查看: 9060|回复: 9
[求助] DDR 校准
发表于 2016-12-5 16:08:40 | 显示全部楼层 |阅读模式
硬件配置:
    i.mx6D  ,DDR 为镁光的MT41K128M16JT-125K,两片,只用了一个片选 CS0.
I.MX6DQSDL DDR3 Script Aid V0.10.XLSX的配置如下:
Device Information
Manufacturer:
Micron
Memory part  number:
MT41K128M16JT-125K
Memory type:
DDR3-1600
DRAM density  (Gb)
DRAM Bus Width
16
Number of  Banks
8
Number of ROW  Addresses
Number of  COLUMN Addresses
Page Size (K)
Self-Refresh  Temperature (SRT)
Normal
tRCD=tRP=CL  (ns)
13.75
tRC Min (ns)
48.75
tRAS Min (ns)
35
System Information
i.Mx Part
i.Mx6D
Bus Width
32
Density per chip select (Gb)
Number of Chip  Selects used
Total DRAM Density (Gb)
DRAM Clock  Freq (MHz)
528
DRAM Clock  Cycle Time (ns)
1.894
Address  Mirror (for CS1)
Disable
SI Configuration
DRAM DSE  Setting - DQ/DQM (ohm)
48
DRAM DSE  Setting - ADDR/CMD/CTL (ohm)
48
DRAM DSE Setting - CK (ohm)
48
DRAM DSE Setting - DQS (ohm)
48
System ODT Setting (ohm)
60
Q1:以上配置不知道为没有问题?
然后把inc文件拷贝出来,把里面的看门狗去掉
//init script for i.Mx6D DDR3
// Revision History
// v01
wait = on
// Disable        WDOG
//setmem /16        0x020bc000 =        0x30
// Enable all clocks (they are disabled by ROM code)
setmem /32        0x020c4068 =        0xffffffff
setmem /32        0x020c406c =        0xffffffff
setmem /32        0x020c4070 =        0xffffffff
setmem /32        0x020c4074 =        0xffffffff
setmem /32        0x020c4078 =        0xffffffff
setmem /32        0x020c407c =        0xffffffff
setmem /32        0x020c4080 =        0xffffffff
setmem /32        0x020c4084 =        0xffffffff
// IOMUX
//DDR IO TYPE:
setmem /32        0x020e0798 =        0x000C0000        // IOMUXC_SW_PAD_CTL_GRP_DDR_TYPE
setmem /32        0x020e0758 =        0x00000000        // IOMUXC_SW_PAD_CTL_GRP_DDRPKE
//CLOCK:
setmem /32        0x020e0588 =        0x00000028        // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDCLK_0
setmem /32        0x020e0594 =        0x00000028        // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDCLK_1
//ADDRESS:
setmem /32        0x020e056c =        0x00000028        // IOMUXC_SW_PAD_CTL_PAD_DRAM_CAS
setmem /32        0x020e0578 =        0x00000028        // IOMUXC_SW_PAD_CTL_PAD_DRAM_RAS
setmem /32        0x020e074c =        0x00000028        // IOMUXC_SW_PAD_CTL_GRP_ADDDS
//Control:
setmem /32        0x020e057c =        0x00000028        // IOMUXC_SW_PAD_CTL_PAD_DRAM_RESET
setmem /32        0x020e058c =        0x00000000        // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDBA2 - DSE can be configured using Group Control Register: IOMUXC_SW_PAD_CTL_GRP_CTLDS
setmem /32        0x020e059c =        0x00000028        // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDODT0
setmem /32        0x020e05a0 =        0x00000028        // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDODT1
setmem /32        0x020e078c =        0x00000028        // IOMUXC_SW_PAD_CTL_GRP_CTLDS
//Data Strobes:
setmem /32        0x020e0750 =        0x00020000        // IOMUXC_SW_PAD_CTL_GRP_DDRMODE_CTL
setmem /32        0x020e05a8 =        0x00000028        // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS0
setmem /32        0x020e05b0 =        0x00000028        // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS1
setmem /32        0x020e0524 =        0x00000028        // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS2
setmem /32        0x020e051c =        0x00000028        // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS3
//setmem /32        0x020e0518 =        0x00000028        // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS4
//setmem /32        0x020e050c =        0x00000028        // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS5
//setmem /32        0x020e05b8 =        0x00000028        // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS6
//setmem /32        0x020e05c0 =        0x00000028        // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS7
//Data:
setmem /32        0x020e0774 =        0x00020000        // IOMUXC_SW_PAD_CTL_GRP_DDRMODE
setmem /32        0x020e0784 =        0x00000028        // IOMUXC_SW_PAD_CTL_GRP_B0DS
setmem /32        0x020e0788 =        0x00000028        // IOMUXC_SW_PAD_CTL_GRP_B1DS
setmem /32        0x020e0794 =        0x00000028        // IOMUXC_SW_PAD_CTL_GRP_B2DS
setmem /32        0x020e079c =        0x00000028        // IOMUXC_SW_PAD_CTL_GRP_B3DS
//setmem /32        0x020e07a0 =        0x00000028        // IOMUXC_SW_PAD_CTL_GRP_B4DS
//setmem /32        0x020e07a4 =        0x00000028        // IOMUXC_SW_PAD_CTL_GRP_B5DS
//setmem /32        0x020e07a8 =        0x00000028        // IOMUXC_SW_PAD_CTL_GRP_B6DS
//setmem /32        0x020e0748 =        0x00000028        // IOMUXC_SW_PAD_CTL_GRP_B7DS
setmem /32        0x020e05ac =        0x00000028        // IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM0
setmem /32        0x020e05b4 =        0x00000028        // IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM1
setmem /32        0x020e0528 =        0x00000028        // IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM2
setmem /32        0x020e0520 =        0x00000028        // IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM3
//setmem /32        0x020e0514 =        0x00000028        // IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM4
//setmem /32        0x020e0510 =        0x00000028        // IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM5
//setmem /32        0x020e05bc =        0x00000028        // IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM6
//setmem /32        0x020e05c4 =        0x00000028        // IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM7
// DDR Controller Registers
// Manufacturer:        Micron
// Device Part Number:        MT41K128M16JT-125
// Clock Freq.:         528MHz
// Density per CS in Gb:         4
// Chip Selects used:        1
// Number of Banks:        8
// Row address:            14
// Column address:         10
// Data bus width        32
setmem /32        0x021b001c =        0x00008000        MMDC0_MDSCR, set the Configuration request bit during MMDC set up
// Calibration setup.
setmem /32        0x021b0800 =        0xA1390003        // DDR_PHY_P0_MPZQHWCTRL, enable both one-time & periodic HW ZQ calibration.
// For target board, may need to run write leveling calibration to fine tune these settings.
setmem /32        0x021b080c  =        0x0017001A
setmem /32        0x021b0810 =        0x00210011
//setmem /32        0x021b480c  =        0x00000000
//setmem /32        0x021b4810 =        0x00000000
////Read DQS Gating calibration
setmem /32        0x021b083c =        0x03440350        // MPDGCTRL0 PHY0
setmem /32        0x021b0840 =        0x03400348        // MPDGCTRL1 PHY0
//setmem /32        0x021b483c =        0x00000000        // MPDGCTRL0 PHY1
//setmem /32        0x021b4840 =        0x00000000        // MPDGCTRL1 PHY1
//Read calibration
setmem /32        0x021b0848 =        0x3A303838        // MPRDDLCTL PHY0
//setmem /32        0x021b4848 =        0x40404040        // MPRDDLCTL PHY1
//Write calibration
setmem /32        0x021b0850 =        0x3C3A4038        // MPWRDLCTL PHY0
//setmem /32        0x021b4850 =        0x40404040        // MPWRDLCTL PHY1
//read data bit delay: (3 is the reccommended default value, although out of reset value is 0)
setmem /32        0x021b081c =        0x33333333        // DDR_PHY_P0_MPREDQBY0DL3
setmem /32        0x021b0820 =        0x33333333        // DDR_PHY_P0_MPREDQBY1DL3
setmem /32        0x021b0824 =        0x33333333        // DDR_PHY_P0_MPREDQBY2DL3
setmem /32        0x021b0828 =        0x33333333        // DDR_PHY_P0_MPREDQBY3DL3
//setmem /32        0x021b481c =        0x33333333        // DDR_PHY_P1_MPREDQBY0DL3
//setmem /32        0x021b4820 =        0x33333333        // DDR_PHY_P1_MPREDQBY1DL3
//setmem /32        0x021b4824 =        0x33333333        // DDR_PHY_P1_MPREDQBY2DL3
//setmem /32        0x021b4828 =        0x33333333        // DDR_PHY_P1_MPREDQBY3DL3
//For i.mx6qd parts of versions A & B (v1.0, v1.1), uncomment the following lines. For version C (v1.2), keep commented
//setmem /32        0x021b08c0 =        0x24911492        // fine tune SDCLK duty cyc to low - seen to improve measured duty cycle of i.mx6
//setmem /32        0x021b48c0 =        0x24911492
// Complete calibration by forced measurement:
setmem /32        0x021b08b8 =         0x00000800        // DDR_PHY_P0_MPMUR0, frc_msr
//setmem /32        0x021b48b8 =         0x00000800        // DDR_PHY_P0_MPMUR0, frc_msr
// Calibration setup end
//MMDC init:
setmem /32        0x021b0004 =        0x00020036        // MMDC0_MDPDC
setmem /32        0x021b0008 =        0x09444040        // MMDC0_MDOTC
setmem /32        0x021b000c =        0x54597955        // MMDC0_MDCFG0
setmem /32        0x021b0010 =        0xFF328F64        // MMDC0_MDCFG1
setmem /32        0x021b0014 =        0x01FF00DB        // MMDC0_MDCFG2
//MDMISC: RALAT kept to the high level of 5.
//MDMISC: consider reducing RALAT if your 528MHz board design allow that. Lower RALAT benefits:
//a. better operation at low frequency, for LPDDR2 freq < 100MHz, change RALAT to 3
//b. Small performence improvment
setmem /32        0x021b0018 =        0x00011740        // MMDC0_MDMISC
setmem /32        0x021b001c =        0x00008000        // MMDC0_MDSCR, set the Configuration request bit during MMDC set up
setmem /32        0x021b002c =        0x000026D2        // MMDC0_MDRWD
setmem /32        0x021b0030 =        0x00591023        // MMDC0_MDOR
setmem /32        0x021b0040 =        0x00000017        // Chan0 CS0_END
setmem /32        0x021b0000 =        0x83190000        // MMDC0_MDCTL
//Mode register writes
setmem /32        0x021b001c =        0x02088032        // MMDC0_MDSCR, MR2 write, CS0
setmem /32        0x021b001c =        0x00008033        // MMDC0_MDSCR, MR3 write, CS0
setmem /32        0x021b001c =        0x00048031        // MMDC0_MDSCR, MR1 write, CS0
setmem /32        0x021b001c =        0x19408030        // MMDC0_MDSCR, MR0write, CS0
setmem /32        0x021b001c =        0x04008040        // MMDC0_MDSCR, ZQ calibration command sent to device on CS0
//setmem /32        0x021b001c =        0x0208803A        // MMDC0_MDSCR, MR2 write, CS1
//setmem /32        0x021b001c =        0x0000803B        // MMDC0_MDSCR, MR3 write, CS1
//setmem /32        0x021b001c =        0x00048039        // MMDC0_MDSCR, MR1 write, CS1
//setmem /32        0x021b001c =        0x19408038        // MMDC0_MDSCR, MR0write, CS1
//setmem /32        0x021b001c =        0x04008048        // MMDC0_MDSCR, ZQ calibration command sent to device on CS1
setmem /32        0x021b0020 =        0x00007800        // MMDC0_MDREF
setmem /32        0x021b0818 =        0x00022227        // DDR_PHY_P0_MPODTCTRL
//setmem /32        0x021b4818 =        0x00022227        // DDR_PHY_P1_MPODTCTRL
setmem /32        0x021b0004 =        0x00025576        // MMDC0_MDPDC now SDCTL power down enabled
setmem /32        0x021b0404 =        0x00011006        // MMDC0_MAPSR ADOPT power down enabled, MMDC will enter automatically to self-refresh while the number of idle cycle reached.
setmem /32        0x021b001c =        0x00000000        // MMDC0_MDSCR, clear this register (especially the configuration bit as initialization is complete)
开始进行压力测试:
1、选 800MHZ 的主频率       -> 1
2、选 512MB的内存              ->2
3、选校准频率528MHZ         ->y
4、选MR1的值                      ->0004
我做了三块板(2#,4#,5#),其中一块做了两次,得到了校准参数:
2#
MMDC_MPWLDECTRL0 CH0 0X0015001A
MMDC_MPWLDECTRL1 CH0 0X001A000B
MPDGCTRL0 PHY0     = OX0340034C
MPDGCTRL0 PHY0     = OX03340338
MPRDDLCTL  PHY0    =  0X3E34383C
MPWRDLCTL  PHY0    =  0X38383C3A
4#0
MMDC_MPWLDECTRL0 CH0 0X00140019
MMDC_MPWLDECTRL1 CH0 0X00160009
MPDGCTRL0 PHY0     = OX03400344
MPDGCTRL0 PHY0     = OX0334033C
MPRDDLCTL  PHY0   =  0X42344040
MPWRDLCTL  PHY0   =  0X3E3A403C
4#1
MMDC_MPWLDECTRL0 CH0 0X0014001B
MMDC_MPWLDECTRL1 CH0 0X0019000C
MPDGCTRL0 PHY0     = 0X03400344
MPDGCTRL0 PHY0     = 0X0334033C
5#
MMDC_MPWLDECTRL0 CH0 0X0011001B
MPDGCTRL0 PHY0     = 0X03400348
MPRDDLCTL  PHY0   =  0X3E30363A
MPWRDLCTL  PHY0   =  0X3C384036
Q2:同一批次的板子得到的参数不一样,而且同一板子测试两次得到的参数也不一样,这是为什么啊?我们如何得到合适的校准参数啊?
得到的六个值回写到 inc文件里进行压力测试,测试了一天多,没有问题。
Q3: inc里的值 是不是只要把标红的更新到flash_header.s里?还是说要对一遍所有的,以.inc里的为准,更新到flash_header.s?
我知道答案 目前已有9人回答
发表于 2016-12-5 17:11:03 | 显示全部楼层
楼主你好,关于Q2回答如下:
这个现象并不奇怪,说明DDR在布线上有一些问题,造成了在某个频率上出现临界点,这个临界点附近是不稳定的,有时候可以跑过去,有时候跑不过去。但是,如果在528MHz,400MHz时,每次都可以通过,并且是稳定的,就可以配置为528MHz或者400MHz。
发表于 2016-12-5 17:11:23 | 显示全部楼层
每次做DDR压力测试,528MHz总是可以通过,那么就配置为528MHz,这是我们标准,并且MMDC支持的时钟频率。
发表于 2016-12-5 17:11:53 | 显示全部楼层
这个DDR test不是用来校准的,是测试DDR工作性能的。你这里使用528M就是OK的。
发表于 2016-12-5 17:13:56 | 显示全部楼层
关于另外两个问题,关于DDR的设置,建议你参考你芯片的手册和参数来设置。你可以参考一下我们论坛中的帖子:
https://www.nxpic.org.cn/module/forum/thread-594371-1-1.html
https://www.nxpic.org.cn/module/forum/thread-606303-1-1.html
 楼主| 发表于 2016-12-5 17:15:10 | 显示全部楼层
小智MM 发表于 2016-12-5 17:11
这个DDR test不是用来校准的,是测试DDR工作性能的。你这里使用528M就是OK的。 ...
你好,Q3,我应该怎么做?
    2017-10-15 13:16
  • 签到天数: 191 天
    发表于 2016-12-5 17:32:37 | 显示全部楼层
    谢谢分享
    发表于 2016-12-5 21:02:28 | 显示全部楼层
    学习一下
  • 签到天数: 4 天
    发表于 2016-12-6 09:20:00 | 显示全部楼层
    真不懂
  • 签到天数: 184 天
    发表于 2016-12-7 09:57:54 | 显示全部楼层
    学习一下....
    GMT+8, 2025-10-24 03:48 , Processed in 0.110294 second(s), 30 queries , MemCache On.
