查看: 3972|回复: 3
[MPC] MPC5745R芯片PIT求助
发表于 2016-12-2 17:22:55 | 显示全部楼层 |阅读模式
芯片  MPC5745R, PIT配置如下PIT_0.MCR.B.MDIS = 0;             // Clock for standard PIT timers is enabled.
PIT_0.MCR.B.FRZ = 0;              // Timers continue to run in Debug mode
uint32_t cnt_value=(uint32_t)(Clock_Freq*ExpectedTimeBase)-1;
PIT_0.TIMER[Channel].LDVAL.R=cnt_value;
PIT_0.TIMER[Channel].TCTRL.B.CHN = 0;
PIT_0.TIMER[Channel].TCTRL.B.TIE = 1;
PIT_0.TIMER[Channel].TFLG.B.TIF = 0;
PIT_0.TIMER[Channel].TCTRL.B.TEN=1;
INTC配置如下
        xcptn_xmpl ();              /* Configure and Enable Interrupts */
        //Choose software (HVEN=0) or hardware (HVEN=1) vector mode
    INTC_0.BCR.R = 0x00000000;
    //Set INTC ISR vector table base addr.
    INTC_0.IACKR[0].B.VTBA = (uint32_t) &IntcIsrVectorTable[0];
/***************Set priorities********************************************/
    //Set priorities - PIT
        switch(PIT_WD_CH){
                case 0 : INTC_0.PSR[226].B.PRIN = 12; break;
                case 1 : INTC_0.PSR[227].B.PRIN = 12; break;
                case 2 : INTC_0.PSR[228].B.PRIN = 12; break;
                case 3 : INTC_0.PSR[229].B.PRIN = 12; break;
        INTC_0.CPR[0].B.PRI = 0;
        // Enable external interrupts
        asm(" wrteei 1");
中断intc_SW_mode_isr_vectors_MPC574xR.c函数 中 在  226向量号定义中断服务函数
(uint32_t) &ISR226_PIT0_CH0, /* Vector # 226 Periodic Interrupt Timer (PIT0) PIT_0_TFLG0[TIF] */
然后一直进不去中断服务函数
大神给指点指点有什么问题
    2017-10-15 13:16
  • 签到天数: 191 天
    发表于 2016-12-2 21:20:49 | 显示全部楼层
    发表于 2016-12-2 23:58:03 | 显示全部楼层
    你用的那个IDE,先看看例程试试
  • 签到天数: 4 天
    发表于 2016-12-3 10:05:55 | 显示全部楼层
    GMT+8, 2025-10-28 09:59 , Processed in 0.149915 second(s), 24 queries , MemCache On.
