanced Linux Sound Architecture Driver Version 1.0.24.
[    0.988232] i2c-core: driver [max17135] using legacy suspend method
[    0.994537] i2c-core: driver [max17135] using legacy resume method
[    1.000759] Switching to clocksource mxc_timer1
[    1.007713] NET: Registered protocol family 2
[    1.012251] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[    1.020098] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    1.030115] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
[    1.038683] TCP: Hash tables configured (established 131072 bind 65536)
[    1.045324] TCP reno registered
[    1.048512] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    1.054494] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    1.061400] NET: Registered protocol family 1
[    1.066182] RPC: Registered named UNIX socket transport module.
[    1.072123] RPC: Registered udp transport module.
[    1.076873] RPC: Registered tcp transport module.
[    1.081592] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.088225] Unpacking initramfs...
[    1.546506] Freeing initrd memory: 4436K
[    1.557572] Static Power Management for Freescale i.MX6
[    1.562835] wait mode is disabled for i.MX6
[    1.568553] cpaddr = ea820000 suspend_iram_base=ea8a4000
[    1.573980] PM driver module loaded
[    1.582024] IMX usb wakeup probe
[    1.591188] add wake up source irq 75
[    1.606676] IMX usb wakeup probe
[    1.613173] mxc_bt_rfkill driver success loaded
[    1.617832] rfkill: BT RF going to : on
[    1.621693] Bluetooth power on
[    1.625577] cpu regulator mode:ldo_enable
[    1.629921] i.MXC CPU frequency driver
[    1.671283] highmem bounce pool size: 64 pages
[    1.676464] ashmem: initialized
[    1.893254] NTFS driver 2.1.30 [Flags: R/O].
[    1.906262] fuse init (API version 7.16)
[    1.921355] msgmni has been set to 1310
[    1.930238] alg: No test for stdrng (krng)
[    1.934412] io scheduler noop registered
[    1.938553] io scheduler deadline registered
[    1.942952] io scheduler cfq registered (default)
[    1.951792] mxc_sdc_fb mxc_sdc_fb.0: register mxc display driver ldb
[    1.959524] _regulator_get: get() with no identifier
[    2.025427] imx-ipuv3 imx-ipuv3.0: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
[    2.042359] imx-sdma imx-sdma: loaded firmware 1.1
[    2.144807] imx-sdma imx-sdma: initialized
[    3.950853] Serial: IMX driver
[    3.954107] imx-uart.1: ttymxc1 at MMIO 0x21e8000 (irq = 59) is a IMX
[    3.961996] imx-uart.2: ttymxc2 at MMIO 0x21ec000 (irq = 60) is a IMX
[    3.977536] imx-uart.3: ttymxc3 at MMIO 0x21f0000 (irq = 61) is a IMX
[    3.984033] console [ttymxc3] enabled, bootconsole disabled
[    4.059880] loop: module loaded
[    4.063084] [DRM]ipoddrmic_i2c_init(223):module_init
[    4.076931] [DRM]ipoddrmic_i2c_probe(149):probe
[    4.119891] cgpio initialized
[    4.162325] FEC Ethernet Driver
[    4.169390] fec_enet_mii_bus: probed
[    4.184710] PPP generic driver version 2.4.2
[    4.192451] PPP Deflate Compression module registered
[    4.197552] PPP BSD Compression module registered
[    4.208956] PPP MPPE Compression module registered
[    4.213758] NET: Registered protocol family 24
[    4.218367] PPTP driver version 0.8.5
[    4.222850] tun: Universal TUN/TAP device driver, 1.6
[    4.227959] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    4.239260] usbcore: registered new interface driver smsc95xx
[    4.245045] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    4.256667] fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
[    4.263605] fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
[    4.295384] fsl-ehci fsl-ehci.0: irq 75, io base 0x02184000
[    4.315364] fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
[    4.322415] hub 1-0:1.0: USB hub found
[    4.326242] hub 1-0:1.0: 1 port detected
[    4.330539] add wake up source irq 72
[    4.334264] fsl-ehci fsl-ehci.1: Freescale On-Chip EHCI Host Controller
[    4.340931] fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2
[    4.375392] fsl-ehci fsl-ehci.1: irq 72, io base 0x02184200
[    4.395372] fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00
[    4.402460] hub 2-0:1.0: USB hub found
[    4.406283] hub 2-0:1.0: 1 port detected
[    4.412400] usbcore: registered new interface driver cdc_acm
[    4.420970] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    4.429068] Initializing USB Mass Storage driver...
[    4.434506] usbcore: registered new interface driver usb-storage
[    4.440572] USB Mass Storage support registered.
[    4.446386] usbcore: registered new interface driver usbserial
[    4.452234] usbserial: USB Serial Driver core
[    4.460885] USB Serial support registered for GSM modem (1-port)
[    4.471357] usbcore: registered new interface driver option
[    4.476963] option: v0.7.2:USB Driver for GSM modems
[    4.481937] ARC USBOTG Device Controller driver (1 August 2005)
[    4.492573] g_file_storage gadget: controller 'fsl-usb2-udc' not recognized
[    4.503358] check_parameters:UTP settings are in place now, overriding defaults
[    4.510766] g_file_storage gadget: No serial-number string provided!
[    4.518137] g_file_storage gadget: File-backed Storage Gadget, version: 1 September 2010
[    4.526301] g_file_storage gadget: Number of LUNs=1
[    4.531203] Suspend udc for OTG auto detect
[    4.535961] udc_controller->stopped
[    4.542767] fsl-usb2-udc: bind to driver g_file_storage
[    4.548102] suspend_irq
[    4.556645] input: rpc-keys as /devices/platform/rpc-keys/input/input0
[    4.573357] lsm330dlc_acc accelerometer driver: init
[    4.581487] i2c-core: driver [lsm330dlc_acc] using legacy suspend method
[    4.588270] i2c-core: driver [lsm330dlc_acc] using legacy resume method
[    4.594911] lsm330dlc_gyr: gyroscope sysfs driver init
[    4.614667] using rtc device, snvs_rtc, for alarms
[    4.619481] snvs_rtc snvs_rtc.0: rtc core: registered snvs_rtc as rtc0
[    4.626787] i2c /dev entries driver
[    4.640024]
[    4.640032]
[    4.640035] xf6000ye_vc_probe!!!
[    4.640042]
[    4.668389] XF6000YE VC is ready!
[    4.668396]
[    4.668399]  ch9setaddress 22
[    4.996818] [wangjiachao]Dymicle init char type device !!!! MAJOR = 250, MINOR = 0
[    5.005743] Linux video capture interface: v2.00
[    5.057101] ioctl_s_power
[    5.059740] ioctl_g_fmt_cap
[    5.062770] tw9990_reg_write:write reg error:reg=0, val=58, res = -5
[    5.069370] tw9990_reg_read:write reg error! reg=0
[    5.074256] +++++++++++ wirte unsuccessed! addr = 0 val = 88 ,val = 0+++++++++++
[    5.081863] tw9990_reg_write:write reg error:reg=1, val=78, res = -5
[    5.088424] tw9990_reg_read:write reg error! reg=1
[    5.093308] +++++++++++ wirte unsuccessed! addr = 1 val = 120 ,val = 0+++++++++++
[    5.101034] tw9990_reg_write:write reg error:reg=2, val=40, res = -5
[    5.107596] tw9990_reg_read:write reg error! reg=2
[    5.112480] +++++++++++ wirte unsuccessed! addr = 2 val = 64 ,val = 0+++++++++++
[    5.120080] tw9990_reg_write:write reg error:reg=3, val=a2, res = -5
[    5.126644] tw9990_reg_read:write reg error! reg=3
[    5.131527] +++++++++++ wirte unsuccessed! addr = 3 val = 162 ,val = 0+++++++++++
[    5.139214] tw9990_reg_write:write reg error:reg=4, val=0, res = -5
[    5.145684] tw9990_reg_read:write reg error! reg=4
[    5.150752] tw9990_reg_write:write reg error:reg=5, val=0, res = -5
[    5.157229] tw9990_reg_read:write reg error! reg=5
[    5.162300] tw9990_reg_write:write reg error:reg=6, val=0, res = -5
[    5.168776] tw9990_reg_read:write reg error! reg=6
[    5.173847] tw9990_reg_write:write reg error:reg=7, val=2, res = -5
[    5.180321] tw9990_reg_read:write reg error! reg=7
[    5.185204] +++++++++++ wirte unsuccessed! addr = 7 val = 2 ,val = 0+++++++++++
[    5.192726] tw9990_reg_write:write reg error:reg=8, val=13, res = -5
[    5.199286] tw9990_reg_read:write reg error! reg=8
[    5.204170] +++++++++++ wirte unsuccessed! addr = 8 val = 19 ,val = 0+++++++++++
[    5.211780] tw9990_reg_write:write reg error:reg=9, val=f0, res = -5
[    5.218339] tw9990_reg_read:write reg error! reg=9
[    5.223222] +++++++++++ wirte unsuccessed! addr = 9 val = 240 ,val = 0+++++++++++
[    5.230920] tw9990_reg_write:write reg error:reg=a, val=12, res = -5
[    5.237482] tw9990_reg_read:write reg error! reg=a
[    5.242365] +++++++++++ wirte unsuccessed! addr = 10 val = 18 ,val = 0+++++++++++
[    5.250051] tw9990_reg_write:write reg error:reg=b, val=d0, res = -5
[    5.256875] tw9990_reg_read:write reg error! reg=b
[    5.261758] +++++++++++ wirte unsuccessed! addr = 11 val = 208 ,val = 0+++++++++++
[    5.269561] tw9990_reg_write:write reg error:reg=c, val=cc, res = -5
[    5.276123] tw9990_reg_read:write reg error! reg=c
[    5.281006] +++++++++++ wirte unsuccessed! addr = 12 val = 204 ,val = 0+++++++++++
[    5.288785] tw9990_reg_write:write reg error:reg=d, val=0, res = -5
[    5.295246] tw9990_reg_read:write reg error! reg=d
[    5.300333] tw9990_reg_write:write reg error:reg=e, val=11, res = -5
[    5.306893] tw9990_reg_read:write reg error! reg=e
[    5.311776] +++++++++++ wirte unsuccessed! addr = 14 val = 17 ,val = 0+++++++++++
[    5.319466] tw9990_reg_write:write reg error:reg=f, val=0, res = -5
[    5.325940] tw9990_reg_read:write reg error! reg=f
[    5.331012] tw9990_reg_write:write reg error:reg=10, val=f0, res = -5
[    5.337673] tw9990_reg_read:write reg error! reg=10
[    5.342643] +++++++++++ wirte unsuccessed! addr = 16 val = 240 ,val = 0+++++++++++
[    5.350422] tw9990_reg_write:write reg error:reg=11, val=60, res = -5
[    5.357068] tw9990_reg_read:write reg error! reg=11
[    5.362038] +++++++++++ wirte unsuccessed! addr = 17 val = 96 ,val = 0+++++++++++
[    5.369728] tw9990_reg_write:write reg error:reg=12, val=11, res = -5
[    5.376374] tw9990_reg_read:write reg error! reg=12
[    5.381344] +++++++++++ wirte unsuccessed! addr = 18 val = 17 ,val = 0+++++++++++
[    5.389034] tw9990_reg_write:write reg error:reg=13, val=80, res = -5
[    5.395683] tw9990_reg_read:write reg error! reg=13
[    5.400652] +++++++++++ wirte unsuccessed! addr = 19 val = 128 ,val = 0+++++++++++
[    5.408435] tw9990_reg_write:write reg error:reg=14, val=80, res = -5
[    5.415068] tw9990_reg_read:write reg error! reg=14
[    5.420052] +++++++++++ wirte unsuccessed! addr = 20 val = 128 ,val = 0+++++++++++
[    5.427828] tw9990_reg_write:write reg error:reg=15, val=0, res = -5
[    5.434374] tw9990_reg_read:write reg error! reg=15
[    5.439548] tw9990_reg_write:write reg error:reg=16, val=0, res = -5
[    5.446107] tw9990_reg_read:write reg error! reg=16
[    5.451265] tw9990_reg_write:write reg error:reg=17, val=80, res = -5
[    5.457912] tw9990_reg_read:write reg error! reg=17
[    5.462883] +++++++++++ wirte unsuccessed! addr = 23 val = 128 ,val = 0+++++++++++
[    5.470659] tw9990_reg_write:write reg error:reg=18, val=44, res = -5
[    5.477307] tw9990_reg_read:write reg error! reg=18
[    5.482278] +++++++++++ wirte unsuccessed! addr = 24 val = 68 ,val = 0+++++++++++
[    5.489967] tw9990_reg_write:write reg error:reg=19, val=58, res = -5
[    5.496615] tw9990_reg_read:write reg error! reg=19
[    5.501585] +++++++++++ wirte unsuccessed! addr = 25 val = 88 ,val = 0+++++++++++
[    5.509277] tw9990_reg_write:write reg error:reg=1a, val=0, res = -5
[    5.515838] tw9990_reg_read:write reg error! reg=1a
[    5.520996] tw9990_reg_write:write reg error:reg=1b, val=0, res = -5
[    5.527557] tw9990_reg_read:write reg error! reg=1b
[    5.532716] tw9990_reg_write:write reg error:reg=1c, val=7, res = -5
[    5.539276] tw9990_reg_read:write reg error! reg=1c
[    5.544246] +++++++++++ wirte unsuccessed! addr = 28 val = 7 ,val = 0+++++++++++
[    5.551850] tw9990_reg_write:write reg error:reg=1d, val=7f, res = -5
[    5.558497] tw9990_reg_read:write reg error! reg=1d
[    5.563467] +++++++++++ wirte unsuccessed! addr = 29 val = 127 ,val = 0+++++++++++
[    5.571244] tw9990_reg_write:write reg error:reg=1e, val=8, res = -5
[    5.577805] tw9990_reg_read:write reg error! reg=1e
[    5.582775] +++++++++++ wirte unsuccessed! addr = 30 val = 8 ,val = 0+++++++++++
[    5.590379] tw9990_reg_write:write reg error:reg=1f, val=0, res = -5
[    5.596939] tw9990_reg_read:write reg error! reg=1f
[    5.602098] tw9990_reg_write:write reg error:reg=20, val=50, res = -5
[    5.608749] tw9990_reg_read:write reg error! reg=20
[    5.613719] +++++++++++ wirte unsuccessed! addr = 32 val = 80 ,val = 0+++++++++++
[    5.621411] tw9990_reg_write:write reg error:reg=21, val=22, res = -5
[    5.628059] tw9990_reg_read:write reg error! reg=21
[    5.633029] +++++++++++ wirte unsuccessed! addr = 33 val = 34 ,val = 0+++++++++++
[    5.640719] tw9990_reg_write:write reg error:reg=22, val=f0, res = -5
[    5.647365] tw9990_reg_read:write reg error! reg=22
[    5.652335] +++++++++++ wirte unsuccessed! addr = 34 val = 240 ,val = 0+++++++++++
[    5.660112] tw9990_reg_write:write reg error:reg=23, val=d8, res = -5
[    5.666759] tw9990_reg_read:write reg error! reg=23
[    5.671729] +++++++++++ wirte unsuccessed! addr = 35 val = 216 ,val = 0+++++++++++
[    5.679505] tw9990_reg_write:write reg error:reg=24, val=bc, res = -5
[    5.686153] tw9990_reg_read:write reg error! reg=24
[    5.691123] +++++++++++ wirte unsuccessed! addr = 36 val = 188 ,val = 0+++++++++++
[    5.698900] tw9990_reg_write:write reg error:reg=25, val=b8, res = -5
[    5.705548] tw9990_reg_read:write reg error! reg=25
[    5.710518] +++++++++++ wirte unsuccessed! addr = 37 val = 184 ,val = 0+++++++++++
[    5.718296] tw9990_reg_write:write reg error:reg=26, val=44, res = -5
[    5.724930] tw9990_reg_read:write reg error! reg=26
[    5.729913] +++++++++++ wirte unsuccessed! addr = 38 val = 68 ,val = 0+++++++++++
[    5.737602] tw9990_reg_write:write reg error:reg=27, val=38, res = -5
[    5.744236] tw9990_reg_read:write reg error! reg=27
[    5.749219] +++++++++++ wirte unsuccessed! addr = 39 val = 56 ,val = 0+++++++++++
[    5.756908] tw9990_reg_write:write reg error:reg=28, val=0, res = -5
[    5.763454] tw9990_reg_read:write reg error! reg=28
[    5.768626] tw9990_reg_write:write reg error:reg=29, val=0, res = -5
[    5.775174] tw9990_reg_read:write reg error! reg=29
[    5.780345] tw9990_reg_write:write reg error:reg=2a, val=78, res = -5
[    5.786991] tw9990_reg_read:write reg error! reg=2a
[    5.791961] +++++++++++ wirte unsuccessed! addr = 42 val = 120 ,val = 0+++++++++++
[    5.799738] tw9990_reg_write:write reg error:reg=2b, val=44, res = -5
[    5.806389] tw9990_reg_read:write reg error! reg=2b
[    5.811359] +++++++++++ wirte unsuccessed! addr = 43 val = 68 ,val = 0+++++++++++
[    5.819050] tw9990_reg_write:write reg error:reg=2c, val=30, res = -5
[    5.825698] tw9990_reg_read:write reg error! reg=2c
[    5.830669] +++++++++++ wirte unsuccessed! addr = 44 val = 48 ,val = 0+++++++++++
[    5.838360] tw9990_reg_write:write reg error:reg=2d, val=14, res = -5
[    5.844994] tw9990_reg_read:write reg error! reg=2d
[    5.849978] +++++++++++ wirte unsuccessed! addr = 45 val = 20 ,val = 0+++++++++++
[    5.857665] tw9990_reg_write:write reg error:reg=2e, val=a5, res = -5
[    5.864301] tw9990_reg_read:write reg error! reg=2e
[    5.869284] +++++++++++ wirte unsuccessed! addr = 46 val = 165 ,val = 0+++++++++++
[    5.877059] tw9990_reg_write:write reg error:reg=2f, val=e0, res = -5
[    5.883693] tw9990_reg_read:write reg error! reg=2f
[    5.888676] +++++++++++ wirte unsuccessed! addr = 47 val = 224 ,val = 0+++++++++++
[    5.896452] tw9990_reg_write:write reg error:reg=30, val=0, res = -5
[    5.902998] tw9990_reg_read:write reg error! reg=30
[    5.908172] tw9990_reg_write:write reg error:reg=31, val=10, res = -5
[    5.914805] tw9990_reg_read:write reg error! reg=31
[    5.919789] +++++++++++ wirte unsuccessed! addr = 49 val = 16 ,val = 0+++++++++++
[    5.927479] tw9990_reg_write:write reg error:reg=32, val=ff, res = -5
[    5.934113] tw9990_reg_read:write reg error! reg=32
[    5.939097] +++++++++++ wirte unsuccessed! addr = 50 val = 255 ,val = 0+++++++++++
[    5.946873] tw9990_reg_write:write reg error:reg=33, val=5, res = -5
[    5.953420] tw9990_reg_read:write reg error! reg=33
[    5.958404] +++++++++++ wirte unsuccessed! addr = 51 val = 5 ,val = 0+++++++++++
[    5.966006] tw9990_reg_write:write reg error:reg=34, val=1a, res = -5
[    5.972641] tw9990_reg_read:write reg error! reg=34
[    5.977624] +++++++++++ wirte unsuccessed! addr = 52 val = 26 ,val = 0+++++++++++
[    5.985303] tw9990_reg_write:write reg error:reg=35, val=0, res = -5
[    5.991865] tw9990_reg_read:write reg error! reg=35
[    5.997037] tw9990_reg_write:write reg error:reg=36, val=0, res = -5
[    6.003583] tw9990_reg_read:write reg error! reg=36
[    6.008759] tw9990_reg_write:write reg error:reg=37, val=0, res = -5
[    6.015307] tw9990_reg_read:write reg error! reg=37
[    6.020481] tw9990_reg_write:write reg error:reg=38, val=0, res = -5
[    6.027041] tw9990_reg_read:write reg error! reg=38
[    6.032201] tw9990_reg_write:write reg error:reg=39, val=0, res = -5
[    6.038762] tw9990_reg_read:write reg error! reg=39
[    6.043921] tw9990_reg_write:write reg error:reg=3a, val=0, res = -5
[    6.050482] tw9990_reg_read:write reg error! reg=3a
[    6.055656] tw9990_reg_write:write reg error:reg=3b, val=0, res = -5
[    6.062203] tw9990_reg_read:write reg error! reg=3b
[    6.067375] tw9990_reg_write:write reg error:reg=3c, val=0, res = -5
[    6.073924] tw9990_reg_read:write reg error! reg=3c
[    6.079096] tw9990_reg_write:write reg error:reg=3d, val=0, res = -5
[    6.085658] tw9990_reg_read:write reg error! reg=3d
[    6.090816] tw9990_reg_write:write reg error:reg=3e, val=0, res = -5
[    6.097377] tw9990_reg_read:write reg error! reg=3e
[    6.102535] tw9990_reg_write:write reg error:reg=3f, val=0, res = -5
[    6.109097] tw9990_reg_read:write reg error! reg=3f
[    6.114255] tw9990_reg_write:write reg error:reg=40, val=0, res = -5
[    6.120815] tw9990_reg_read:write reg error! reg=40
[    6.125989] tw9990_reg_write:write reg error:reg=41, val=0, res = -5
[    6.132536] tw9990_reg_read:write reg error! reg=41
[    6.137708] tw9990_reg_write:write reg error:reg=42, val=0, res = -5
[    6.144254] tw9990_reg_read:write reg error! reg=42
[    6.149425] tw9990_reg_write:write reg error:reg=43, val=0, res = -5
[    6.155985] tw9990_reg_read:write reg error! reg=43
[    6.161143] tw9990_reg_write:write reg error:reg=44, val=0, res = -5
[    6.167705] tw9990_reg_read:write reg error! reg=44
[    6.172864] tw9990_reg_write:write reg error:reg=45, val=0, res = -5
[    6.179424] tw9990_reg_read:write reg error! reg=45
[    6.184584] tw9990_reg_write:write reg error:reg=46, val=0, res = -5
[    6.191145] tw9990_reg_read:write reg error! reg=46
[    6.196317] tw9990_reg_write:write reg error:reg=47, val=0, res = -5
[    6.202864] tw9990_reg_read:write reg error! reg=47
[    6.208039] tw9990_reg_write:write reg error:reg=48, val=0, res = -5
[    6.214587] tw9990_reg_read:write reg error! reg=48
[    6.219760] tw9990_reg_write:write reg error:reg=49, val=0, res = -5
[    6.226322] tw9990_reg_read:write reg error! reg=49
[    6.231480] tw9990_reg_write:write reg error:reg=4a, val=0, res = -5
[    6.238038] tw9990_reg_read:write reg error! reg=4a
[    6.243196] tw9990_reg_write:write reg error:reg=4b, val=0, res = -5
[    6.249756] tw9990_reg_read:write reg error! reg=4b
[    6.254916] tw9990_reg_write:write reg error:reg=4c, val=0, res = -5
[    6.261476] tw9990_reg_read:write reg error! reg=4c
[    6.266667] tw9990_reg_write:write reg error:reg=4d, val=0, res = -5
[    6.273213] tw9990_reg_read:write reg error! reg=4d
[    6.278382] tw9990_reg_write:write reg error:reg=4e, val=8a, res = -5
[    6.285012] tw9990_reg_read:write reg error! reg=4e
[    6.290002] +++++++++++ wirte unsuccessed! addr = 78 val = 138 ,val = 0+++++++++++
[    6.297781] tw9990_reg_write:write reg error:reg=4f, val=0, res = -5
[    6.304327] tw9990_reg_read:write reg error! reg=4f
[    6.309499] tw9990_reg_write:write reg error:reg=50, val=a0, res = -5
[    6.316146] tw9990_reg_read:write reg error! reg=50
[    6.321117] +++++++++++ wirte unsuccessed! addr = 80 val = 160 ,val = 0+++++++++++
[    6.328894] tw9990_reg_write:write reg error:reg=51, val=22, res = -5
[    6.335540] tw9990_reg_read:write reg error! reg=51
[    6.340510] +++++++++++ wirte unsuccessed! addr = 81 val = 34 ,val = 0+++++++++++
[    6.348201] tw9990_reg_write:write reg error:reg=52, val=31, res = -5
[    6.354835] tw9990_reg_read:write reg error! reg=52
[    6.359818] +++++++++++ wirte unsuccessed! addr = 82 val = 49 ,val = 0+++++++++++
[    6.367506] tw9990_reg_write:write reg error:reg=53, val=80, res = -5
[    6.374139] tw9990_reg_read:write reg error! reg=53
[    6.379123] +++++++++++ wirte unsuccessed! addr = 83 val = 128 ,val = 0+++++++++++
[    6.386898] tw9990_reg_write:write reg error:reg=54, val=0, res = -5
[    6.393445] tw9990_reg_read:write reg error! reg=54
[    6.398618] tw9990_reg_write:write reg error:reg=55, val=0, res = -5
[    6.405164] tw9990_reg_read:write reg error! reg=55
[    6.410341] tw9990_reg_write:write reg error:reg=56, val=0, res = -5
[    6.416901] tw9990_reg_read:write reg error! reg=56
[    6.422059] tw9990_reg_write:write reg error:reg=57, val=0, res = -5
[    6.428618] tw9990_reg_read:write reg error! reg=57
[    6.433777] tw9990_reg_write:write reg error:reg=58, val=0, res = -5
[    6.440336] tw9990_reg_read:write reg error! reg=58
[    6.445508] tw9990_reg_write:write reg error:reg=59, val=0, res = -5
[    6.452056] tw9990_reg_read:write reg error! reg=59
[    6.457228] tw9990_reg_write:write reg error:reg=5a, val=0, res = -5
[    6.463774] tw9990_reg_read:write reg error! reg=5a
[    6.468946] tw9990_reg_write:write reg error:reg=5b, val=0, res = -5
[    6.475505] tw9990_reg_read:write reg error! reg=5b
[    6.480664] tw9990_reg_write:write reg error:reg=5c, val=0, res = -5
[    6.487223] tw9990_reg_read:write reg error! reg=5c
[    6.492382] tw9990_reg_write:write reg error:reg=5d, val=0, res = -5
[    6.498943] tw9990_reg_read:write reg error! reg=5d
[    6.504101] tw9990_reg_write:write reg error:reg=5e, val=0, res = -5
[    6.510661] tw9990_reg_read:write reg error! reg=5e
[    6.515834] tw9990_reg_write:write reg error:reg=5f, val=0, res = -5
[    6.522381] tw9990_reg_read:write reg error! reg=5f
[    6.527554] tw9990_reg_write:write reg error:reg=60, val=0, res = -5
[    6.534101] tw9990_reg_read:write reg error! reg=60
[    6.539274] tw9990_reg_write:write reg error:reg=61, val=0, res = -5
[    6.545836] tw9990_reg_read:write reg error! reg=61
[    6.550994] tw9990_reg_write:write reg error:reg=62, val=0, res = -5
[    6.557553] tw9990_reg_read:write reg error! reg=62
[    6.562713] tw9990_reg_write:write reg error:reg=63, val=0, res = -5
[    6.569273] tw9990_reg_read:write reg error! reg=63
[    6.574432] tw9990_reg_write:write reg error:reg=64, val=0, res = -5
[    6.580993] tw9990_reg_read:write reg error! reg=64
[    6.586165] tw9990_reg_write:write reg error:reg=65, val=0, res = -5
[    6.592711] tw9990_reg_read:write reg error! reg=65
[    6.597884] tw9990_reg_write:write reg error:reg=66, val=0, res = -5
[    6.604432] tw9990_reg_read:write reg error! reg=66
[    6.609608] tw9990_reg_write:write reg error:reg=67, val=0, res = -5
[    6.616168] tw9990_reg_read:write reg error! reg=67
[    6.621326] tw9990_reg_write:write reg error:reg=68, val=0, res = -5
[    6.627885] tw9990_reg_read:write reg error! reg=68
[    6.633044] tw9990_reg_write:write reg error:reg=69, val=0, res = -5
[    6.639603] tw9990_reg_read:write reg error! reg=69
[    6.644763] tw9990_reg_write:write reg error:reg=6a, val=0, res = -5
[    6.651322] tw9990_reg_read:write reg error! reg=6a
[    6.656493] tw9990_reg_write:write reg error:reg=6b, val=2c, res = -5
[    6.663126] tw9990_reg_read:write reg error! reg=6b
[    6.668110] +++++++++++ wirte unsuccessed! addr = 107 val = 44 ,val = 0+++++++++++
[    6.675887] tw9990_reg_write:write reg error:reg=6c, val=60, res = -5
[    6.682520] tw9990_reg_read:write reg error! reg=6c
[    6.687504] +++++++++++ wirte unsuccessed! addr = 108 val = 96 ,val = 0+++++++++++
[    6.695269] tw9990_reg_write:write reg error:reg=6d, val=0, res = -5
[    6.701830] tw9990_reg_read:write reg error! reg=6d
[    6.707003] tw9990_reg_write:write reg error:reg=6e, val=20, res = -5
[    6.713637] tw9990_reg_read:write reg error! reg=6e
[    6.718621] +++++++++++ wirte unsuccessed! addr = 110 val = 32 ,val = 0+++++++++++
[    6.726397] tw9990_reg_write:write reg error:reg=6f, val=24, res = -5
[    6.733030] tw9990_reg_read:write reg error! reg=6f
[    6.738014] +++++++++++ wirte unsuccessed! addr = 111 val = 36 ,val = 0+++++++++++
[    6.754076] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video16
[    6.766231] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video17
[    6.780149] imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=1)
[    6.796195] SoftDog: cannot register miscdev on minor=130 (err=-16)
[    6.803031] sdhci: Secure Digital Host Controller Interface driver
[    6.813068] sdhci: Copyright(c) Pierre Ossman
[    6.825129] mmc0: SDHCI controller on platform [sdhci-esdhc-imx.3] using ADMA
[    6.844032] mmc1: SDHCI controller on platform [sdhci-esdhc-imx.2] using ADMA
[    6.851881] mxc_vdoa mxc_vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
[    6.875271] VPU initialized
[    6.882650] Galcore version 4.6.9.9754
[    6.917541] revserved_memory_account:viv_gpu registerd
[    6.927048] Thermal calibration data is 0x5844ce7d
[    6.931855] Thermal sensor with ratio = 183
[    6.955417] Anatop Thermal registered as thermal_zone0
[    6.961138] anatop_thermal_probe: default cooling device is cpufreq!
[    6.991034] usbcore: registered new interface driver usbhid
[    6.996695] usbhid: USB HID core driver
[    7.002750] logger: created 256K log 'log_main'
[    7.012572] logger: created 256K log 'log_events'
[    7.018106] logger: created 256K log 'log_radio'
[    7.023630] logger: created 256K log 'log_system'
[    7.039779] usbcore: registered new interface driver snd-usb-audio
[    7.056672] mxc_spdif mxc_spdif.0: MXC SPDIF Audio
[    7.062165] codec-tef6638 codec-tef6638.0: tef6638 Audio codec
[    7.072260] ak5701 spi2.0: MIC ADC AK5701 codec
[    7.078507] codec-bthci codec-bthci: BT HCI Audio codec
[    7.133322] asoc: bthci <-> imx-ssi.0 mapping ok
[    7.158724] ASoC: ssi0-card initialled
[    7.162129] mmc0: new high speed DDR MMC card at address 0001
[    7.169037] mmcblk0: mmc0:0001 MMC16G 14.4 GiB
[    7.174758] mmcblk0boot0: mmc0:0001 MMC16G partition 1 16.0 MiB
[    7.181472] asoc: tef6638-3 <-> imx-ssi.1 mapping ok
[    7.183423] mmcblk0boot1: mmc0:0001 MMC16G partition 2 16.0 MiB
[    7.187518]  mmcblk0: p1 p2 p3 < p5 p6 p7 p8 p9 > p4
[    7.187892] mmcblk0: p4 size 26042368 extends beyond EOD, truncated
[    7.228353] ASoC: ssi1-card initialled
[    7.252268] asoc: micadc-ak5701 <-> imx-esai.0 mapping ok
[    7.276136]  mmcblk0boot1: unknown partition table
[    7.283634] +imx_spdif_init()
[    7.295904]  mmcblk0boot0: unknown partition table
[    7.311086] asoc: mxc-spdif <-> imx-spdif-dai.0 mapping ok
[    7.332770] -imx_spdif_init()
[    7.335871] ALSA device list:
[    7.338855]   #0: ssi0-card
[    7.341663]   #1: ssi1-card
[    7.344470]   #2: esai-card
[    7.347307]   #3: imx-spdif
[    7.359145] oprofile: using arm/armv7-ca9
[    7.363323] nf_conntrack version 0.5.0 (12788 buckets, 51152 max)
[    7.375833] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[    7.382812] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[    7.392612] IPv4 over IPv4 tunneling driver
[    7.398003] mmc1: queuing unknown CIS tuple 0x01 (3 bytes)
[    7.412576] GRE over IPv4 demultiplexor driver
[    7.413714] mmc1: queuing unknown CIS tuple 0x1a (5 bytes)
[    7.417520] mmc1: queuing unknown CIS tuple 0x1b (8 bytes)
[    7.418233] mmc1: queuing unknown CIS tuple 0x14 (0 bytes)
[    7.430930] mmc1: queuing unknown CIS tuple 0x80 (1 bytes)
[    7.431018] mmc1: queuing unknown CIS tuple 0x81 (1 bytes)
[    7.431107] mmc1: queuing unknown CIS tuple 0x82 (1 bytes)
[    7.431152] mmc1: new high speed SDIO card at address 0001
[    7.459331] ip_tables: (C) 2000-2006 Netfilter Core Team
[    7.464784] TCP cubic registered
[    7.479652] NET: Registered protocol family 10
[    7.485609] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    7.491052] NET: Registered protocol family 17
[    7.495576] NET: Registered protocol family 15
[    7.500035] L2TP core driver, V2.0
[    7.503450] PPPoL2TP kernel driver, V2.0
[    7.507458] L2TP IP encapsulation support (L2TPv3)
[    7.512971] L2TP netlink interface
[    7.516439] L2TP ethernet pseudowire support (L2TPv3)
[    7.521504] lib80211: common routines for IEEE802.11 drivers
[    7.527208] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[    7.535726] Bus freq driver module loaded
[    7.539757] Bus freq driver Enabled
[    7.546196] mxc_dvfs_core_probe
[    7.549989] DVFS driver module loaded
[    7.560634] snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 00:00:02 UTC (2)
[    7.573216] Freeing init memory: 208K
Starting UTP
ln: /etc/mtab: File exists
disable turn off display
/linuxrc: line 13: can't create /dev/tty0: No such device or address
Starting the hotplug events dispatcher udevd
[    7.635721] udevd (2171): /proc/2171/oom_adj is deprecated, please use /proc/2171/oom_score_adj instead.
Synthesizing initial hotplug events
uuc 0.4 [built Aug 16 2013 01:24:08]
UTP: Waiting for device to appear
UTP: file/device node /dev/utp already exists
cpu_id is 0
[   16.761607] ch9setaddress 22
[   16.876547] g_file_storage gadget: high speed config #1
UTP: received command '$ dd if=/dev/zero of=/dev/mmcblk0 bs=512 seek=1536 count=16'
UTP: executing "dd if=/dev/zero of=/dev/mmcblk0 bs=512 seek=1536 count=16"
16+0 records in
16+0 records out
8192 bytes (8.0KB) copied, 0.033139 seconds, 241.4KB/s
UTP: sending Success to kernel for command $ dd if=/dev/zero of=/dev/mmcblk0 bs=512 seek=1536 count=16.
[   17.378099] utp_poll: pass returned.
UTP: received command '$ echo 0 > /sys/block/mmcblk0boot0/force_ro'
UTP: executing "echo 0 > /sys/block/mmcblk0boot0/force_ro"
UTP: sending Success to kernel for command $ echo 0 > /sys/block/mmcblk0boot0/force_ro.
[   17.652729] utp_poll: pass returned.
UTP: received command 'send'
UTP: sending Success to kernel for command send.
UTP: received command '$ dd if=$FILE of=/dev/mmcblk0boot0 bs=512 seek=2 skip=2'
UTP: executing "dd if=$FILE of=/dev/mmcblk0boot0 bs=512 seek=2 skip=2"
423+1 records in
423+1 records out
216780 bytes (211.7KB) copied, 0.621580 seconds, 340.6KB/s
UTP: sending Success to kernel for command $ dd if=$FILE of=/dev/mmcblk0boot0 bs=512 seek=2 skip=2.
[   18.533974] utp_poll: pass returned.
UTP: received command '$ echo 1 > /sys/block/mmcblk0boot0/force_ro'
UTP: executing "echo 1 > /sys/block/mmcblk0boot0/force_ro"
UTP: sending Success to kernel for command $ echo 1 > /sys/block/mmcblk0boot0/force_ro.
[   18.814749] utp_poll: pass returned.
UTP: received command 'frf'
UTP: closing the file
UTP: sending Success to kernel for command frf.
[   19.096299] utp_poll: pass returned.
UTP: received command '$ tar xf $FILE '
UTP: executing "tar xf $FILE "
tar: invalid tar magic
UTP: sending Non-success to kernel for command $ tar xf $FILE .
log:
DLL version: 2.2.3
Wednesday, August 03, 2016 08:58:32   Start new logging
ModuleID[2] LevelID[10]: CMyExceptionHandler thread is running
ModuleID[2] LevelID[1]: new MxHidDeviceClass
ModuleID[2] LevelID[10]: Device Manager thread is running
ModuleID[2] LevelID[10]: DeviceManager:evChangeWnd::OnDeviceChange() - DEVICE_ARRIVAL_EVT(\\?\USB#VID_15A2&ID_0061#7&25c389c1&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
ModuleID[2] LevelID[10]: DeviceManager:evChangeWnd::OnDeviceChange() - end
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_ARRIVAL_EVT(\\?\USB#VID_15A2&ID_0061#7&25c389c1&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
ModuleID[2] LevelID[10]: DeviceClass::FindDeviceByUsbPath--DeviceListType_Current, _devices.size: 0
ModuleID[2] LevelID[1]: DeviceClass::FindDeviceByUsbPath() - DeviceListType_New--index: 0
ModuleID[2] LevelID[1]: DeviceClass::FindDeviceByUsbPath() - DeviceListType_New--devPath: \\?\hid#vid_0e0f&pid_0003&mi_01#8&2f818f48&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
ModuleID[2] LevelID[1]: DeviceClass::FindDeviceByUsbPath() - DeviceListType_New--index: 1
ModuleID[2] LevelID[1]: DeviceClass::FindDeviceByUsbPath() - DeviceListType_New--devPath: \\?\hid#vid_15a2&pid_0061#8&3b7e8d8f&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
ModuleID[2] LevelID[10]: new MxHidDevice[02770A38]
ModuleID[2] LevelID[10]: DeviceClass::FindDeviceByUsbPath--DeviceListType_New, devInstPathToFind: USB\VID_15A2&ID_0061\7&25C389C1&0&1, _deviceInstanceID: USB\VID_15A2&ID_0061\7&25C389C1&0&1
ModuleID[2] LevelID[10]: DeviceClass::FindDeviceByUsbPath--DeviceListType_New, Find the device, Port: 1
ModuleID[2] LevelID[10]: DeviceClass::AddUsbDevice() successful USB#VID_15A2&ID_0061#7&25C389C1&0&1#{A5DCBF10-6530-11D2-901F-00C04FB951ED} add to current list, retrycount: 0
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_ARRIVAL_EVT,[MxHidDeviceClass] vid_15a2&pid_0061, Hub:2-Port:1
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_ARRIVAL_EVT, Notify
ModuleID[2] LevelID[10]: CmdOpreation[0]--OnDeviceChangeNotify, Volume Arrive/Remove or Device Arrive/Remove
ModuleID[2] LevelID[10]: CmdOpreation[0]--OnDeviceChangeNotify, m_p_usb_port is not NULL, so only refresh
ModuleID[2] LevelID[10]: CmdOpreation[0]--OnDeviceChangeNotify, Volume/Device Arrive
ModuleID[2] LevelID[1]: CmdOpreation[0]--set m_hDeviceArriveEvent.
ModuleID[2] LevelID[10]: CmdOpreation[0]--WaitforEvents device arrive1
ModuleID[2] LevelID[10]: CmdOperation[0] device chagned and reset to state 0
ModuleID[2] LevelID[10]: ExecuteCommand--Boot[WndIndex:0], File is C:\Users\li-cah\Documents\123\C33DB_PC_Update_20151202_PR\Profiles\C3ALFUS\OS Firmware\u-boot.bin
ModuleID[2] LevelID[10]: ExecuteCommand--Load[WndIndex:0], File is C:\Users\li-cah\Documents\123\C33DB_PC_Update_20151202_PR\Profiles\C3ALFUS\OS Firmware\uImage, address is 0x10800000
ModuleID[2] LevelID[10]: PortMgrDlg(0)--Command Load excute successfully, retry count: 0
ModuleID[2] LevelID[10]: ExecuteCommand--Load[WndIndex:0], File is C:\Users\li-cah\Documents\123\C33DB_PC_Update_20151202_PR\Profiles\C3ALFUS\OS Firmware\initramfs.cpio.gz.uboot, address is 0x10C00000
ModuleID[2] LevelID[10]: ExecuteCommand--Jump[WndIndex:0]
ModuleID[2] LevelID[10]: *********MxHidDevice[02770A38] Jump to Ramkernel successfully!**********
ModuleID[2] LevelID[10]: CmdOperation[0], current state command has been finished and the last command is successful, so SetEvent(hDevCanDeleteEvent)
ModuleID[2] LevelID[10]: DeviceManager:evChangeWnd::OnDeviceChange() - DEVICE_REMOVAL_EVT(\\?\USB#VID_15A2&ID_0061#7&25c389c1&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_REMOVAL_EVT(\\?\USB#VID_15A2&ID_0061#7&25c389c1&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
ModuleID[2] LevelID[10]: DeviceClass::FindDeviceByUsbPath--DeviceListType_Current, _devices.size: 1
ModuleID[2] LevelID[10]: DeviceClass::FindDeviceByUsbPath--DeviceListType_Current, devInstPathToFind: USB\VID_15A2&ID_0061\7&25C389C1&0&1, _deviceInstanceID: USB\VID_15A2&ID_0061\7&25C389C1&0&1
ModuleID[2] LevelID[10]: DeviceClass::FindDeviceByUsbPath--DeviceListType_Current, Find the device
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_REMOVAL_EVT,[MxHidDeviceClass] vid_15a2&pid_0061, Hub:2-Port:1
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_REMOVAL_EVT, Notify
ModuleID[2] LevelID[10]: CmdOpreation[0]--OnDeviceChangeNotify, Volume/Device Remove
ModuleID[2] LevelID[1]: CmdOpreation[0]--set m_hDeviceRemoveEvent.
ModuleID[2] LevelID[10]: CmdOpreation[0]--WaitforEvents device remove1
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent()-DEVICE_REMOVAL_EVT, hDevCanDeleteEvent has been set
ModuleID[2] LevelID[10]: delete MxHidDevice[02770A38]
ModuleID[2] LevelID[10]: DeviceManager:evChangeWnd::OnDeviceChange() - DEVICE_ARRIVAL_EVT(\\?\USB#VID_066F&ID_37FF#7&25c389c1&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_ARRIVAL_EVT(\\?\USB#VID_066F&PID_37FF#7&25c389c1&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_ARRIVAL_EVT,[Msc,DiskDeviceClass] vid_066f&pid_37ff, not handled
ModuleID[2] LevelID[10]: DeviceManager:evChangeWnd::OnDeviceChange() - VOLUME_ARRIVAL_EVT(E)
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - VOLUME_ARRIVAL_EVT(E)
ModuleID[2] LevelID[10]: VolumeDeviceClass::AddUsbDevice()  E
ModuleID[2] LevelID[10]: DeviceTypeDisk--_devices size: 1
ModuleID[2] LevelID[10]: Volume--StorageDisk, Disk->_driveNumber:1, Volume->_diskNumber:1
ModuleID[2] LevelID[10]: DeviceTypeDisk--find Disk device: 02772EB0
ModuleID[2] LevelID[10]: Device::hubIndex::getmsc, return the port index is: 1
ModuleID[2] LevelID[10]: VolumeDeviceClass::AddUsbDevice() successful E add to current list, retrycount: 0
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - VOLUME_ARRIVAL_EVT-Disk(E), Hub:2-Port:1
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - VOLUME_ARRIVAL_EVT, Notify
ModuleID[2] LevelID[10]: CmdOperation[0] device chagned and reset to state 1
ModuleID[2] LevelID[10]: ExecuteCommand--Push[WndIndex:0], Body is $ dd if=/dev/zero of=/dev/mmcblk0 bs=512 seek=1536 count=16
ModuleID[2] LevelID[10]: ExecuteCommand--Push[WndIndex:0], Body is $ echo 0 > /sys/block/mmcblk0boot0/force_ro
ModuleID[2] LevelID[10]: ExecuteCommand--Push[WndIndex:0], Body is send
ModuleID[2] LevelID[10]: ExecuteCommand--Push[WndIndex:0], Body is $ dd if=$FILE of=/dev/mmcblk0boot0 bs=512 seek=2 skip=2
ModuleID[2] LevelID[10]: ExecuteCommand--Push[WndIndex:0], Body is $ echo 1 > /sys/block/mmcblk0boot0/force_ro
ModuleID[2] LevelID[10]: ExecuteCommand--Push[WndIndex:0], Body is frf
ModuleID[2] LevelID[10]: ExecuteCommand--Push[WndIndex:0], Body is $ tar xf $FILE
ModuleID[2] LevelID[1]: PortMgrDlg(0)--MSCDevice--Command Push(no file) excute failed
ModuleID[2] LevelID[10]: CmdOperation[0], current command executed failed, so SetEvent(hDevCanDeleteEvent)
ModuleID[2] LevelID[10]: DeviceManager:evChangeWnd::OnDeviceChange() - DEVICE_REMOVAL_EVT(\\?\USB#VID_066F&PID_37FF#7&25c389c1&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_REMOVAL_EVT(\\?\USB#VID_066F&PID_37FF#7&25c389c1&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_REMOVAL_EVT,[Msc,DiskDeviceClass] vid_066f&pid_37ff, not handled
ModuleID[2] LevelID[10]: DeviceManager::DevChangeWnd::OnDeviceChange() - VOLUME_REMOVAL_EVT(E)
ModuleID[2] LevelID[10]: DeviceManager::DevChangeWnd::OnDeviceChange() - end
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - VOLUME_REMOVAL_EVT(E)
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - VOLUME_REMOVAL_EVT-Disk(E), Hub:2-Port:1
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - VOLUME_REMOVAL_EVT, Notify
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent()-VOLUME_REMOVAL_EVT, wait hDevCanDeleteEvent
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent()-VOLUME_REMOVAL_EVT, hDevCanDeleteEvent has been set
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent()-VOLUME_REMOVAL_EVT, delete Disk:02772EB0, Volume:02773250
ModuleID[2] LevelID[10]: CCmdOpreation[0] thread is Closed
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - EVENT_KILL
ModuleID[2] LevelID[10]: CMyExceptionHandler::OnMsgExceptionEvent() - KillExceptionHandlerThread
ModuleID[2] LevelID[10]: Exception Handler thread is closed
ModuleID[2] LevelID[1]: delete MxHidDeviceClass
ModuleID[2] LevelID[10]: Device Manager thread is closed
我知道答案 目前已有5人回答
发表于 2016-8-3 11:55:04 | 显示全部楼层
楼主你好,请问你这里使用的是哪块板子?BSP是什么版本?
发表于 2016-8-3 11:55:26 | 显示全部楼层
你重新烧写的话,文件和烧写配置是否OK?
  • 签到天数: 11 天
    优秀版主
    发表于 2016-8-3 21:55:27 | 显示全部楼层
    这是一个完整的LOG吗?
     楼主| 发表于 2016-8-4 08:25:10 | 显示全部楼层
    0.0昨天换了台电脑,烧写竟然成功了,copy的是一份烧写工具,难道是我电脑系统的问题?
     楼主| 发表于 2016-8-4 08:26:07 | 显示全部楼层
    技术范儿 发表于 2016-8-3 21:55
    这是一个完整的LOG吗?
    是的,我把log文件里的都贴过来了
    GMT+8, 2025-10-28 20:16 , Processed in 0.117039 second(s), 26 queries , MemCache On.
