查看: 9708|回复: 10
[求助] KL27芯片下载失败,提示Verify Failed!
发表于 2016-8-27 21:33:05 | 显示全部楼层 |阅读模式
你好,我使用的芯片是MKL27Z256VLH4,自己画了一块板子,使用J-Link下载不成功,请问是哪里出了问题?
Load "D:\\Keil_Project_KL27\\1-test\\Objects\\xkwy.axf"
Set JLink Project File to "D:\Keil_Project_KL27\1-test\JLinkSettings.ini"
* JLink Info: Device "MKL27Z256XXX4" selected.
JLink info:
DLL: V5.10d, compiled Dec  9 2015 12:49:14
Firmware: J-Link ARM V8 compiled Jan 31 2018 18:34:52
Hardware: V8.00
S/N : 20080643
Feature(s) : RDI,FlashDL,FlashBP,JFlash,GDBFull
* JLink Info: Found SWD-DP with ID 0x0BC11477
***JLink Error: Kinetis (connect): Timeout while halting CPU. CPU does not stop.
* JLink Info: Found Cortex-M0 r0p1, Little endian.
* JLink Info: FPUnit: 2 code (BP) slots and 0 literal slots
* JLink Info: CoreSight components:
* JLink Info: ROMTbl 0 @ F0002000
* JLink Info: ROMTbl 0 [0]: FFFFE000, CID: B105900D, PID: 001BB932 MTB-M0+
* JLink Info: ROMTbl 0 [1]: FFFFF000, CID: B105900D, PID: 0008E000 MTBDWT
* JLink Info: ROMTbl 0 [2]: F00FD000, CID: B105100D, PID: 000BB4C0 ROM Table
* JLink Info: ROMTbl 1 @ E00FF000
* JLink Info: ROMTbl 1 [0]: FFF0F000, CID: B105E00D, PID: 000BB008 SCS
* JLink Info: ROMTbl 1 [1]: FFF02000, CID: B105E00D, PID: 000BB00A DWT
* JLink Info: ROMTbl 1 [2]: FFF03000, CID: B105E00D, PID: 000BB00B FPB
ROMTableAddr = 0xF0002000
Target info:
Device: MKL27Z256xxx4
VTarget = 3.319V
State of Pins:
TCK: 0, TDI: 0, TDO: 0, TMS: 0, TRES: 1, TRST: 0
Hardware-Breakpoints: 2
Software-Breakpoints: 8192
Watchpoints:          2
JTAG speed: 4000 kHz
Erase Done.
Programming Done.
Contents mismatch at: 0000001CH  (Flash=00H  Required=61H) !
Contents mismatch at: 0000001DH  (Flash=00H  Required=1CH) !
Contents mismatch at: 0000001FH  (Flash=00H  Required=E0H) !
Verify Failed!
Error: Flash Download failed  -  "Cortex-M0+"
Flash Load finished at 21:24:32
我知道答案 目前已有10人回答
    发表于 2016-8-27 23:43:21 | 显示全部楼层
    我来帮你顶一下
    今天好开心
    发表于 2016-8-29 08:29:05 | 显示全部楼层
    楼主你好!
    使用JLINK Commander窗口看看能不能找到内核。
    另外查下你的板子:
    NMI_b 引脚上拉10K电阻。
    Reset引脚上拉10K,对地0.1uf电容。
    SWD_DIO上拉10K。
    SWD_CLK不需要外加器件。
    再有就是检查下你的SWD或者JTAG的接口连接线序是否有问题。
  • 签到天数: 11 天
    优秀版主
    发表于 2016-8-29 09:26:46 | 显示全部楼层
    没有找到内核,检查一下电源和复位电路,这个片子没有外部晶振也可以下载的
  • 签到天数: 273 天
    发表于 2016-8-29 15:52:40 | 显示全部楼层
    帮你顶一下,希望大神来回答你的问题
     楼主| 发表于 2016-8-30 08:53:05 | 显示全部楼层
    你好,我按照网上的办法把Verify选项去掉就可以了,程序也能正常运行,不知道为什么
    发表于 2016-8-30 10:27:41 | 显示全部楼层
    楼主可以在选择全片擦除的情况下,加上校验试试。
    其实不加校验也是可以的,直接烧录,代码是能够运行的。
     楼主| 发表于 2016-11-18 14:04:13 | 显示全部楼层
    其实不加校验也是可以的,直接烧录,代码是能够运行的 ...
    谢谢。
    暂时只能不校验了
    发表于 2017-7-11 22:14:18 | 显示全部楼层
    你好 这个问题解决了吗
    发表于 2017-7-12 09:57:22 | 显示全部楼层
    你好这一个问题解决了吗
    GMT+8, 2025-10-26 19:25 , Processed in 0.103525 second(s), 31 queries , MemCache On.
