在线时间19 小时
UID276433
注册时间2011-4-6
NXP金币0
- 215
- 1970-1-1
小弟在xep100中使用Xgate 处理PIT0中断 和SCI0中断可行,但将PIT0中断放到S12中处理就死机,什么原因啊?
static void SetupXGATE(void) {
/* initialize the XGATE vector block and
set the XGVBR register to its start address */
XGVBR= (unsigned int)(void*__far)(XGATE_VectorTable - XGATE_VECTOR_OFFSET);
/* switch software trigger 0 interrupt to XGATE */
// ROUTE_INTERRUPT(SOFTWARETRIGGER0_VEC, 0x81); /* RQST=1 and PRIO=1 */
ROUTE_INTERRUPT(SCI0_VEC, 0x81);
// ROUTE_INTERRUPT(PIT0_VEC, 0x81);
// ROUTE_INTERRUPT(RTI_VEC, 0x81);
/* when changing your derivative to non-core3 one please remove next five lines */
XGISPSEL= 1;
XGISP31= (unsigned int)(void*__far)(XGATE_STACK_L + 1);
XGISPSEL= 2;
XGISP74= (unsigned int)(void*__far)(XGATE_STACK_H + 1);
XGISPSEL= 0;
/* enable XGATE mode and interrupts */
XGMCTL= 0xFBC1; /* XGE | XGFRZ | XGIE */
/* force execution of software trigger 0 handler */
XGSWT= 0x0101;
void PIT_Init(void)
PITCFLMT &= 0x7F; //Disable PIT first
PITMUX |= 0x01; //Ch0 use macro timer 1
while (PITTF) PITTF=0x0F; //clear all exist overflow flag
PITMTLD1 = 160-1; //Macro timer1 load = 200, output->BusClk/200 to 16bit-timer
PITLD0 = 200-1; //Channel0: BusClk/200/10000 1Hz @ 2M
//time-out period = (PITMTLD + 1) * (PITLD + 1) / fBUS
// = 160*200/32M =1ms
PITINTE |=0x01; //enable the PIT channel 0 interrupt
PITCE |=0x01; //enable the PIT channel 0
PITCFLMT|=0x80; //enable PIT
#pragma CODE_SEG __NEAR_SEG NON_BANKED //接收中断
interrupt void PTI_ISR(void){//1MS
if(timer_5ms > 4){ //实时中断
flag_5ms=1;
timer_5ms=0;
}else
timer_5ms++;
if(timer_10ms>9){ //实时中断
flag_10ms=1;
timer_10ms=0;
}else
timer_10ms++;
if(timer_20ms>19){
flag_20ms=1;
timer_20ms=0;
}else
timer_20ms++;
if(timer_50ms>49){
flag_50ms=1;
timer_50ms=0;
}else
timer_50ms++;
if(timer_100ms>99){
flag_100ms=1;
timer_100ms=0;
}else
timer_100ms++;
if(timer_250ms>249){
flag_250ms=1;
timer_250ms=0;
}else
timer_250ms++;
if(timer_500ms>499){
flag_500ms=1;
timer_500ms=0;
}else
timer_500ms++;
PITTF |= 0x01;
const XGATE_TableEntry XGATE_VectorTable[] = {
// Channel # = Vector address / 2
/* channel 0..8 are not used, first used must match macro XGATE_VECTOR_OFFSET in xgate.h */
{ErrorHandler, 0x09}, // Channel 09 - Reserved
{ErrorHandler, 0x0A}, // Channel 0A - Reserved
{ErrorHandler, 0x0B}, // Channel 0B - Reserved
{ErrorHandler, 0x0C}, // Channel 0C - Reserved
{ErrorHandler, 0x0D}, // Channel 0D - Reserved
{ErrorHandler, 0x0E}, // Channel 0E - Reserved
{ErrorHandler, 0x0F}, // Channel 0F - Reserved
{ErrorHandler, 0x10}, // Channel 10 - Reserved
{ErrorHandler, 0x11}, // Channel 11 - Reserved
{ErrorHandler, 0x12}, // Channel 12 - Reserved
{ErrorHandler, 0x13}, // Channel 13 - Reserved
{ErrorHandler, 0x14}, // Channel 14 - Reserved
{ErrorHandler, 0x15}, // Channel 15 - Reserved
{ErrorHandler, 0x16}, // Channel 16 - Reserved
{ErrorHandler, 0x17}, // Channel 17 - Reserved
{ErrorHandler, 0x18}, // Channel 18 - Reserved
{ErrorHandler, 0x19}, // Channel 19 - Reserved
{ErrorHandler, 0x1A}, // Channel 1A - Reserved
{ErrorHandler, 0x1B}, // Channel 1B - Reserved
{ErrorHandler, 0x1C}, // Channel 1C - Reserved
{ErrorHandler, 0x1D}, // Channel 1D - Reserved
{ErrorHandler, 0x1E}, // Channel 1E - Reserved
{ErrorHandler, 0x1F}, // Channel 1F - Reserved
{ErrorHandler, 0x20}, // Channel 20 - Reserved
{ErrorHandler, 0x21}, // Channel 21 - Reserved
{ErrorHandler, 0x22}, // Channel 22 - Reserved
{ErrorHandler, 0x23}, // Channel 23 - Reserved
{ErrorHandler, 0x24}, // Channel 24 - Reserved
{ErrorHandler, 0x25}, // Channel 25 - Reserved
{ErrorHandler, 0x26}, // Channel 26 - Reserved
{ErrorHandler, 0x27}, // Channel 27 - Reserved
{ErrorHandler, 0x28}, // Channel 28 - Reserved
{ErrorHandler, 0x29}, // Channel 29 - Reserved
{ErrorHandler, 0x2A}, // Channel 2A - Reserved
{ErrorHandler, 0x2B}, // Channel 2B - Reserved
{ErrorHandler, 0x2C}, // Channel 2C - Reserved
{ErrorHandler, 0x2D}, // Channel 2D - Reserved
{ErrorHandler, 0x2E}, // Channel 2E - Reserved
{ErrorHandler, 0x2F}, // Channel 2F - Reserved
{ErrorHandler, 0x30}, // Channel 30 - XSRAM20K Access Violation
{ErrorHandler, 0x31}, // Channel 31 - XGATE Software Error Interrupt
{ErrorHandler, 0x32}, // Channel 32 - XGATE Software Trigger 7
{ErrorHandler, 0x33}, // Channel 33 - XGATE Software Trigger 6
{ErrorHandler, 0x34}, // Channel 34 - XGATE Software Trigger 5
{ErrorHandler, 0x35}, // Channel 35 - XGATE Software Trigger 4
{ErrorHandler, 0x36}, // Channel 36 - XGATE Software Trigger 3
{ErrorHandler, 0x37}, // Channel 37 - XGATE Software Trigger 2
{ErrorHandler, 0x38}, // Channel 38 - XGATE Software Trigger 1
{ErrorHandler, 0x39}, // Channel 39 - XGATE Software Trigger 0
// {(XGATE_Function)SoftwareTrigger0_Handler, (int)&MyData}, // Channel 39 - XGATE Software Trigger 0
{ErrorHandler, 0x3A}, // Channel 3A - Periodic Interrupt Timer
{ErrorHandler, 0x3B}, // Channel 3B - Periodic Interrupt Timer
{ErrorHandler, 0x3C}, // Channel 3C - Periodic Interrupt Timer
{ErrorHandler, 0x3D}, // Channel 3D - Periodic Interrupt Timer
// {(XGATE_Function) PIT_ISR, 0x3D}, // Channel 3D - Periodic Interrupt Timer
{ErrorHandler, 0x3E}, // Channel 3E - Reserved
{ErrorHandler, 0x3F}, // Channel 3F - Autonomous Periodical interrupt API
{ErrorHandler, 0x40}, // Channel 40 - Low Voltage interrupt LVI
{ErrorHandler, 0x41}, // Channel 41 - IIC1 Bus
{ErrorHandler, 0x42}, // Channel 42 - SCI5
{ErrorHandler, 0x43}, // Channel 43 - SCI4
{ErrorHandler, 0x44}, // Channel 44 - SCI3
{ErrorHandler, 0x45}, // Channel 45 - SCI2
{ErrorHandler, 0x46}, // Channel 46 - PWM Emergency Shutdown
{ErrorHandler, 0x47}, // Channel 47 - Port P Interrupt
{ErrorHandler, 0x48}, // Channel 48 - CAN4 transmit
{ErrorHandler, 0x49}, // Channel 49 - CAN4 receive
{ErrorHandler, 0x4A}, // Channel 4A - CAN4 errors
{ErrorHandler, 0x4B}, // Channel 4B - CAN4 wake-up
{ErrorHandler, 0x4C}, // Channel 4C - CAN3 transmit
{ErrorHandler, 0x4D}, // Channel 4D - CAN3 receive
{ErrorHandler, 0x4E}, // Channel 4E - CAN3 errors
{ErrorHandler, 0x4F}, // Channel 4F - CAN3 wake-up
{ErrorHandler, 0x50}, // Channel 50 - CAN2 transmit
{ErrorHandler, 0x51}, // Channel 51 - CAN2 receive
{ErrorHandler, 0x52}, // Channel 52 - CAN2 errors
{ErrorHandler, 0x53}, // Channel 53 - CAN2 wake-up
{ErrorHandler, 0x54}, // Channel 54 - CAN1 transmit
{ErrorHandler, 0x55}, // Channel 55 - CAN1 receive
{ErrorHandler, 0x56}, // Channel 56 - CAN1 errors
{ErrorHandler, 0x57}, // Channel 57 - CAN1 wake-up
{ErrorHandler, 0x58}, // Channel 58 - CAN0 transmit
{ErrorHandler, 0x59}, // Channel 59 - CAN0 receive
{ErrorHandler, 0x5A}, // Channel 5A - CAN0 errors
{ErrorHandler, 0x5B}, // Channel 5B - CAN0 wake-up
{ErrorHandler, 0x5C}, // Channel 5C - FLASH
{ErrorHandler, 0x5D}, // Channel 5D - EEPROM
{ErrorHandler, 0x5E}, // Channel 5E - SPI2
{ErrorHandler, 0x5F}, // Channel 5F - SPI1
{ErrorHandler, 0x60}, // Channel 60 - IIC0 Bus
{ErrorHandler, 0x61}, // Channel 61 - Reserved
{ErrorHandler, 0x62}, // Channel 62 - CRG Self Clock Mode
{ErrorHandler, 0x63}, // Channel 63 - CRG PLL lock
{ErrorHandler, 0x64}, // Channel 64 - Pulse Accumulator B Overflow
{ErrorHandler, 0x65}, // Channel 65 - Modulus Down Counter underflow
{ErrorHandler, 0x66}, // Channel 66 - Port H
{ErrorHandler, 0x67}, // Channel 67 - Port J
{ErrorHandler, 0x68}, // Channel 68 - ATD1
{ErrorHandler, 0x69}, // Channel 69 - ATD0
{ErrorHandler, 0x6A}, // Channel 6A - SCI1
{(XGATE_Function)SCI0RX, 0x6B }, // Channel 6B - SCI0 (int) &SCI0Rec
{ErrorHandler, 0x6C}, // Channel 6C - SPI0
{ErrorHandler, 0x6D}, // Channel 6D - Pulse accumulator input edge
{ErrorHandler, 0x6E}, // Channel 6E - Pulse accumulator A overflow
{ErrorHandler, 0x6F}, // Channel 6F - Enhanced Capture Timer overflow
{ErrorHandler, 0x70}, // Channel 70 - Enhanced Capture Timer channel 7
{ErrorHandler, 0x71}, // Channel 71 - Enhanced Capture Timer channel 6
{ErrorHandler, 0x72}, // Channel 72 - Enhanced Capture Timer channel 5
{ErrorHandler, 0x73}, // Channel 73 - Enhanced Capture Timer channel 4
{ErrorHandler, 0x74}, // Channel 74 - Enhanced Capture Timer channel 3
{ErrorHandler, 0x75}, // Channel 75 - Enhanced Capture Timer channel 2
{ErrorHandler, 0x76}, // Channel 76 - Enhanced Capture Timer channel 1
{ErrorHandler, 0x77}, // Channel 77 - Enhanced Capture Timer channel 0
{ErrorHandler, 0x78},
// {(XGATE_Function)RTI_ISR, 0x78}, // Channel 78 - Real Time Interrupt(XGATE_Function)RTI_ISR
{ErrorHandler, 0x79}, // Channel 79 - IRQ
