查看: 8059|回复: 3
[求助] imx6q bcm43341wifi移植问题
发表于 2016-9-27 14:08:45 | 显示全部楼层 |阅读模式
FAE:
     我在imx6q 移植ap6441 (bcm43341)wifi驱动移植,我现是可以ping通手机热点,但是通过android界面打开wifi开关,也可以扫描
     到很多wifi,但是连接的点击连接,输入密码后,界面上显示已保存,正在连接,然后是通过wpa/wpa2进行保护,
    1、 内核打印的log如下:(上面是连接公司wifi时候的打印)
     [  538.406137] Connectting with fc:d7:33:c3:fd:de channel (11) ssid "RUILI-TP-LINK", len (13)
     [  538.823298] connect failed event=0 e->status 1 e->reason 0
     [  538.829334] CFG80211-ERROR) wl_bss_connect_done : Report connect result - connection failed
    2、通过界面连接手机wifi热点打印log如下:(两个log也不一样)
      【441.140981] Connectting with fc:d7:33:c3:fd:de channel (11) ssid "RUILI-TP-LINK", len (13)
       [  441.261807] wl_iw_event: Link UP with BSSID=FC7:00:00:FDE
       [  441.267837] wl_bss_connect_done succeeded with fc:d7:33:c3:fd:de
       [  441.279680] wl_bss_connect_done succeeded with fc:d7:33:c3:fd:de
       [  441.416397] dhd_pno_get_for_batch : wifi location service is not supported
       [  441.423381] ANDROID-ERROR) failed to getting batching results
       [  441.431044] dhd_pno_stop_for_batch : wifi location service is not supported
       [  441.438242] NULL POINTER (_dhd_pno_clear_all_batch_results) : head->next is NULL
       [  441.445798] NULL POINTER (_dhd_pno_clear_all_batch_results) : head->next is NULL
       [  441.454450] ANDROID-ERROR) failed to stop batching scan
       [  442.479629] CFG80211-ERROR) wl_cfg80211_disconnect : Reason 3
       [  442.487956] cfg80211: Calling CRDA for country: CN
       [  442.531723] dhd_stop: Enter d20b6000
       [  442.537503] wl_iw_event: Link Down with BSSID=FC7:00:00:FDE
       [  442.544209] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_LINK
       [  442.561612] wl_android_wifi_off in 1
       [  442.565351] CFG80211-ERROR) wl_escan_handler : wl_android_wifi_off in 2: g_wifi_on=1
       [  442.565956] bcmsdh_oob_intr_unregister: Enter
       [  442.565965] remove wake up source irq 101
       [  442.565982] dhd_txglom_enable: enable 0
     那位朋友知道这是什么原因造成的?是硬件还是软件软件(如果是硬件,那我也ping通手机热点,这还不能证明硬件好着吗?)
     谢谢!
发表于 2016-9-29 13:33:41 | 显示全部楼层
楼主你好,你可以参考一下如下文档: Porting-BCM4330-BCM43362-WIFI-to-Android4.2.2.pdf (331.67 KB, 下载次数: 88)
    发表于 2016-10-13 09:54:44 | 显示全部楼层
    很多板子都有这种情况,不只是i.MX6吧
  • 签到天数: 11 天
    优秀版主
    发表于 2016-10-13 16:27:09 | 显示全部楼层
    驱动没弄好
    GMT+8, 2026-4-5 01:55 , Processed in 0.111712 second(s), 27 queries , Redis On.
