查看: 6021|回复: 9
[原创] LPC824Lite 产生6路PWM
  • 签到天数: 273 天
    发表于 2016-11-15 11:14:05 | 显示全部楼层 |阅读模式
    LPC824的矩阵功能确实好用,玩PWM想可以随便配置输出,给你看看配置程序:
    static am_lpc82x_sct_pwm_ioinfo_t __g_sct0_pwm_ioinfo_list[] = {
        /** \brief   输出0 */
        {PIO0_7,  PIO_FUNC_SCT_OUT0,  PIO0_27_GPIO  | PIO0_7_GPIO_OUTPUT_INIT_HIGH},
        /** \brief    输出1 */
        {PIO0_13,  PIO_FUNC_SCT_OUT1,  PIO0_13_GPIO  | PIO0_13_GPIO_OUTPUT_INIT_HIGH},
        /** \brief    输出2 */
        {PIO0_16,  PIO_FUNC_SCT_OUT2,  PIO0_16_GPIO  | PIO0_16_GPIO_OUTPUT_INIT_HIGH},
        /** \brief    输出3 */
        {PIO0_17,  PIO_FUNC_SCT_OUT3,  PIO0_17_GPIO  | PIO0_17_GPIO_OUTPUT_INIT_HIGH},
        /** \brief    输出4 */
        {PIO0_19,  PIO_FUNC_SCT_OUT4,  PIO0_19_GPIO  | PIO0_19_GPIO_OUTPUT_INIT_HIGH},
        /** \brief    输出5 */
        {PIO0_27,  PIO_FUNC_SCT_OUT5,  PIO0_27_GPIO  | PIO0_27_GPIO_OUTPUT_INIT_HIGH},
    可以随意配置通道使用哪个IO口输出,以后画板子布线就容易多了
    接着初始化PWM,暂时就不做呼吸灯了,每路都是固定的频率和占空比:
        am_pwm_config(sct_pwm_handle, 0, 250000/2, 250000);
        am_pwm_enable(sct_pwm_handle, 0);
        am_pwm_config(sct_pwm_handle, 1, 250000/4, 250000);
        am_pwm_enable(sct_pwm_handle, 1);
        am_pwm_config(sct_pwm_handle, 2, 250000/8, 250000);
        am_pwm_enable(sct_pwm_handle, 2);
        am_pwm_config(sct_pwm_handle, 3, 250000/16, 250000);
        am_pwm_enable(sct_pwm_handle, 3);
        am_pwm_config(sct_pwm_handle, 4, 250000/32, 250000);
        am_pwm_enable(sct_pwm_handle, 4);
        am_pwm_config(sct_pwm_handle, 5, 250000/64, 250000);
        am_pwm_enable(sct_pwm_handle, 5);
    下面再加个闪灯,当运行指示:
        while (1) {
            am_led_toggle(LED7);
            am_mdelay(200);
    真像在这里:
    下面是波形图,一只手测量,另外一支手拍照真不容易
    备注一下:
    源程序请看ametal_am824_core_1.02中的
    ametal_am824_core_1.02\projects_keil5\examples_sct\demo_lpc82x_std_sct_pwm
    例程在这里可以下载:
    【LPC分享】LPC824例程及教程
    https://www.nxpic.org.cn/module/ ... amp;fromuid=2075309
    (出处: 恩智浦技术社区)
  • 签到天数: 206 天
    发表于 2016-11-15 11:36:12 | 显示全部楼层
    老哥,这示波器不便宜啊
    来根华子
  • 签到天数: 131 天
    发表于 2016-11-15 12:04:44 | 显示全部楼层
    壕的玩物
  • 签到天数: 273 天
     楼主| 发表于 2016-11-15 12:45:38 | 显示全部楼层
    混森蓝兽 发表于 2016-11-15 11:36
    老哥,这示波器不便宜啊
    是便宜货吧
  • 签到天数: 2992 天
    连续签到: 8 天
    发表于 2016-11-15 13:11:36 | 显示全部楼层
    赞一个,示波器看着不错。
    签到签到
  • 签到天数: 812 天
    发表于 2016-11-15 13:26:22 | 显示全部楼层
    感觉示波器好像是2000左右的
  • 签到天数: 1251 天
    发表于 2016-11-15 13:33:36 | 显示全部楼层
    这个示波器比板子好看多了
    郁闷
    2021-1-9 21:21
  • 签到天数: 56 天
    发表于 2016-11-21 23:12:55 | 显示全部楼层
    原来的你 发表于 2016-11-15 13:26
    感觉示波器好像是2000左右的
    应该是1500左右
    发表于 2016-12-1 08:00:23 | 显示全部楼层
    不错,不错
    昨天 08:22
  • 签到天数: 1504 天
    连续签到: 12 天
    发表于 2016-12-1 11:57:07 | 显示全部楼层
    学习一下,谢谢!
    GMT+8, 2026-4-14 00:09 , Processed in 0.111948 second(s), 29 queries , Redis On.
