查看: 10615|回复: 14
[求助] IMX6使用MFG无法烧写系统问题求助
发表于 2016-10-24 20:16:16 | 显示全部楼层 |阅读模式
各位好,小弟新手,求教各位大大一些问题:
最近在使用自己制作的板子,想烧写Android系统到eMMC里面,但是始终无法下载成功,MFG卡在Loading U-Boot(就是在jumping to OS image之后那一步),串口无打印消息。下面小弟将cfg.ini文件配置及MfgTool.log内容粘贴如下:
cfg.ini文件:
[profiles]
chip = MX6Q Linux Update
[platform]
board = SabreSD
[LIST]
name = Android-SabreSD-eMMC
MfgTool.log内容如下:
DLL version: 2.2.2
Monday, October 24, 2016 11:06:23   Start new logging
ModuleID[2] LevelID[10]: CMyExceptionHandler thread is running
ModuleID[2] LevelID[1]: new MxHidDeviceClass
ModuleID[2] LevelID[10]: new MxHidDevice[00921348]
ModuleID[2] LevelID[10]: Device Manager thread is running
ModuleID[2] LevelID[10]: CmdOperation[0] device chagned and reset to state 0
ModuleID[2] LevelID[10]: ExecuteCommand--Boot[WndIndex:0], File is F:\IMX6ModuleID[2] LevelID[10]: ExecuteCommand--Load[WndIndex:0], File is F:\IMX6ModuleID[2] LevelID[10]: PortMgrDlg(0)--Command Load excute successfully, retry count: 0
ModuleID[2] LevelID[10]: ExecuteCommand--Jump[WndIndex:0]
ModuleID[2] LevelID[10]: *********MxHidDevice[00921348] Jump to Ramkernel successfully!**********
ModuleID[2] LevelID[10]: CmdOperation[0], current state command has been finished and the last command is successful, so SetEvent(hDevCanDeleteEvent)
ModuleID[2] LevelID[10]: DeviceManager:evChangeWnd::OnDeviceChange() - DEVICE_REMOVAL_EVT(\\?\USB#VID_15A2&ID_0054#6&3b313210&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
ModuleID[2] LevelID[10]: DeviceManager:evChangeWnd::OnDeviceChange() - end
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_REMOVAL_EVT(\\?\USB#VID_15A2&ID_0054#6&3b313210&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
ModuleID[2] LevelID[10]: DeviceClass::FindDeviceByUsbPath--DeviceListType_Current, _devices.size: 1
ModuleID[2] LevelID[10]: DeviceClass::FindDeviceByUsbPath--DeviceListType_Current, devInstPathToFind: USB\VID_15A2&ID_0054\6&3B313210&0&2, _deviceInstanceID: USB\VID_15A2&ID_0054\6&3B313210&0&2
ModuleID[2] LevelID[10]: DeviceClass::FindDeviceByUsbPath--DeviceListType_Current, Find the device
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_REMOVAL_EVT,[MxHidDeviceClass] vid_15a2&pid_0054, Hub:3-Port:2
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_REMOVAL_EVT, Notify
ModuleID[2] LevelID[10]: CmdOpreation[0]--OnDeviceChangeNotify, Volume Arrive/Remove or Device Arrive/Remove
ModuleID[2] LevelID[10]: CmdOpreation[0]--OnDeviceChangeNotify, m_p_usb_port is not NULL, so only refresh
ModuleID[2] LevelID[10]: CmdOpreation[0]--OnDeviceChangeNotify, Volume/Device Remove
ModuleID[2] LevelID[1]: CmdOpreation[0]--set m_hDeviceRemoveEvent.
ModuleID[2] LevelID[10]: CmdOpreation[0]--WaitforEvents device remove1
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent()-DEVICE_REMOVAL_EVT, hDevCanDeleteEvent has been set
ModuleID[2] LevelID[10]: delete MxHidDevice[00921348]
ModuleID[2] LevelID[10]: DeviceManager:evChangeWnd::OnDeviceChange() - DEVICE_ARRIVAL_EVT(\\?\USB#VID_15A2&ID_0054#6&3b313210&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_ARRIVAL_EVT(\\?\USB#VID_15A2&ID_0054#6&3b313210&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
ModuleID[2] LevelID[10]: DeviceClass::FindDeviceByUsbPath--DeviceListType_Current, _devices.size: 0
ModuleID[2] LevelID[1]: DeviceClass::FindDeviceByUsbPath() - DeviceListType_New--index: 0
ModuleID[2] LevelID[1]: DeviceClass::FindDeviceByUsbPath() - DeviceListType_New--devPath: \\?\hid#vid_09da&pid_c10a&col01#7&4aae317&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
ModuleID[2] LevelID[1]: DeviceClass::FindDeviceByUsbPath() - DeviceListType_New--index: 1
ModuleID[2] LevelID[1]: DeviceClass::FindDeviceByUsbPath() - DeviceListType_New--devPath: \\?\hid#vid_09da&pid_c10a&col02#7&4aae317&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}
ModuleID[2] LevelID[1]: DeviceClass::FindDeviceByUsbPath() - DeviceListType_New--index: 2
ModuleID[2] LevelID[1]: DeviceClass::FindDeviceByUsbPath() - DeviceListType_New--devPath: \\?\hid#vid_15a2&pid_0054#7&268b6789&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
ModuleID[2] LevelID[10]: new MxHidDevice[0092EE18]
ModuleID[2] LevelID[10]: DeviceClass::FindDeviceByUsbPath--DeviceListType_New, devInstPathToFind: USB\VID_15A2&ID_0054\6&3B313210&0&2, _deviceInstanceID: USB\VID_15A2&ID_0054\6&3B313210&0&2
ModuleID[2] LevelID[10]: DeviceClass::FindDeviceByUsbPath--DeviceListType_New, Find the device, Port: 2
ModuleID[2] LevelID[10]: DeviceClass::AddUsbDevice() successful USB#VID_15A2&ID_0054#6&3B313210&0&2#{A5DCBF10-6530-11D2-901F-00C04FB951ED} add to current list, retrycount: 0
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_ARRIVAL_EVT,[MxHidDeviceClass] vid_15a2&pid_0054, Hub:3-Port:2
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_ARRIVAL_EVT, Notify
ModuleID[2] LevelID[10]: CmdOpreation[0]--OnDeviceChangeNotify, Volume/Device Arrive
ModuleID[2] LevelID[1]: CmdOpreation[0]--set m_hDeviceArriveEvent.
ModuleID[2] LevelID[10]: CmdOpreation[0]--WaitforEvents device arrive1
ModuleID[2] LevelID[10]: ExecuteCommand--Boot[WndIndex:0], File is F:\IMX6ModuleID[2] LevelID[1]: MxHidDevice::Read() Error reading from device 0x48f.
ModuleID[2] LevelID[1]: Failed to read HAB type from ROM!!!
ModuleID[2] LevelID[1]: Failed to initialize memory!
ModuleID[2] LevelID[1]: PortMgrDlg(0)--MxHidDevice--Command Boot excute failed
ModuleID[2] LevelID[10]: CmdOperation[0], current command executed failed, so SetEvent(hDevCanDeleteEvent)
ModuleID[2] LevelID[10]: CCmdOpreation[0] thread is Closed
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - EVENT_KILL
ModuleID[2] LevelID[10]: CMyExceptionHandler::OnMsgExceptionEvent() - KillExceptionHandlerThread
ModuleID[2] LevelID[10]: Exception Handler thread is closed
ModuleID[2] LevelID[1]: delete MxHidDeviceClass
ModuleID[2] LevelID[10]: delete MxHidDevice[0092EE18]
ModuleID[2] LevelID[10]: Device Manager thread is closed
请高手指教啊。
我知道答案 目前已有14人回答
 楼主| 发表于 2016-10-24 20:17:12 | 显示全部楼层
上面有的地儿不造咋变成表情了。。。。给位大大直接忽视啊,重点的错误在后面
  • 签到天数: 11 天
    优秀版主
    发表于 2016-10-25 08:10:06 | 显示全部楼层
    Work-Tang 发表于 2016-10-24 20:17
    上面有的地儿不造咋变成表情了。。。。给位大大直接忽视啊,重点的错误在后面 ...
    帖LOG用代码的方式贴
  • 签到天数: 11 天
    优秀版主
    发表于 2016-10-25 08:10:07 | 显示全部楼层
    帖LOG用代码的方式贴
     楼主| 发表于 2016-10-25 10:27:10 | 显示全部楼层
    LOG里面显示出错的应该是最后几行,这是咋回事啊。。
  • 签到天数: 11 天
    优秀版主
    发表于 2016-10-25 10:40:37 | 显示全部楼层
    描述清楚,谁家的板子那个软件版本
  • 签到天数: 4 天
    发表于 2016-10-25 10:44:35 | 显示全部楼层
    devices 需要工作在status “1”,看样子是没有用对应android版本的MFGtool。
     楼主| 发表于 2016-10-25 15:09:27 | 显示全部楼层
    参考的是TQIMX6Q_COREC_V2板子,烧写的内核是Linux-3.0.35,烧写软件是Mfgtools-Rel-13.01.00_ER_MX6Q_UPDATER。应该不是软件问题,因为之前有一块一模一样的板子(也是自己做的),烧写成功了,这块应该是硬件原因,但是就是不知道硬件上哪个地方出错会导致这种问题。
  • 签到天数: 11 天
    优秀版主
    发表于 2016-10-25 15:24:10 | 显示全部楼层
    Work-Tang 发表于 2016-10-25 15:09
    参考的是TQIMX6Q_COREC_V2板子,烧写的内核是Linux-3.0.35,烧写软件是Mfgtools-Rel-13.01.00_ER_MX6Q_UPDA ...
    检查一下USB端口软件是否识别了,然后就是用DDR测试工具跑下DDR有没有问题,最后检查下eMMC
    发表于 2016-10-25 16:29:19 | 显示全部楼层
    楼主你好,请问你这里自己设计的板子使用的DDR是和我们的开发板一样么?还是换了DDR?还有你这里使用的是哪个版本的BSP呢?
    GMT+8, 2026-4-7 00:59 , Processed in 0.103858 second(s), 30 queries , Redis On.
