查看: 5811|回复: 5
[已解决] imx6dl uimage文件过大怎么解决
    发表于 2016-9-20 15:52:48 | 显示全部楼层 |阅读模式
    我最近用imx6dl安卓,修改内核后烧写 uImage 文件,现在是5M,以前是3M,错误如下
    In:    serial
    Out:   serial
    Err:   serial
    Net:   got MAC address from IIM: 00:00:00:00:00:00
    FEC0 [PRIME]
    ## Booting kernel from Legacy Image at 10800000 ...
       Image Name:   Linux-3.0.35
       Image Type:   ARM Linux Kernel Image (uncompressed)
       Data Size:    5124764 Bytes =  4.9 MB
       Load Address: 10008000
       Entry Point:  10008000
       Verifying Checksum ... Bad Data CRC
    ERROR: can't get kernel image!
    MX6SDL SABRESD-MFG U-Boot >
    我知道答案 目前已有5人回答
    今天天气不错!签到!
  • 签到天数: 4 天
    发表于 2016-9-20 16:19:35 | 显示全部楼层
    您好,这个问题应该比较简单,从你输出的信息看得出来,你的内核头已经被正确识别,但是加载内核的时候,可能受到某个变量的限制,没有将5M内核全部拷贝进来,拷了个烂尾残缺内核,所以做CRC校验通不过
    发表于 2016-9-22 15:08:44 | 显示全部楼层
    楼主你好,请问你这里是写到SD卡上还是emmc上呢?是不是你的u-boot参数没有设置正确,导致找不到kernel image,建议你查看一下内核启动参数设置。
    还有楼主这里使用的是哪个版本的BSP,板子是自己设计的吗?
     楼主| 发表于 2016-9-22 15:25:57 | 显示全部楼层
    小智MM 发表于 2016-9-22 15:08
    楼主你好,请问你这里是写到SD卡上还是emmc上呢?是不是你的u-boot参数没有设置正确,导致找不到kernel ima ...
    烧写到sd卡没事,烧写到emmc上出错,以前是emmc4.5,现在换成了emmc5.0,错误如下
    mmc0: unrecognised EXT_CSD revision 7
    mmc0: error -22 whilst initialising MMC card
    mmc2: new high speed SDHC card at address aaaa
    mmcblk0: mmc2:aaaa SS08G 7.40 GiB (ro)
    mmcblk0: p1 p2 p3 < p5 p6 p7 p8 > p4
    mmcblk0: p4 size 13344768 extends beyond EOD, truncated
    uuc 0.4 [built May 23 2013 23:59:39]
    UTP: Waiting for device to appear
    UTP: file/device node /dev/utp already exists
    cpu_id is 0
    UTP: received command '$ dd if=/dev/zero of=/dev/mmcblk0 bs=512 seek=1536 count=
    16'
    UTP: executing "dd if=/dev/zero of=/dev/mmcblk0 bs=512 seek=1536 count=16"
    dd: can't open '/dev/mmcblk0': Read-only file system
    UTP: sending Non-success to kernel for command $ dd if=/dev/zero of=/dev/mmcblk0
    bs=512 seek=1536 count=16.
    utp_poll: exit with status 256
    网上说改掉mmc.c的6换成7.但是出现以下错误
    mmc0: new high speed DDR MMC card at address 0001
    VFP support v0.3:
    mmcblk0: mmc0:0001 8WPD3R 7.28 GiB
    implementor 41 architecture 3 part 30 variant 9 rev 4
    Bus freq driver module loaded
    Bus freq driver Enabled
    mxc_dvfs_core_probe
    DVFS driver module loaded
    mmcblk0boot0: mmc0:0001 8WPD3R partition 1 4.00 MiB
    g_file_storage gadget: high speed config #1
    mmcblk0boot1: mmc0:0001 8WPD3R partition 2 4.00 MiB
    regulator_init_complete: SPKVDD: incomplete constraints, leaving on
    snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 00:00:00 UTC (0)
    mmcblk0: p4 size 13090816 extends beyond EOD, truncated
    Freeing init memory: 800K
    Starting UTP
    mmcblk0boot1: unknown partition table
    ln: /etc/mtab: File exists
    disable turn off display
    mmcblk0boot0: unknown partition table
    Starting the hotplug events dispatcher udevd
    Synthesizing initial hotplug evenudevd (2023): /proc/2023/oom_adj is deprecated,
    please use /proc/2023/oom_score_adj instead.
    ts
    mmc1: new high speed SDHC card at address aaaa
    mmcblk1: mmc1:aaaa SS08G 7.40 GiB
    mmcblk1: p1 p2 p3 < p5 p6 p7 p8 > p4
    mmcblk1: p4 size 13344768 extends beyond EOD, truncated
    cpu_id is 0
    16'
    16+0 records in
    16+0 records out
    8192 bytes (8.0KB) copied, 0.002465 seconds, 3.2MB/s
    UTP: sending Success to kernel for command $ dd if=/dev/zero of=/dev/mmcblk0 bs=
    utp_poll: pass returned.
    UTP: received command '$ echo 1 > /sys/devices/platform/sdhci-esdmmc0: DO NOT sw
    itch the partitions that used to be
    accessed in OS layer HERE. please following the
    guidance of Documentation/mmc/mmc-dev-parts.txt.
    hc-imx.3/mmc_host/mmc0/mmc0:0001/boot_config'
    UTP: executing "echo 1 > /sys/devices/platform/sdhci-esdhc-imx.3/mmc_host/mmc0/m
    mc0:0001/boot_config"
    sh: write error: Invalid argument
    UTP: sending Non-success to kernel for command $ echo 1 > /sys/devices/platform/
    sdhci-esdhc-imx.3/mmc_host/mmc0/mmc0:0001/boot_config.
    小智MM求帮助!!!烧写工具为:Mfgtools-Rel-13.01.00_ER_MX6DL_UPDATER
    BSP为:L3.0.35的内核,安卓系统
    今天天气不错!签到!
    发表于 2016-9-22 16:38:27 | 显示全部楼层
    mmc0: unrecognised EXT ...
    好的,我看你另外一个贴中也是关于这个问题的,我们在那个帖中讨论哈~~
     楼主| 发表于 2016-9-23 10:57:44 | 显示全部楼层
    哇哈哈,已解决
    今天天气不错!签到!
    GMT+8, 2025-10-28 09:34 , Processed in 0.099376 second(s), 26 queries , MemCache On.
