查看: 4509|回复: 2
[已解决] imx6dl怎么增加dm9000网卡驱动,linux系统3.14.28内核
    发表于 2016-10-26 16:42:01 | 显示全部楼层 |阅读模式
    我的片选地址是0800 0000 中断是gpio4_5,设备树设置如下
        ethernet@0800040 {
            compatible = "davicom,dm9000";
            reg = <0x08000040 0x2 0x08000044 0x2>;
            interrupt-parent = <&gpio4>;
            interrupts = <5 2>;
            local-mac-address = [00 00 de ad be ef];
            davicom,no-eeprom;
    内核增加dm9000后,烧写开机logo如下
    CAN device driver interface
    dm9000 8000040.ethernet: read wrong id 0x01010101
    eth0: dm9000a at c08fe040,c0912044 IRQ 261 MAC: 00:00:de:ad:be:ef (platform data
    2188000.ethernet supply phy not found, using dummy regulator
    pps pps0: new PPS source ptp0
    fec 2188000.ethernet (unregistered net_device): Invalid MAC address: 00:00:00:00
    :00:00
    fec 2188000.ethernet (unregistered net_device): Using random MAC address: fa:19:
    2e:16:3c:22
    libphy: fec_enet_mii_bus: probed
    fec 2188000.ethernet eth1: registered PHC device 0
    然后ping测试
    root@imx6dlsabresd:~# ifconfig eth0 192.168.88.186
    root@imx6dlsabresd:~# ping 192.168.88.1
    PING 192.168.88.1 (192.168.88.1): 56 data bytes
    然后一直卡死没有任何信息,网口绿灯闪烁黄灯常量,求大神指导指导!!!
    我知道答案 目前已有2人回答
    今天天气不错!签到!
    无聊
    2017-1-24 08:47
  • 签到天数: 49 天
    发表于 2016-10-26 17:18:41 | 显示全部楼层
    地址分配错误?
     楼主| 发表于 2016-10-27 17:52:06 | 显示全部楼层
    OK 经过了2天多的时间终于搞定了!!!
    &fec {     pinctrl-names = "default";     pinctrl-0 = <&pinctrl_enet_1>;     phy-mode = "rgmii";     status = "okay"; };
    http://lxr.free-electrons.com/
    查看设备树增加文档,很重要啊
    ls Documentation/devicetree/bindings/net/davicom-dm9000.txt
    Required properties:
    - compatible = "davicom,dm9000";
    - reg : physical addresses and sizes of registers, must contain 2 entries:
        first entry : address register,
        second entry : data register.
    - interrupt-parent : interrupt controller to which the device is connected
    - interrupts : interrupt specifier specific to interrupt controller
    Optional properties:
    - local-mac-address : A bytestring of 6 bytes specifying Ethernet MAC address
        to use (from firmware or bootloader)
    - davicom,no-eeprom : Configuration EEPROM is not available
    - davicom,ext-phy : Use external PHY
    Example:
        ethernet@18000000 {
            reg = <0x18000000 0x2 0x18000004 0x2>;
            interrupt-parent = <&gpn>;
            interrupts = <7 4>;
            davicom,no-eeprom;
    今天天气不错!签到!
    GMT+8, 2025-10-27 22:57 , Processed in 0.089466 second(s), 23 queries , MemCache On.
