在线时间6 小时
UID2070854
注册时间2014-1-20
NXP金币0
- 105
- 1970-1-1
楼主 |
发表于 2016-10-17 15:22:25
显示全部楼层
多谢!用了Jlink V2.1的固件, 似乎是可以了,以前的Bootloader盘变成了JLINK盘。IAR里Simulator选Jlink, 可以下载了!再观察下,看调试功能如何。多谢了!
Download Log:
Mon Oct 17, 2016 15:16:27: IAR Embedded Workbench 7.70.2 (armproc.dll)
Mon Oct 17, 2016 15:16:27: Loaded macro file: C:\Program *** (x86)\IAR Systems\Embedded Workbench 7.5\arm\config\debugger\NXP\KV3x.dmac
Mon Oct 17, 2016 15:16:28: JLINK command: ProjectFile = E:\Work\Datasheet\FSL\Kinetis\Kinetis Motor Control\MCRSP_PMSM_V1.1.1\build_demos\frdm-kv31f\iar\settings\pmsm_demo_debug.jlink, return = 0
Mon Oct 17, 2016 15:16:28: Device "MKV31F512XXX12" selected.
Mon Oct 17, 2016 15:16:28: DLL version: V6.0h, compiled Sep 1 2016 19:00:33
Mon Oct 17, 2016 15:16:28: Firmware: J-Link OpenSDA 2 compiled Oct 13 2015 12:10:56
Mon Oct 17, 2016 15:16:28: JTAG speed is initially set to: 1000 kHz
Mon Oct 17, 2016 15:16:28: Found SWD-DP with ID 0x2BA01477
Mon Oct 17, 2016 15:16:28: AP-IDR: 0x24770011, Type: AHB-AP
Mon Oct 17, 2016 15:16:28: Found Cortex-*** r0p1, Little endian.
Mon Oct 17, 2016 15:16:28: FPUnit: 6 code (BP) slots and 2 literal slots
Mon Oct 17, 2016 15:16:28: CoreSight components:
Mon Oct 17, 2016 15:16:28: ROMTbl 0 @ E00FF000
Mon Oct 17, 2016 15:16:28: ROMTbl 0 [0]: FFF0F000, CID: B105E00D, PID: 000BB00C SCS
Mon Oct 17, 2016 15:16:28: ROMTbl 0 [1]: FFF02000, CID: B105E00D, PID: 003BB002 DWT
Mon Oct 17, 2016 15:16:28: ROMTbl 0 [2]: FFF03000, CID: B105E00D, PID: 002BB003 FPB
Mon Oct 17, 2016 15:16:28: ROMTbl 0 [3]: FFF01000, CID: B105E00D, PID: 003BB001 ITM
Mon Oct 17, 2016 15:16:28: ROMTbl 0 [4]: FFF41000, CID: B105900D, PID: 000BB9A1 TPIU
Mon Oct 17, 2016 15:16:28: Hardware reset with strategy 0 was performed
Mon Oct 17, 2016 15:16:28: Initial reset was performed
Mon Oct 17, 2016 15:16:28: Found 1 JTAG device, Total IRLen = 4:
Mon Oct 17, 2016 15:16:28: 3196 bytes downloaded and verified (18.15 Kbytes/sec)
Mon Oct 17, 2016 15:16:28: Loaded debugee: C:\Program *** (x86)\IAR Systems\Embedded Workbench 7.5\arm\config\flashloader\NXP\FlashKxxFxxx96K.out
Mon Oct 17, 2016 15:16:28: Target reset
Mon Oct 17, 2016 15:16:29: Downloaded E:\Work\Datasheet\FSL\Kinetis\Kinetis Motor Control\MCRSP_PMSM_V1.1.1\build_demos\frdm-kv31f\iar\debug\pmsm_demo.out to flash memory.
Mon Oct 17, 2016 15:16:29: Hardware reset with strategy 0 was performed
Mon Oct 17, 2016 15:16:30: 19814 bytes downloaded into FLASH and verified (11.49 Kbytes/sec)
Mon Oct 17, 2016 15:16:30: Loaded debugee: E:\Work\Datasheet\FSL\Kinetis\Kinetis Motor Control\MCRSP_PMSM_V1.1.1\build_demos\frdm-kv31f\iar\debug\pmsm_demo.out
Mon Oct 17, 2016 15:16:30: Hardware reset with strategy 0 was performed
Mon Oct 17, 2016 15:16:30: Target reset
